Old 1st July 2021, 01:14   #21  |  Link
Sounds good.
Old 3rd July 2021, 12:19   #22  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Originally Posted by chmars View Post
It is a RAW file resulting from macro motion control tests.
I didn't find a way to open it in Avisynth64 though. If someone knows how, I'd be curious to try.
You didn't find a way 'cause there's no way.
When I first got my first red file, there were no indexers, so I installed the codec and put the money on DirectShowSource. Needless to say I was pretty disappointed as the codec wasn't really a codec meant to be used by Windows but rather a plugin to allow AVID Media Composer and other NLE to link the file and transcode it...
Old 3rd July 2021, 14:22   #23  |  Link
chmars
Ah, too bad, Thanks for your lights.
A certain Gabor Kertai developped something for R3D some years ago.
But only 8-bit due to Avisynth limitation at this moment if I get it right.
R3D source plugin for AviSynth
R3D input plugin for VirutalDub
The Avisynth 32 bit plugin can be found in a plugins pack in this doom9 post.
chmars is offline   Reply With Quote
Old 3rd July 2021, 16:31   #24  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Yes, but that plugin is only for very very very very old files and doesn't work with new .r3d files, sadly...
