10th September 2016, 21:02 | #1281 | Link |
It seems that Nvidias Hybrid H.265 Decoder is more efficient with CUVID Decoding especially on intra frames DXVA Native has the tendency to cause latency spikes (no matter which decoder used) on edge decoding cases i guess it has todo with DXVA Natives Frequency Scaling issues in conjunction with Nvidias Boost Power Management System.
I frames seem to heavy fluctuate in my tests with Nvidias Hybrid Decoder GM204 and a DXVA frequency of around 759 MHz @ 0,862v Real 4K 23.976 Fps CUVID doesn't show these Latency I frame fluctuations @ 1126 MHz @ 1.025v NVAPI Hook readouts (MSI Afterburner hooked NVAPI results gained after test) Though Unwinders code is super nice it itself creates almost 0 fluctuations when polling of Nvapi is kept in sane ranges Im mainly using as seen MPC-BE Sync Graph which is awesome fine grained for a almost Realtime Graph especially in Analyze Mode 2 when CPU overhead is way lower then with the Full OSD and additional timer polling (NVAPI ?) eliminated @V0lt Please add a Sync Graph only Analyze Mode without any additional OSD timer running maybe it can further lower the Overhead and it's caused EVR Latency Fluctuations that become visible in the Graph itself increasing the Audio and Video distance from the middle with DWMs tripple buffering same happens with Energy Saving Modes the lines move away when timer precision is lowered and CPU overhead gets higher with lower Frequency PS: About the Intel vs AMD thing Intel had a major advantage with shrinking up to 22nm before AMD could do it thus is the only reason they won the Mobile Space with Baytrail and Cherrytrail adding more CUs each time this advantage is slowly over, but it gave Intel the time to improve the GPU each time and close the gap to AMD and Intels GPU Core being now more feature advanced then all of them including the Video Asic part, where we will see surely another interesting development but i guess not with Kabylake in terms of Intels capability with their Video Decode/Encode time to market updates in the future At least with 14nm we reach pretty much parity for the first time between virtualy all of them for a longer time period. Intel = 22nm/14nm/ in the future targeting 11nm but the shrinking advantage will be lower as ever before Nvidia =28nm/16nm/14nm AMD = 28nm/14nm so 14nm is the common denominator on that a lot architecturally will happen finally and no shrinking race advantage anymore for a longer period
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 11th September 2016 at 06:28. |
11th September 2016, 00:28 | #1284 | Link | |
11th September 2016, 17:54 | #1285 | Link | |
It's pretty simple a Graph that shows you the current Render Jitter and this is dependent on many System factors the lower the jitter the smoother the Rendering playback
And the Graph is very sensitive to System Problems and fluctuations in the whole WDDM Playback Chain because it's own Render Overhead isn't really high though it works only in the Render context of D3D9 in MPC-BE for now it's though muich nicer then some static numbers you can't bring into context over time of what you seeing even if it's slightly delayed Push for example the Print Screen button and see if you get a spike Quote:
Though you wouldn't really expect anything else from VP7/8 Nvidia is very picky about memory see the last AV1 Optimizations they proposed for the De-ringing Filter or their latest AGGA R&D Nvidias Hybrid Decoder failing not even Broadcast Complexity but high enough to get it performing very unstable 13 sm vs 4 Intel Cores to the rescue PS: Did some RX 460,470 480 user tried if Strongene Lentoids Hybrid OpenCL Decoder still works, as each IDCT,MC and PP part is generation individually optimized and chosen at runtime i wonder if it still works @ all on Polaris GCN 4.0 supporting the Decoding or fails or if it's going to fallback to the Tonga\Hawai or some Generic GPU/CPU Path ? Lentoid can even partly outrun lav video in complex bitstream parts when the CPU starts to starving under heavy load and push out more stable results then but therefore it also uses lot more System Ram and it performs equal in 32 bit as in 64 bit no slowdown like lav video Fast Scenechange sudden Bitrate Peak test Lav Video CPU Lentoid CPU
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 12th September 2016 at 17:08. |
19th September 2016, 09:16 | #1286 | Link |
I'm back, to share my findings. I'm trying to optimize my CPU and GPU power in order to get the maximum HEVC decoding result.
For now, the best thing I can achieve on a 4K 40Mbps HEVC sample, using a 2600K@4.4 and GTX960, on a 1080p display : - GPU HEVC decoding : OK. - Madvr : Jinc and other "rather good" algoritms - FRC (Frame Rate Conversion) using SVP, from 24p to 60p The GPU assumes most Madvr + LAV work, while the CPU is used for frame interpolation. I'm currently tuning the settings to get a rock stable smooth experience. The 1080p output helps a lot, on my 1440p the rendering time grows quickly.
I7 2600K@4.4 / GTX1080 / ACER M550 (DLP 4K) / Catleap (IPS 1440p) / Onkyo SE200 Sound card Last edited by Paul Tronc; 19th September 2016 at 09:18. |
7th October 2016, 14:23 | #1288 | Link |
And 10bit VP9 ?
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
7th October 2016, 14:44 | #1290 | Link |
No and I haven't found an encoder
7th October 2016, 18:28 | #1292 | Link |
here a 3 sec VP9 10 bit file: http://filehorst.de/download.php?file=bDyyChti
i encoded it with VPXENC edit: i will check out 16.10.1 for polaris VP9 support |
7th October 2016, 18:32 | #1293 | Link |
You own a polaris card ?
7th October 2016, 18:47 | #1295 | Link |
It would be useful if you could post H.264 & H.265 (8bit & 10bit) benchmarks of the usual clips of this thread.
Which one by the way ?
7th October 2016, 18:56 | #1296 | Link |
RX 480 4Gb.
it's broken or at least i have major problem with it to even get an Constant image have to replace before i can do any proper test. i will do some test with the card in some of my other PC this weekend to make sure it is really the card. even though it is pretty clearly the card. in short no performance tests for now. and most likely not any time soon. |
7th October 2016, 19:07 | #1297 | Link |
Do you have problems in 2D and 3D besides video ?
7th October 2016, 19:17 | #1298 | Link |
i get the problem in madVR and in browser. so it is generally.
nothing special just bad luck. i could work around it and do some tests but testing this card it self is just more important right now. trust me i'm very very upset about this. |
7th October 2016, 19:22 | #1299 | Link |
Brand ?
