27th May 2005, 02:07 | #701 | Link |
李姗倩 Lǐ Shān Qiàn
Thanks as always
well, i got like 10 reports about some other troubles with this new build. i cannot reproduce the pb myself (it works ok for me), but i can sum up the feedback: (1) The installer complains 'ffdshow.ax' is missing, or "Error while registering ffdshow.ax" even if you try to install this version right after rebooting your OS. seeminly, this might happen when you uninstall the previous version before installing this version, and according to some reports, the workaround in that case is: first re-install a random old version, and then overwrite it by this version. Did anyone experience this problem? Or can anyone guess what is wrong? (2) Generally, i got a vague impression that this version works better on Win2K and a bit less reliable on WinXP--especially it installs but doesn't work on x64Edition. |
27th May 2005, 03:02 | #702 | Link |
XviD User
Loaded latest build on 3 XP machines with SP2 and not had any problems with the installer. I uninstalled the previous builds first.
The libmpeg2 build seems to work great so far but need to test MPEG2 a little more.
DFI NF4 SLI Expert | Opteron 165 CCBBE 0616 XPMW (9x325HTT=2.9Ghz) | 2x1GB G.Skill HZ (3-4-4-8-12-16-2T) | LG 62L DVD/CD | Geforce 7300GT | All SATA | Antec 650 Trio PSU | XP SP2 |
27th May 2005, 04:30 | #703 | Link |
msvcrt71.dll is a dependancy of ffdshow.ax and was not included in the installer. Some of the previous installers did include it which is why installing over an old version would work. Really people should have the file in they system32 folder though.
So previous builds worked ok on XP64? |
27th May 2005, 06:09 | #704 | Link |
李姗倩 Lǐ Shān Qiàn
Are you sure? I installed your ffdshow-20050510.exe into a newly created folder, and I got ffdshow.ax 1.0.1.1 dated 2005-05-23 04:04 UTC there. I believe this one is included in the package.
About 64-Bit Editions, I doubt it. It's very new and only a few use it. I think you can ignore it for now. |
27th May 2005, 06:53 | #705 | Link | |
ffdshow/AviSynth wrangler
np: Apollo 440 - Carrera Rapida (Theme From Rapid Racer) (Electro Glide In Blue) |
27th May 2005, 07:01 | #706 | Link |
About "Friday - early off":
One half of Germany - mainly southern and western federal states, which are more related to the catholic church, especially Bavaria - had a leisure holiday yesterday, and most people tried to expand it to a "long weekend" (Thu => Sun). Other federal states in northern and eastern Germany, which are more related to the protestantic church, have less leisure holidays and just a normal week of work. Isn't that "fair"?! But anyway, way too many people in Germany don't need to care about holidays, without a job. |
27th May 2005, 15:15 | #711 | Link |
Mr. Sandman
mirrored
27th May 2005, 16:24 | #714 | Link |
Got it.
(Sorry, just a small joke... ) __ And a queer thought, but who knows...: Because several people complained that H.264 videos look strange, because they left post-processing activated (which is obviously much more useful for MPEG-ASP video). Which way might be most useful for switching off PP on H.264 videos? Maybe auto-applied profiles depending on the codec? |
27th May 2005, 22:01 | #715 | Link |
VirtualDubMod plugin error
after installing latest ffdshow with vdub plug-in i get the following error upon exiting vdub. "VirtualDubMod.exe - Application Error: the instruction at ... referenced memory at ... memory could not be read. click ok to terminate the program."
both addresses are different every time it happens. you can reproduce that: load divx+ac3 avi and use video direct stream copy, ac3 -> mp3 (lame). i think i also got the same kind of error in zoomplayer while configuring customized playback to use ffdshow. though this one i couldn't reproduce later. |
27th May 2005, 22:20 | #717 | Link | |
4th June 2005, 17:21 | #718 | Link | |
5th June 2005, 04:25 | #719 | Link |
About SVQ3 in 20050527 :
my test MOV (Video:SVQ3/ Audio:AAC) http://pdl3.warnerbros.com/thematrix...nal_480_dl.zip IN FFDshow version : 20040312 : works absolutely perfect! all build in between : libavcodec.dll crash 20040418 to 20050527: works but frame rate doesn't resolve (2fps or something) Is it possible for you libavcodec gurus to "take" the SVQ3 code from 20040312 and somehow put it in the next FFDshow build? Later, TSR Last edited by TheShadowRunner; 5th June 2005 at 04:38. |
5th June 2005, 15:55 | #720 | Link | |
Pain and suffering
http://forum.doom9.org/showthread.ph...353#post664353
So hopefully celtic_druid can fix both TheShadowRunner's and our problem, and put a fresh new all working ffdshow build online! |
