11th October 2021, 21:43 | #581 | Link |
It's unfortunately not that easy to support MakeMKV. You can still support Findvuk without DVDFab by using the command line parameter GetMetaInfoFromDisc
findvuk.exe GetMetaInfoFromDisc=[driveletter] This will only upload disc metadata like the discid and title to the findvuk database. However keys will then magically appear in a future keydb update . You just need to wait a while |
30th October 2021, 23:13 | #582 | Link |
Updated http://fvonline-db.bplaced.net/ to also include DeviceKeys, ProcessingKeys and HostCertificates.
For the moment the ones from this post Up to MKB v68 KEYDB.cfg file are included. I'm still not sure if I should exclude the old host certificates? During the next days I'll publish a new FindVUK that also synchronises them properly and includes support for aacskeys in order to easily get the VUK for supported discs on drives where the latest host certificate is not yet revoked. Additionally this new FindVUK will process uploaded "legacy" entries directly into the online database so that I don't have to process them manually every now and then |
1st November 2021, 01:41 | #583 | Link | |
You'll be fine using just the latest revoked host cert for v71, as for processing keys just use the ones for v63 through v68 and the device keys will cover everything from v1 through v62
unfortunately we still do not have processing/device keys for MKB revisions above v68 (e.g v70/v71 and up) but hopefully some may come about soon. here's my sample config that plays everything i have up to v68: Quote:
10th November 2021, 23:20 | #584 | Link |
Thanks! You're absolutely right - I've already flagged the other entries in the online database as "to be ignored" so they aren't included again.
The processing-keys MKBv01 until MKBv62 are calculated on the fly with the device-keys. So separated processing-keys are only necessary for the MKBversions where no device key is available. And the most recent host certificate is enough as it also works with old entries. |
11th November 2021, 21:50 | #585 | Link |
Released FindVUK 1.53
It includes a lot of small bugfixes and the integration of aacskeys. With the processing-keys, device-keys and the host-certificate now also available from the online-db it's possible to get the vuk and the unitkeys directly without DVDfab software - at least as long as the drive has not yet revoked the host certificate (it's only valid until mkbv71 and got revoked in 72) and the inserted disc is max mkbv68. I've added a small "FindVUK - AACSkeys.bat" that takes a driveletter as parameter, so in the easiest case simply drag and drop a drive in explorer on the bat file. Finally I've changed the upload during the sync of the keydb.cfg so that not only single "meta" entries get directly processed, but also the sync of unvalidated entries. In case you notice any problems just let me know - thanks! |
13th November 2021, 22:51 | #586 | Link |
Released FindVUK 1.54
Only one change - introduced a new ini parameter to disable the upload of ProcessingKeys, DeviceKeys and HostCertificates and it's now disabled by default. As there's no easy way to get new DeviceKeys, HostCertificates it's not sure that in case someone discovers new entry, he's already willing to share them with others. Note: in case entries of this 3 kinds are uploaded, they aren't published automatically. They get a special flag in database and require that I enable them specifically. |
26th April 2022, 19:09 | #587 | Link |
I have a disc where processing fails because it seem to have a weird/stupid name : The Night of the Sorcerers / The
The slash seem to be the culprit ?
MPC-BE feature wishlist: 1) DiscID 2) Two independent volume control sliders in the UI when using dual-audio-out. |
1st May 2022, 11:15 | #589 | Link |
Just released 1.55 - hopefully it fixes the notified problem.
There has already been a procedured to "fix" special characters in the final filename. The new problem comes from the fact that "" or "/" are both discovered as folder separator and so my previous procedure though the only the part behind the "/" is finally the filename ... Now I'll check for those 2 very special characters before executing the other special-character check Hope it works! |
1st May 2022, 14:00 | #590 | Link |
Seem to not work yet. Will send you the logtext via PM. Thank you
1st July 2022, 16:29 | #592 | Link |
DVD Magistrate
anyone know what happened to:
http://fvonline-db.bplaced.net/ Nothing there anymore. Anyone have the last file from there? |
5th July 2022, 19:29 | #594 | Link |
Hopefully he is just on vacation and only forget to pay for the hosting as of July 1st. Fingers crossed.
6th July 2022, 23:36 | #595 | Link |
Big Bit Savings Now !
If you have an old version of FindVUK: the update via Synchronize.bat still works,
just got 1.57 and updated database. Hm, the ShowAllDriveDetails.bat seems incomplete, one may add a second line with content pause
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 6th July 2022 at 23:50. |
7th July 2022, 08:41 | #597 | Link |
Website works again for me since yesterday morning ! Maybe you should clear your browser cache ?
7th July 2022, 12:25 | #598 | Link |
Browser cache of course. A reload did it, thank you !
7th July 2022, 12:38 | #599 | Link |
Note to nalor: Again, many thanks !
Running FindVUK - AACSkeys.bat exhibits a filename incompatibility: I happened to have spaces in my path: cmd.exe stops path parsing at the first space from left. Commenting these lines out and hardwiring helped to start up. aacskeys=%1 did not find my drive, so hardsetting my drive letter G helped: Code:
:@set fv_path=%~dp0 :%fv_path%findvuk.exe aacskeys=%1 findvuk.exe aacskeys=G pause
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 7th July 2022 at 12:48. |
