27th September 2010, 15:54 | #8541 | Link | |
benjyv -
if you really don't have those folders, your installation didn't go right. I suspect maybe you're not lookin in the install directory or something though Quote:
Changed: HD Audio can now be demuxed and copied instead of always, retardedly being decompressed directly to .w64 |
28th September 2010, 09:48 | #8542 | Link |
eac3to cannot fix audio gaps while demuxing TrueHD.
24 bit DTS-MA+DTS-Core is just a waste of space. 16 bit FLAC is a better option and don't tell me that you hear difference between 24bit and 16bit.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 28th September 2010 at 09:54. |
28th September 2010, 21:20 | #8543 | Link |
flac is not really option if you have a bluray player
it's also not if you like keeping things as unmodified / original as possible DTS-HD MA is not a waste of space because it is lossless. however wav / PCM is a waste of space because it contains redundancies I was unaware of eac3to not being able to fix gaps in TrueHD. I'm not sure I've run across a branched bluray with TrueHD though it is able to fix them while demuxing / decompressing though? |
29th September 2010, 00:27 | #8544 | Link |
Is there any benefit to using CoreAVC w/Cuda support to decode the video for Ripbot vs ffdshow's ffmpeg-mt?
I was just messing around with it last night and when using CoreAVC /Cuda the Video Engine load (as reported by GPU-Z) was around 10%-20% while ripbot was running and the x264 was at 98%-99% cpu usage and avysynth (I think that was the name anyway) was using around 1%-2%. So by offloading the decoding to the nvidia card via Cuda does that provide any benefit to the encoding speed (assuming the decoding would be using roughly the same 10-20% of cpu instead of GPU - I'm a complete noob and have been looking these things up as I have time)? I did notice that while using ripbot and CoreAVC together Ripbot doesn't update progress and the window simply shows "not responding". I've seen a lot of posts about benchmarks on decoding speed...but not really any using it along with encoding for speed benefit. I'm doing an encode right now just to see (Prince of Persia blu-ray) and when it's done I'm going to re-do it with the same settings only with CoreAVC. I just figured I'd ask here to see if anyone had any thoughts if it was worth it or not or if the gains (if any) to be had were negligible. |
29th September 2010, 10:50 | #8545 | Link | |||
29th September 2010, 17:40 | #8546 | Link | |||
I do have a question about that though....does eac3to automatically fix gaps? or does it require anything extra in the command to do so in eac3to and more gui there's a "If Gaps File Found, Rerun Command Line For Affected Files" option I don't see anything extra added to the command line and the log reads the same had I not checked it. and this is eac3to fixing the overlaps right: Code:
[a04] Starting 2nd pass... [a04] Realizing DTS gaps... |
29th September 2010, 18:10 | #8547 | Link |
I'm having problems with how ripbot reads HDV Cineform files. If I have an 1440x1080 cineform file ripbot won't give me anything other than SD re-size options.
29th September 2010, 18:20 | #8548 | Link |
I have a film 29.970 fps as it is to change the standard 23.976? Information about the film, see below!
D : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 12 frames Muxing mode : Container profile=Unknown@4.0 Codec ID : V_MPEG4/ISO/AVC Duration : 1h 41mn Nominal bit rate : 2 800 Kbps Width : 1 024 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.158 Last edited by muhadi; 29th September 2010 at 18:27. |
30th September 2010, 13:32 | #8550 | Link |
Hello Atak,
I've experience some movies burned with BDMV + CERTIFICATE folder burned after conversion of PS3 reading only has a file (seen only folders) need to navigate and select the m2ts file has a file. Some LG Bluray readers of my mother can't read the disc! I tested to change medias type, brand, burner, it does the same. Now i test to repack again with tsmuser to AVCHD format to reburn and see if the problem is resolved. Did you get feedback of this issue from other members? 8ternity EDIT: when project is done, less folder having in the BDMV subfolder. Here an example˝: Ripbot264 folders in BDMV\ Code:
BACKUP CLIPINF PLAYLIST STREAM index.bdmv MovieObject.bdmv Code:
AUXDATA BACKUP BDJO CLIOPINF JAR META PLAYLIST STREAM index.bdmv MovieObject.bdmv
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 30th September 2010 at 13:38. |
30th September 2010, 15:00 | #8551 | Link | |
@8ternity
Which one is working for you? Ripbot264 is set to create strict AVCHD structure (empty redundant folders are removed) @muhadi try Restore -> 23.976 fps Quote:
@Lobstaman Did you try to manually select resolution? ( Custom [x,xx:1] )
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 30th September 2010 at 15:32. |
30th September 2010, 19:16 | #8552 | Link |
well like I was saying, this is eac3to fixing the overlaps, isn't it??
[a04] Starting 2nd pass... [a04] Realizing DTS gaps... cuz I know I'm not the only one making bd25s nor the only one who likes too keep DTS-HD MA. and this way the person can choose what they'd prefer to do with the audio. |
30th September 2010, 19:41 | #8553 | Link |
We all know that x264 encoder is extremly efficient so 20-25Mbps is more that enough for 1920x1080. BD25 has also enough space for uncompressed audio.
Quick example: 20Mbps (bitrate for video) / 8 = 2.5 MB/s 120 min movie = 7200 s 2.5MB/s * 7200 = 18000 MB 23830 MB (real BD25 size) - 18000 MB (video size) = 5830 MB (to be used by audio stream) 48000(Hz)*8(channels)*2(16bit)=750KB/s 750KB/s*7200s=5400000KB=5273 MB 18000MB + 5273 MB = 23273 MB As you can see despite 8 channel audio uses only ~5GB on disc. Also don't forget that DTS-MA is not really supported in strict AVCHD structure.
30th September 2010, 20:04 | #8554 | Link |
I don't mux to AVCHD for BD25's, I mux to bluray structure.
and once again....there are more reasons than just space to keep tracks like DTS-HDMA. So why does it even matter if you can fit uncompressed audio? if you can fit the original DTS-HDMA track and use ~2GB less space it'd be stupid to waste that 2GB of space with PCM audio.... you have the same audio....and use less space, why is there any argument there? with DTS-HDMA some movies still have to be dropped quite low to fit BD25. robin hood, for example, I had to drop under 16000. imagine if I'd wasted even more space using PCM I don't understand why you always insist on arguing simply because you don't like something or you wouldn't personally want to use it. I know this is your tool and all that...but if it's something people would use and can benefit from...why not add it? |
30th September 2010, 20:22 | #8555 | Link | |
Look what PS3 show (Data Disc); Disc Informations: Data Disc: All folders is there with BLURAY structure export in tsmuxer. What im questionnig myself, did export in bluray structure can cause disc faillure in PS3 has burned on DVD5/9 format? I will remux it in AVCHD + reburn and retest, before bring back my brother ps3. Thanks!
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
1st October 2010, 00:18 | #8556 | Link |
HI Atak;
I've remuxe in AVCHD with tsmuxerGUI and reburn and it detected has AVCHD disc in the ps3. I will bring the new burned disc and tested in the LG blu-ray home theater this weekend. Thank You, 8ternity
1st October 2010, 04:15 | #8557 | Link |
I've messed with bluray vs avchd mux before
I burned a bd9 after muxing to bluray, a bluray player and a PS3 wouldn't read it if you're burning DVD5/DVD9 use AVCHD if you're burning BD25/BD50 use Bluray I've never tried muxing to AVCHD for a bluray disc.....but I'm not wasting a bd-r to find out if it works or not =P Last edited by pacaveli211; 1st October 2010 at 04:17. |
1st October 2010, 11:16 | #8558 | Link |
@pacaveli211
Use BD-Rebuilder. Problem solved.
