15th May 2023, 15:02 | #1 | Link |
Broadcast Encoder
Getting started with VSGAN for a VapourSynth newbie
Hi there,
I'm a long time Avisynth user (2006) and I've never ever used VapourSynth in my life, but you know, my boss wanted me to test the new GAN models and there just isn't such a thing for Avisynth, so I had to tell myself "the day has come" and install VapourSynth. After so many years I'm not really planning in changing frameserver, but you know, I will at least test all the new VSGAN models, compare them against NNEDI3 in real life v210 lossless footage from tapes and then decide. Anyway, I'm facing some issues. OS: Windows 10 22H2 Enterprise x64 CPU: i7 5930K 6c/12th 3.50GHz RAM: 32GB DDR4 (8x4) GPU: NVIDIA GTX 980Ti 6GB GDDR5 Steps I've done, following the guide: - Installed Python 3.11 x64 - Installed VapourSynth x64 - Put in the C:\Program Files\VapourSynth\plugins path the following plugins: akarin.dll, ffms2.dll, ffmsindex.exe, libhistogram.dll, LibP2P.dll, LSMASHSource.dll - Installed Anaconda x64 - From Anaconda: pip install VSGAN pip install torch torchaudio pip install torchvision conda install pytorch -c pytorch and yet: I'm definitely doing something stupid, I know, I'm sure, but I don't know what. By the way, before you think I'm crazy, the computer above is what I'll be using for testing purposes. As far as the real encoding is concerned, it would, eventually, be done on a 20c/40th Intel Xeon with an NVIDIA Quadro P4000. So... what am I doing wrong? |
15th May 2023, 18:43 | #2 | Link |
It seems like your VSGAN had not installed correctly, follow the instruction here:
https://vsgan.phoeniix.dev/en/stable/installation.html And in your script, you need to load the different model, not the filter itself. You can find models from this database: https://upscale.wiki/wiki/Model_Database Code:
esrgan = ESRGAN(clip, "cuda") model = r'2x_LD-Anime_Skr_v1.0.pth' clip = esrgan.load(model).apply().clip clip.set_output() |
16th May 2023, 09:22 | #3 | Link |
Broadcast Encoder
Well, I did, but it's not really finding it...
Same result... From the sources I'm reading about on the web, it looks like things have to be installed for the current user. So I thought "hold on a second, it might be that I'm trying to use two different users?" I started VapourSynthEditor2 using the same Windows user I used to run Anaconda and install VSGAN, then, but nothing. I'm lost. |
16th May 2023, 19:55 | #5 | Link |
Probably an anaconda issue ; perhaps a conflict with site-packages directory.
Notice you have 2 different locations: python310\site-packages and anaconda3\lib\site-packages. vsgan is in the 1st location. For portable installations, there is a python<version>._pth file that you can edit in notepad to modify directory locations. It might work with anaconda, not sure |
17th May 2023, 09:03 | #6 | Link |
Anaconda has some issues with VS (scroll down to last post)
https://github.com/vapoursynth/vapoursynth/issues/225 You could try the "diagnose" button in vsrepogui https://github.com/theChaosCoder/VSRepoGUI It mainly checks for plugin issues, but also shows the installed python and vs versions.
17th May 2023, 10:13 | #7 | Link | |||
Broadcast Encoder
Yep, ffms2 as an indexer works:
That's the output of "Check Script". On the other hand, clicking on "Script, Preview" in VapourSynthEditor2, does nothing and if I click on the "Play" button on the right hand side, VapourSynthEditor2 crashes: At the same time, though, VirtualDub plays the content from the .vpy script just fine (the one with just the indexing, that is): Quote:
I'm not particularly attached to it, I just downloaded it the other day, so I'm totally open to changes. Besides, the only reason why I used it is because it was mentioned in the VSGAN guide somewhere... Anyway, so, it is an Anaconda issue and Anaconda is bad as it doesn't play nicely with VapourSynth, gotcha. The next question is gonna be: what should I use instead of Anaconda to install VSGAN properly and in a VapourSynth friendly way? |
17th May 2023, 21:11 | #8 | Link | ||
You could also try the portable version. Simply download python embedded and extract the VS files into the same folder. Same with the VS Editor. Make sure you use the python.exe from the portable folder. Then "install" pip and vsgan etc..
18th May 2023, 17:21 | #9 | Link | |
Also, if you want I can send you a link to my portable Vapoursynth folder which I use in Hybrid as 'torchAddon', it does include the VSGAN and much more. I can also send you a link to my current dev version of Hybrid, which allows using VSGAN&Co more easily, main benefit to start is probably that you can look at the scripts Hybrid uses. "NVIDIA GTX 980Ti 6GB GDDR5" <- my condolences, trying to use VSGAN and other ml based filters will be a real pain. That said, if you just want to use VSGAN and create a portable version by yourself, try:
You could then use something like: Code:
# Imports import vapoursynth as vs import os import sys # getting Vapoursynth core core = vs.core # source: 'G:\TestClips&Co\test.avi' # current color space: YUV420P8, bit depth: 8, resolution: 640x352, fps: 25, color matrix: 470bg, yuv luminance scale: limited, scanorder: progressive # Loading G:\TestClips&Co\test.avi using LWLibavSource clip = core.lsmas.LWLibavSource(source="G:/TestClips&Co/test.avi", format="YUV420P8", stream_index=0, cache=0, prefer_hw=0) # adjusting color space from YUV420P8 to RGBS for vsVSGAN clip = core.resize.Bicubic(clip=clip, format=vs.RGBS, matrix_in_s="470bg", range_s="full") # resizing using VSGAN from vsgan import ESRGAN vsgan = ESRGAN(clip=clip,device="cuda") model = "F:/Hybrid/64bit/vsgan_models/2x_RealESRGAN_x2plus.pth" vsgan.load(model) vsgan.apply() # 1280x704 clip = vsgan.clip # adjusting output color from: RGBS to YUV420P8 for x264Model clip = core.resize.Bicubic(clip=clip, format=vs.YUV420P8, matrix_s="470bg", range_s="limited", dither_type="error_diffusion") # Output clip.set_output() Cu Selur |
19th May 2023, 01:28 | #10 | Link | |
So I think you need to start over and either install JUST python or JUST anaconda. |
19th May 2023, 13:54 | #11 | Link | |
Broadcast Encoder
I got rid of everything and I started over, trying to get it to work again. I wanna say a big fat thank you to everyone who came here and spent some time to help me. I don't wanna make you feel like you wasted time, because I actually appreciated the fact that you tried to give me some insights and help me, believe me, I did. On the other hand, I've been using Avisynth since June 2006 and when I saw the .onnx models being supported by mlrt_ncnn() in Avisynth, I have been shying away from VapourSynth and went back to Avisynth and got it to work within minutes (not every model, but still, some, but it might just be my GPU being too old for the most complex models). Anyway, thank you for everything, guys, I appreciated everything, so don't feel bad if I'm just gonna go back to Avisynth, but I guess it's just a way of keeping my habits the same... :') Last edited by FranceBB; 19th May 2023 at 13:56. |
28th October 2023, 15:45 | #12 | Link |
Sorry to resurrect this but I got a Win11 laptop at work with a RTX 3050 Ti (4Gb VRAM though so I might need tiling support) and want to try all the AI plugins, specially HolyWu's.
Do you recommend me to install vapoursynth or use portable version? basically on ease of use terms. Also does latest R65 work on Python 3.12? Also plan to install Python system-wide.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 28th October 2023 at 15:51. |
28th October 2023, 18:35 | #14 | Link |
I can do single image on AviSynth but in order to use the fancy ones on CUDA for video I require Vapoursynth (codeformer, basicvsrpp, colorization, inpainting, etc). I will use runway for generative probably.
I simply want to get the workflow done for presentation, and finally upgrade the system for real work.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
28th October 2023, 20:49 | #15 | Link |
@Dogway: send you a pm with my current dev version of Hybrid and all the addons for it, which includes a portable Vapoursynth (with pytorch&HolyWus plugins) which should get you started.
But be warned: 4GB VRAM really isn't much. |
29th October 2023, 13:25 | #16 | Link |
@Selur: Thanks a lot, I installed it without issues. I guess I don't need to install python alongside since it will be retrieved from the included python311.zip file?
And to add more flexibility I can add vapoursynth editor (VapourSynthEditor2 looks abandoned). For the time being I won't install R65 nor Python 3.12 just in case it breaks something. As long as I can show a single output frame I'm good. I only need it now to study the workflow and showcase for work/clients.
29th October 2023, 14:08 | #17 | Link |
Yes, the Vapoursynth-folder directly comes with a portable Python version.
Copying the R65-RC1 into the Vapoursynth folder and overwriting the R64version works fine here. Haven't tried if switching out Python 3.12 works, but I suspect it would cause issues. Cu Selur |
5th November 2023, 02:25 | #19 | Link |
Ok, the nightmare starts. Where am I supposed to drop the VSEditor content? Using VapourSynth_Editor-r19-mod-6.3, I tried in Hybrid root folder, opens but warns with wrong library and plugin paths which neither worked. Then dropped the editor into Hybrid\64\Vapoursynth, can't even open the editor with a "entry point procedure couldnĄt be found on the library symbolic link" error dialog.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 5th November 2023 at 02:28. |
5th November 2023, 06:45 | #20 | Link |
The error should also state 'Please set up the library search paths in settings.'
So,... a. copy/install VapourSynth Editor anywhere you want. b. Start it and go to "Edit->Settings->Path->VapourSnyth library search paths", select and add your 'Hybrid/64bit/Vapoursynth', then hit 'Apply' c. restart Vapoursynth Editor Note that Hybrid by default uses separate folders for the plugins, thus you need to explicitly load dependencies. Cu Selur |
