Old 31st May 2019, 14:43   #41  |  Link
ChaosKing
I can't check if it is a real dependency. Only that it is not a VS plugin.
Old 31st May 2019, 15:06   #42  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by ChaosKing View Post
I can't check if it is a real dependency. Only what it is not a VS plugin.
If you're really insane you could parse the package json and see which files belong to a plugin and simply exclude them. I don't recommend that you do this.
Myrsloik is offline   Reply With Quote
Old 31st May 2019, 15:12   #43  |  Link
ChaosKing
Hmm this would at least work for files that are in that package. The file is parsed and read anyway :P
Old 31st May 2019, 21:45   #44  |  Link
ChaosKing
Better? Comparison is at filename level, maybe I will add hash compare someday so what w2xc-abc.dll would be also recognized.
🤨 Notice - Probably a Plugin dependency (not a VS Plugin):
   libfftw3-3.dll	 [belongs to FFTW3 Library]
   libfftw3f-3.dll	 [belongs to FFTW3 Library]
   libmfxsw64.dll	 [belongs to DGMVCSourceVS]
   libRandom.dll
   svml_dispmd.dll	 [belongs to Waifu2x]
   w2xc.dll	 [belongs to Waifu2x]
   w2xc-abc.dll
Old 31st May 2019, 22:46   #45  |  Link
lansing
   libRandom.dll
   w2xc-abc.dll
Something like this?
 dependency files:
unidentify files:
   libRandom.dll
   w2xc-abc.dll
Old 31st May 2019, 23:37   #46  |  Link
ChaosKing
Checked Plugins: 118, Notices: 2, Errors: 1
🙂 Identified non-VapourSynth Plugins:
🤨 Unidentified DLLs (maybe also Plugin dependencies?):
   libRandom.dll
   w2xc-abc.dll
Maybe also list non DLL files, like avsmeter does?
Old 1st June 2019, 00:05   #47  |  Link
lansing
I don't know about that, because the VMAF filter has a model folder that has like 90 files inside, that's going to be a long list.
The diagnostic test is use to check when something goes wrong, and I don't think those files are going to matter.
Old 6th June 2019, 16:24   #48  |  Link
ChaosKing
I worked a bit on the dependency stuff.
Question: I know that for example that "MSVCP140.dll" is a "Visual C++ Redistributable" Runtime dll, but can I know from which Runtime it is? from 2015, 2017? Or replaces the 2017 dll the 2015 version?
🔥 Error 126 - A DLL dependency is probably missing:
   bilateralGPU.dll
   	 requires following dependencies (one of these should be missing):
   	 - opencv_core320.dll
   	 - opencv_cudaimgproc320.dll
   	 - VCRUNTIME140.dll
   	 - api-ms-win-crt-heap-l1-1-0.dll
   	 - api-ms-win-crt-runtime-l1-1-0.dll
   	 - api-ms-win-crt-math-l1-1-0.dll
   opencv_core320.dll
   	 - cudart64_80.dll
   	 - MSVCP140.dll
   	 - CONCRT140.dll
   	 - VCRUNTIME140.dll
   	 - api-ms-win-crt-stdio-l1-1-0.dll
   	 - api-ms-win-crt-string-l1-1-0.dll
   	 - api-ms-win-crt-convert-l1-1-0.dll
   	 - api-ms-win-crt-environment-l1-1-0.dll
   	 - api-ms-win-crt-time-l1-1-0.dll
   	 - api-ms-win-crt-filesystem-l1-1-0.dll
Old 6th June 2019, 16:53   #49  |  Link
Myrsloik
Myrsloik's Avatar
2019 replaces both 2017 and 2015.
Old 8th June 2019, 18:06   #50  |  Link
Dreamject
It does not work with portable versions. Imo it should detect vs like
If vapoursynth library in current folder, then apply updates to currentdir. Portable/usual mode has different folder strucrure
Dreamject is offline   Reply With Quote
Old 8th June 2019, 18:52   #51  |  Link
ChaosKing
It supports portable version currently only via a "vsrepogui.json" file. (You can set relative paths, but still need python in path)
Old 9th June 2019, 09:08   #52  |  Link
Dreamject
Okay... But what's wrong with autodetection in %cd%
Old 9th June 2019, 09:21   #53  |  Link
ChaosKing
Nothing wrong with it. I needed a custom path for Scripts, so I quickly implement it via a file. This way it's more universal and easier to test around for me. I will add autodetect maybe in the future.
Old 12th June 2019, 12:27   #54  |  Link
ChaosKing
New release https://github.com/theChaosCoder/VSR...leases/tag/0.7
(You need listpedeps if you also want to see the dependencies https://github.com/brechtsanders/pedeps)
Old 13th June 2019, 15:14   #55  |  Link
cyaoeu
Isn't the cat a copyrighted/trademarked character?
cyaoeu is offline   Reply With Quote
Old 13th June 2019, 15:44   #56  |  Link
ChaosKing
I have it from here https://flyclipart.com/art-pusheen-c...een-png-204717
CC BY-NC 4.0 Licence
✓ Free for personal use
✓ Attribution not required
✓ Unlimited download
Old 14th June 2019, 15:23   #57  |  Link
cyaoeu
Okay, cool.
Some real feedback, I'm pretty new to VS and this was really helpful when trying to find dependencies without having to go look on github (didn't try the normal VSRepo).
Some things that were a bit strange to me in the UI:
1. The height of each row is not fixed so it looks pretty ugly when scrolling with the text jumping around. Would probably look better to have all of them the same (maximum I guess) height.
2. The namespaces are links (or at least blue and underlined) but don't really do anything when clicked on.
3. There's a description when you click on a row but I would prefer if this was visible by default, that way you don't need to click on everything to see what it is.
Anyway these are nitpicky suggestions, I didn't have any real problems when using it.
Old 14th June 2019, 15:39   #58  |  Link
ChaosKing
1. Ok will change it
2. Yeah I forgot about it. I wanted to link them to the vsrepo json files on github, but I'm open for other suggestions.
3. I will look into it. It seems if you click on any row and then mark everything with STRG+A you can open every hidden row.
Old 9th July 2019, 01:34   #59  |  Link
ChaosKing
New release (see first page)
- Should start faster now (async plugin read on start)
- Should detect all possible VS installations now (for all and per user)
- Add some additional diagnostic information
- All rows have the same height now (better scrolling experience)
- Namespace links now opens its meta package on github
Old 9th July 2019, 08:59   #60  |  Link
felicialee
Hi, ChaosKing
I suggest you use it with caution.
I specifically contacted the platform, they said that this is a user-uploaded image, they can not guarantee copyright issues. Just like this, https://www.netclipart.com/isee/ibiJ...heen-birthday/, it is possible to complain directly.
felicialee is offline   Reply With Quote
