11th December 2015, 20:17 | #1161 | Link |
L-SMASH Source used to be more reliable earlier while FFMS2 relied on parts of Haali Media Splitter for non-MKV sources (so FFMS2 also had issues with interlaced formats when using more than 1 decoding thread). Today both use libavformats as splitter and are quite equal now.
Remultiplexing some containers to MKV with mkvtoolnix before indexing them may still be a good idea, the MKV container has some features supporting seeking which some other containers don't provide. |
21st December 2015, 19:19 | #1165 | Link |
I have noticed in the Program Settings under the 'Misc' Tab their is a 'Custom Jump Size' option, im guessing this is to select a time or frame to jump to when editing a video?. I know Up & Down Arrows are for jumping in 1 seconds increments and Page Up & Down is for 1 minute increments but not sure that the key is for this 'Custom Jump' feature?
23rd December 2015, 00:03 | #1168 | Link | |
BlockABoots,
Give fvisagie some clue as to what you mean.
29th December 2015, 16:58 | #1169 | Link |
As a 32 bit process, AvsPmod will open VapourSynth scripts as video source only if you installed Python 3.5 and VapourSynth as 32 bit versions. With Python and VapourSynth installed as 64 bit version, AviSource of a 32 bit AviSynth will not find a handler for vpy files.
29th December 2015, 17:34 | #1170 | Link | |
12th March 2016, 07:13 | #1171 | Link | |
Hello all,
I may be doing something totally wrong, or missed a step, but I can't get avspmod to open. I click the executable, but nothing happens after I hit the "run" option in the box that pops up asking me what I want to do. This is the error message I get: Quote:
I downloaded version 2.5.1, I have avisynth 2.6, I'm running Windows 7, any ideas? Thank you |
13th March 2016, 09:10 | #1172 | Link |
Earlier (in this thread?) I covered something similar. IIRC it involves unevelated AvsPmod trying to write to protected area under \Program Files.... What may help is to delete configuration files there and/or running AvsPmod with elevated privileges at least once.
13th March 2016, 09:27 | #1173 | Link | |
And AvsPmod saves the latest version that you was working on and refuses to open like this. Try opening empty avs script in AvsPmod with "Open with". |
13th March 2016, 09:49 | #1174 | Link |
I think I found that passage, it's on page 55 of this thread. It looks like what finally solved it for the poster having trouble was to delete and reinstall avisynth. I hope I don't have to do the same.
I tried running it as an admin, still no luck. Thank you both for helping me look at and solve this. |
14th March 2016, 09:19 | #1175 | Link |
I uninstalled and reinstalled Avisynth.
AVSPMod still won't even open. Puzzling. I'm also having an issue with MeGUI. I have a short AV script that will open in both MeGUI and VDub (and Media Player Classic, etc). But I have a long script with numerous filters that that I can get to open in VDub, but crashes MeGUI even before it can open and get to the preview screen. I don't know if that's related or not, or whether it helps isolate the issue, but thought I'd put that out there. |
18th March 2016, 13:52 | #1176 | Link |
An update.
Now that I have my MeGUI issue figured out, I went back to see if I could get this straight. I had a thought that gave me an idea. In some of my other avisynth related issues I had, a fix was putting a copy of the .dll in the SysWOW64 folder. So I dropped the dll's from AVSPmod in there also and voila, it works. |
8th May 2016, 23:25 | #1177 | Link |
SeparateFields() duplicate handling bug ? ConvertToRGB32(interlaced=true) vs RGB24
Bug report regarding duplicated fields when separatefields() is used with ConvertToRGB24(interlaced=true) or sometimes RGB32
Seems to be avspmod related, as problem doesn't occur in vdub, mpchc, megui preview Instead of copy/pasting, see this thread for more details http://forum.doom9.org/showthread.php?t=173482 |
11th August 2016, 17:20 | #1179 | Link |
Location: Terneuzen, Zeeland, the Netherlands, Europe, Earth, Milky Way,Universe
I do not know if this is the answer to your question, but just open an AvsPmod script in VDub, and VDub will ignore the AvsPmod part and it will 'see' it as a normal Avisynth script.
Fred.
About 8mm film: http://www.super-8.be Film Transfer Tutorial and example clips: https://www.youtube.com/watch?v=W4QBsWXKuV8 More Example clips: http://www.vimeo.com/user678523/videos/sort:newest |
4th October 2016, 13:11 | #1180 | Link | ||
BTW: Quote:
