Old 20th January 2021, 12:10   #1  |  Link
knack_liek
Avisynth script to remove grain, spots, lines, scratches and dirt.
I am new to the world of Avisynth coding, but I have managed to create (by reading guides to find and download the various necessary plugins), through AvsPmod, a script for removing grain, dirt, lines, scratches and spots.
I did a lot of research to make sure that I have included in the source code sheet everything necessary for the script to work in the correct order, also thanks to the powerful AvsPmod debugging tool.
However, I see no difference in the output of the scripted video file.
Did I write something wrong or is the script missing some basic commands (I attach the script I write below)?
Let me know!
import("C:\Program Files (x86)\AviSynth\plugins\RemoveDirtMC.avs")
DirectShowSource("videosource", fps= 29.97, convertfps=true)
ConvertToYV12(matrix="rec709")
RemoveDirt(20,false)
RemoveGrain()
TurnRight()
RemoveGrain()
TurnLeft()
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\despot.dll")
DeSpot(p1=35, p2=14, mthres=25)
even = SelectEven().RemoveDirt(80, false)
odd = SelectOdd().RemoveDirt(80, false)
Interleave(even, odd).RemoveDirt(80, false)
knack_liek is offline   Reply With Quote
Old 20th January 2021, 15:15   #2  |  Link
videoh
Useful n00b
Should be like below. Every time you re-source the file, you lose the previous work. Source the file only once.
RemoveGrain()
TurnRight()
RemoveGrain()
TurnLeft()
Old 20th January 2021, 17:43   #3  |  Link
hello_hello
knack_liek,
FYI, DirectShowSource is probably a "last resort" source filter. It's often not frame accurate (if you jump to a specific frame number you mightn't land on the same frame each time) . Even the DirectShowSource page on the wiki suggests the same. http://avisynth.nl/index.php/DirectShowSource
You're also at the mercy of having system codecs doing the decoding.
For DVD and mpeg2 video: http://avisynth.nl/index.php/DGDecode
For most file types:
http://avisynth.nl/index.php/FFmpegSource
or
http://avisynth.nl/index.php/LSMASHSource
despot, errors, lines, removedirt, removegrain
