2nd April 2016, 19:14 | #41 | Link | |
Professional Code Monkey
I'm going to test my changes and then make a pull request I guess.
29th July 2016, 19:31 | #44 | Link |
Here are compiled windows binaries.
30th July 2016, 23:27 | #46 | Link |
import vapoursynth as vs
import sys core = vs.get_core() clip = core.raws.Source("/dev/stdin") clip = core.fmtc.bitdepth (clip, bits=10) clip.set_output() enable_v210 = True with: ffmpeg -i C:\Users\Andy\Desktop\50i.avi -f yuv4mpegpipe - | "C:\Program Files (x86)\VapourSynth\core64\vspipe.exe" --y4m C:\Users\Andy\Desktop\rr.vpy - | C:\ffmpeg.exe -i - -c:v v210 C:\Users\Andy\Desktop\vv.mov doesn't work, giving error: Output #0, yuv4mpegpipe, to 'pipe:': Metadata: encoder : Lavf57.44.100 Stream #0:0: Video: wrapped_avframe, yuv422p, 1920x1080, q=2-31, 200 kb/s, 2 5 fps, 25 tbn, 25 tbc Metadata: encoder : Lavc57.51.100 wrapped_avframe Stream mapping: Stream #0:0 -> #0:0 (utvideo (native) -> wrapped_avframe (native)) Press [q] to stop, [?] for help Script evaluation failed: Python exception: raws: source does not exist. Traceback (most recent call last): File "src\cython\vapoursynth.pyx", line 1491, in vapoursynth.vpy_evaluateScrip t (src\cython\vapoursynth.c:26897) File "C:\Users\Andy\Desktop\rr.vpy", line 5, in <module> clip = core.raws.Source("/dev/stdin") File "src\cython\vapoursynth.pyx", line 1383, in vapoursynth.Function.__call__ (src\cython\vapoursynth.c:25204) vapoursynth.Error: raws: source does not exist. looks like /dev/stdin doesn't work. Last edited by kolak; 30th July 2016 at 23:34. |
30th July 2016, 23:55 | #48 | Link |
Yes, but been told it should work here also I've read it won't on Windows.
More issues: clip = core.raws.Source("C:\Users\Andy\Desktop\vv.raw", 1920, 1080, 30000, 1001, src_fmt='YUV422P10') gives strange error: Script evaluation failed: Python exception: (unicode error) 'unicodeescape' codec can't decode bytes in po sition 2-3: truncated \UXXXXXXXX escape (rr.vpy, line 4) Traceback (most recent call last): File "src\cython\vapoursynth.pyx", line 1490, in vapoursynth.vpy_evaluateScrip t (src\cython\vapoursynth.c:26883) File "C:\Users\Andy\Desktop\rr.vpy", line 4 clip = core.raws.Source("C:\Users\Andy\Desktop\vv.raw", 1920, 1080, 30000, 1 001, src_fmt='YUV422P10') ^ SyntaxError: (unicode error) 'unicodeescape' codec can't decode bytes in positio n 2-3: truncated \UXXXXXXXX escape Is this complaining about actual video data? |
31st July 2016, 01:19 | #50 | Link |
Yes, it needs the hack that treats the empty dash (-) as stdin, as is the usual convention.
In theory, you could run a pipe server and use names pipes as the ffmpeg ouput / vs input. I don't know of any command offhand that provides this. |
2nd August 2016, 12:56 | #58 | Link |
4th August 2016, 10:40 | #60 | Link |
I have a vague memory the code has to do it the windows api way. Using portable stuff won't work.
Or that it works often enough if you simply skip it on windows. That's what x264 seems to do anyway.
VapourSynth - proving that scripting languages and video processing isn't dead yet Last edited by Myrsloik; 4th August 2016 at 10:57. |
