#81 | Link |
Bonus: degrainTR 5-6
148.04684 47280ms degrainTR=6 postFFT=3 postSigma=4 148.01166 42710ms degrainTR=5 postFFT=3 postSigma=4 147.94945 41310ms degrainTR=5 postFFT=3 postSigma=3 147.78264 37160ms degrainTR=6 postFFT=1 postSigma=4 147.7377 36780ms degrainTR=6 postFFT=1 postSigma=3 147.73164 30890ms degrainTR=5 postFFT=1 postSigma=4 147.67194 30840ms degrainTR=5 postFFT=1 postSigma=3 147.44595 30810ms degrainTR=5 postFFT=1 postSigma=2 144.64229 27510ms degrainTR=5 postFFT=0 postSigma=1 LOG (x64, 0.9.8 beta) Code:
Output 1: name ssim type FLOAT goal MAX unit round 0 Output 2: name time type TIME goal MIN unit ms round 10 Found following optimizable parameters: # optimize degrainTR = _n_ | 5..6 | degrainTR # optimize postFFT = _n_ | 0,1,3 | postFFT # optimize postSigma = _n_ | 1..4 | postSigma found 3 parameters to optimize Running SPEA2 * 1 / 30 : 145.00519 56410ms degrainTR=6 postFFT=0 postSigma=1 + 2 / 30 : 145.00519 55430ms degrainTR=6 postFFT=0 postSigma=3 + 3 / 30 : 144.64229 28650ms degrainTR=5 postFFT=0 postSigma=2 4 / 30 : 144.64229 28710ms degrainTR=5 postFFT=0 postSigma=1 * 5 / 30 : 147.81573 42460ms degrainTR=5 postFFT=3 postSigma=2 + 6 / 30 : 146.67145 31380ms degrainTR=5 postFFT=1 postSigma=1 7 / 30 : 145.00519 56330ms degrainTR=6 postFFT=0 postSigma=4 + 8 / 30 : 144.64229 28330ms degrainTR=5 postFFT=0 postSigma=2 Parameter sensitivity estimation with 64 result combinations -> degrainTR 0,542 postFFT 1,546 postSigma 0,990 Mutating 2 params by 22,0 % + 9 / 30 : 147.78264 37160ms degrainTR=6 postFFT=1 postSigma=4 + 10 / 30 : 147.44595 30810ms degrainTR=5 postFFT=1 postSigma=2 11 / 30 : 144.64229 28410ms degrainTR=5 postFFT=0 postSigma=4 12 / 30 : 145.00519 53030ms degrainTR=6 postFFT=0 postSigma=1 13 / 30 : 147.45505 42150ms degrainTR=5 postFFT=3 postSigma=1 14 / 30 : 146.67145 30820ms degrainTR=5 postFFT=1 postSigma=1 15 / 30 : 146.8749 36550ms degrainTR=6 postFFT=1 postSigma=1 + 16 / 30 : 144.64229 27580ms degrainTR=5 postFFT=0 postSigma=2 Parameter sensitivity estimation with 256 result combinations -> degrainTR 0,556 postFFT 1,403 postSigma 0,968 Mutating 1 params by 14,0 % mutation failed 1000 times, increasing mutation count to 2 + 17 / 30 : 144.64229 27510ms degrainTR=5 postFFT=0 postSigma=1 18 / 30 : 145.00519 52870ms degrainTR=6 postFFT=0 postSigma=2 19 / 30 : 147.81573 42490ms degrainTR=5 postFFT=3 postSigma=2 20 / 30 : 144.64229 27880ms degrainTR=5 postFFT=0 postSigma=3 + 21 / 30 : 147.7377 36780ms degrainTR=6 postFFT=1 postSigma=3 22 / 30 : 147.54588 36850ms degrainTR=6 postFFT=1 postSigma=2 + 23 / 30 : 147.67194 30840ms degrainTR=5 postFFT=1 postSigma=3 24 / 30 : 147.57674 48110ms degrainTR=6 postFFT=3 postSigma=1 Parameter sensitivity estimation with 256 result combinations -> degrainTR 0,559 postFFT 1,282 postSigma 1,054 Mutating 1 params by 6,0 % mutation failed 1000 times, increasing mutation count to 2 mutation failed 1000 times, increasing mutation count to 2 mutation failed 1000 times, increasing mutation count to 2 mutation failed 2000 times, increasing mutation count to 3 25 / 30 : 145.00519 53010ms degrainTR=6 postFFT=0 postSigma=3 + 26 / 30 : 147.73164 30890ms degrainTR=5 postFFT=1 postSigma=4 * 27 / 30 : 147.94945 41310ms degrainTR=5 postFFT=3 postSigma=3 28 / 30 : 147.88573 46830ms degrainTR=6 postFFT=3 postSigma=2 * 29 / 30 : 148.01166 42710ms degrainTR=5 postFFT=3 postSigma=4 30 / 30 : 147.99655 47120ms degrainTR=6 postFFT=3 postSigma=3 * 31 / 30 : 148.04684 47280ms degrainTR=6 postFFT=3 postSigma=4 32 / 30 : 145.00519 53230ms degrainTR=6 postFFT=0 postSigma=4 Parameter sensitivity estimation with 256 result combinations -> degrainTR 0,566 postFFT 1,161 postSigma 1,152 Total execution time: 1339735ms Pareto front: 148.04684 47280ms degrainTR=6 postFFT=3 postSigma=4 148.01166 42710ms degrainTR=5 postFFT=3 postSigma=4 147.94945 41310ms degrainTR=5 postFFT=3 postSigma=3 147.78264 37160ms degrainTR=6 postFFT=1 postSigma=4 147.7377 36780ms degrainTR=6 postFFT=1 postSigma=3 147.73164 30890ms degrainTR=5 postFFT=1 postSigma=4 147.67194 30840ms degrainTR=5 postFFT=1 postSigma=3 147.44595 30810ms degrainTR=5 postFFT=1 postSigma=2 144.64229 27510ms degrainTR=5 postFFT=0 postSigma=1 Running SPEA2 ...
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository Last edited by ChaosKing; 4th November 2018 at 02:19. |
#83 | Link |
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository |
#84 | Link |
Now I tested 100 frames from tears of steel, this scene https://www.youtube.com/watch?v=R6Ml...youtu.be&t=271
And here I noticed also some halos. You can see it very good on his hair in #2 http://screenshotcomparison.com/comparison/123735/ My script Code:
ffms2("TearsOfSteelFull12min_1080p_24fps_27qp_1474kbps_GPSNR_42.29_HM11.mkv").ConvertBits(8).bicubicresize(880,500).trim(6460,6560) source = last last=source.AddGrain(40, 0, 0, seed=2) degrainTR = 5 # optimize degrainTR = _n_ | 1..5 | degrainTR postFFT = 3 # optimize postFFT = _n_ | 0,1,3 | postFFT postSigma = 1 # optimize postSigma = _n_ | 1..4 | postSigma denoised = TemporalDegrain2(degrainTR=degrainTR, postFFT=postFFT, postSigma=postSigma) # no Prefetch, i forgot to add it :) - Evaluate mode still shows version 0.9.8 instead of 0.9.9 - Worst result is still wrong in 0.9.9 and the visualisation also I guess (96.75 value is cut off) Code:
AvisynthOptimizer v0.9.8-beta Arguments mode = evaluate autorefresh = true Running evaluation for log(s) .\avs_version (2018-11-04 10-10-30) optimize spea2 pop-8 mutcount-60%-1 mutamount-0.3-0.01 cross-0.1-20 iters-70 run-01.log Using these settings: ARGUMENT DESCRIPTION VALUE -vismode visualization mode single -scripts write scripts none -globalpareto show series pareto true -autorefresh autorefresh true -highlight highlight latest 10 -multipareto show multiple pareto fronts 0 (OFF) -top zoom into top x% results 20 -groupby group by parameter (OFF) -maxgroups group by max groups N/A -groupmin group by min value N/A -groupmax group by max value N/A -animation animation iterations per frame 0 (OFF) Reading log file .\avs_version (2018-11-04 10-10-30) optimize spea2 pop-8 mutcount-60%-1 mutamount-0.3-0.01 cross-0.1-20 iters-70 run-01.log Single run results: 64 Series results: 0 Run 1 best: 99.42768 51190 degrainTR=5 postFFT=3 postSigma=1 Best result: 99.42768 Worst result: 99.42768 <----- NOPE! Pareto front: 99.42768 51190 degrainTR=5 postFFT=3 postSigma=1 99.42644 44710 degrainTR=4 postFFT=3 postSigma=1 99.3991 38630 degrainTR=3 postFFT=3 postSigma=1 99.39909 38140 degrainTR=3 postFFT=3 postSigma=1 99.37821 37100 degrainTR=5 postFFT=1 postSigma=1 99.35609 30730 degrainTR=4 postFFT=1 postSigma=2 99.3523 30310 degrainTR=4 postFFT=1 postSigma=1 99.34066 24040 degrainTR=3 postFFT=1 postSigma=2 99.26441 17570 degrainTR=2 postFFT=1 postSigma=2 99.15682 17560 degrainTR=2 postFFT=1 postSigma=4 99.067345 17490 degrainTR=2 postFFT=1 postSigma=1 99.05565 11640 degrainTR=1 postFFT=1 postSigma=4 96.75158 8700 degrainTR=1 postFFT=0 postSigma=2 ![]() Code:
98.24987 14380 degrainTR=2 postFFT=0 postSigma=3 99.31801 31720 degrainTR=2 postFFT=3 postSigma=4 99.34313 32060 degrainTR=2 postFFT=3 postSigma=2 99.3523 30310 degrainTR=4 postFFT=1 postSigma=1 96.75158 8700 degrainTR=1 postFFT=0 postSigma=2 99.39007 44140 degrainTR=4 postFFT=3 postSigma=2 96.75158 8720 degrainTR=1 postFFT=0 postSigma=3 98.24987 14580 degrainTR=2 postFFT=0 postSigma=4 98.72428 21350 degrainTR=3 postFFT=0 postSigma=3 99.052536 11670 degrainTR=1 postFFT=1 postSigma=3 99.02302 25530 degrainTR=1 postFFT=3 postSigma=2 99.05565 11640 degrainTR=1 postFFT=1 postSigma=4 98.72428 21600 degrainTR=3 postFFT=0 postSigma=4 98.12291 11930 degrainTR=1 postFFT=1 postSigma=1 99.05177 34090 degrainTR=5 postFFT=0 postSigma=1 99.15682 17560 degrainTR=2 postFFT=1 postSigma=4 96.75158 8820 degrainTR=1 postFFT=0 postSigma=1 98.878456 12010 degrainTR=1 postFFT=1 postSigma=2 99.28696 32500 degrainTR=2 postFFT=3 postSigma=1 99.24217 17770 degrainTR=2 postFFT=1 postSigma=3 99.37821 37100 degrainTR=5 postFFT=1 postSigma=1 96.75158 8750 degrainTR=1 postFFT=0 postSigma=4 98.94025 27930 degrainTR=4 postFFT=0 postSigma=1 98.24987 14310 degrainTR=2 postFFT=0 postSigma=2 99.27137 24320 degrainTR=3 postFFT=1 postSigma=3 99.352585 36270 degrainTR=5 postFFT=1 postSigma=2 98.72428 21830 degrainTR=3 postFFT=0 postSigma=2 99.42768 51190 degrainTR=5 postFFT=3 postSigma=1 99.188416 26020 degrainTR=1 postFFT=3 postSigma=4 99.35609 30730 degrainTR=4 postFFT=1 postSigma=2 99.37805 51230 degrainTR=5 postFFT=3 postSigma=2 99.14046 25910 degrainTR=1 postFFT=3 postSigma=3 99.2798 24180 degrainTR=3 postFFT=1 postSigma=1 99.15887 24290 degrainTR=3 postFFT=1 postSigma=4 99.34593 44000 degrainTR=4 postFFT=3 postSigma=3 99.42644 44710 degrainTR=4 postFFT=3 postSigma=1 99.05177 33440 degrainTR=5 postFFT=0 postSigma=2 98.72428 21520 degrainTR=3 postFFT=0 postSigma=1 99.38929 38540 degrainTR=3 postFFT=3 postSigma=2 99.34066 24040 degrainTR=3 postFFT=1 postSigma=2 99.39909 38140 degrainTR=3 postFFT=3 postSigma=1 98.94025 28150 degrainTR=4 postFFT=0 postSigma=2 99.35622 38870 degrainTR=3 postFFT=3 postSigma=3 98.24987 14870 degrainTR=2 postFFT=0 postSigma=1 99.32733 51160 degrainTR=5 postFFT=3 postSigma=3 98.688225 25490 degrainTR=1 postFFT=3 postSigma=1 99.30322 44120 degrainTR=4 postFFT=3 postSigma=4 99.26441 17570 degrainTR=2 postFFT=1 postSigma=2 98.94025 27280 degrainTR=4 postFFT=0 postSigma=4 99.32066 38310 degrainTR=3 postFFT=3 postSigma=4 99.067345 17490 degrainTR=2 postFFT=1 postSigma=1 99.26495 30370 degrainTR=4 postFFT=1 postSigma=3 99.280716 51640 degrainTR=5 postFFT=3 postSigma=4 99.24911 36540 degrainTR=5 postFFT=1 postSigma=3 99.1392 30790 degrainTR=4 postFFT=1 postSigma=4 99.33777 31310 degrainTR=2 postFFT=3 postSigma=3 99.05177 33620 degrainTR=5 postFFT=0 postSigma=3 99.115715 36940 degrainTR=5 postFFT=1 postSigma=4 99.05177 33770 degrainTR=5 postFFT=0 postSigma=4 98.94025 27360 degrainTR=4 postFFT=0 postSigma=3 98.12291 11790 degrainTR=1 postFFT=1 postSigma=1 99.15887 24470 degrainTR=3 postFFT=1 postSigma=4 98.94025 28210 degrainTR=4 postFFT=0 postSigma=2 99.3991 38630 degrainTR=3 postFFT=3 postSigma=1
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository Last edited by ChaosKing; 4th November 2018 at 11:07. |
#85 | Link | |
Acid fr0g
![]() To clear things up, I am now using AVSMeter64 to get script results with no encoder around. @ChaosKing to answer you about KNLMeansCL performance, I run a simple KNLMeansCL() on 1080p source: Code:
AVSMeter64.exe sacrificio_KNLMeansCL.avs AVSMeter 2.8.6 (x64) - Copyright (c) 2012-2018, Groucho2004 AviSynth+ 0.1 (r2728, MT, x86_64) (0.1.0.0) Number of frames: 1750 Length (hh:mm:ss.ms): 00:01:12.990 Frame width: 1920 Frame height: 1032 Framerate: 23.976 (24000/1001) Colorspace: YV12 Frames processed: 1750 (0 - 1749) FPS (min | max | average): 2.001 | 17.93 | 12.41 Process memory usage (max): 198 MiB Thread count: 24 CPU usage (average): 9.6% Time (elapsed): 00:02:21.065
@turment on Telegram Last edited by tormento; 4th November 2018 at 11:56. |
#86 | Link |
tears of steel 1080p x64 test:
#0.82fps TemporalDegrain2(degrainTR=3, postFFT=3, postSigma=1) #4fps TemporalDegrain2(degrainTR=3, postFFT=3, postSigma=1, fftthreads=8) Prefetch(8) I'm testing the script performance, so I don't feed to any encoder.
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository Last edited by ChaosKing; 4th November 2018 at 11:54. |
#87 | Link |
Acid fr0g
Please try these settings to mantain some uniformity.
EDIT: Code:
#4fps TemporalDegrain2(degrainTR=3, postFFT=3, postSigma=1, fftthreads=8) Prefetch(8) 1.86 fps here on i7-2600k + GTX 760. I can't really see one order of magnitude.
@turment on Telegram Last edited by tormento; 4th November 2018 at 12:10. |
#88 | Link |
All with Prefetch(8). Now tested with avsmeter64, 300 frames, 1080p source - ffms2("TearsOfSteelFull12min_1080p_24fps_27qp_1474kbps_GPSNR_42.29_HM11.mkv").trim(500,500+300)
AviSynth+ r2728, all plugins updated Ryzen 1700 @ 3.7ghz, Rx480, 16gb ram 3000mhz Code:
TemporalDegrain2(degrainTR=4,postFFT=0,postSigma=3,postDither=0) #5.15 TemporalDegrain2(degrainTR=4,postFFT=0,postSigma=3,postDither=0, fftthreads=8) #5.5 TemporalDegrain2(degrainTR=4,postFFT=3,postSigma=3,postDither=0) # 2.42 TemporalDegrain2(degrainTR=4,postFFT=3,postSigma=3,postDither=0, fftthreads=8) # 3.52 TemporalDegrain2(degrainTR=4,postFFT=4,postSigma=3,postDither=0) #4.23 TemporalDegrain2(degrainTR=4,postFFT=4,postSigma=3,postDither=0, fftthreads=8) #4.62
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository Last edited by ChaosKing; 4th November 2018 at 13:05. |
#89 | Link | |||
![]() Last edited by ErazorTT; 4th November 2018 at 13:33. |
#90 | Link | ||
Acid fr0g
@turment on Telegram |
#92 | Link | |
Thats a good suggestion!
EDIT: Hm however fft3dfilter does not work with this version of fftw lib, it produces access violations... Last edited by ErazorTT; 4th November 2018 at 19:13. |
#93 | Link | |||
![]() Quote:
I wasn't able to reproduce the problem with the worst result, I also noticed that in your log the Series has zero results, probably has something to do with that. Code:
Single run results: 64 Series results: 0 You also might try the latest version which has one path related problem fixed. Quote:
#95 | Link | |
I have tracked down the Series results being 0, will be fixed in the next version. And more on topic: it might be a good idea to test if there is any difference in quality when running in multithreaded mode versus single threaded. There shouldn't be, but it doesn't hurt to make sure... |
#96 | Link | |
See here: https://forum.doom9.org/showthread.p...82#post1857182 |
#97 | Link | |
Acid fr0g
It could be nice to have a new compiled version from Pinterf, who already dealt with FFT3DFilter or (my dream) a FFT3DCL from Khanattila
#98 | Link |
FFT is used in two instances in the script. You can already change both to using FFT3DGPU via function arguments. One by changing limitFFT to 2 and the other by changing postFFT to 2. PostFFT also has the options 3 (dfttest) and 4 (meansCL) which do not make sense for limitFFT.
Yeah me too but I just have an integrated Intel GPU. Quality wise I would expect FFT3DGPU to behave very close to FFT3Dfilter. And especially for limitFFT there is will be no difference in quality, though perhaps very significantly in speed. That said, FFT3DGPU has not seen any new version in ages while there have been updates to FFT3Dfilter. Last edited by ErazorTT; 18th November 2018 at 09:47. |
#99 | Link |
Acid fr0g
Ok... I did not notice that. Now that you point it, I can see it in the script code. Now I only need to find a FFT3DGPU x64...
EDIT: Here. A real pity. Just imagine to have a FFT3DCL...
@turment on Telegram Last edited by tormento; 18th November 2018 at 09:53. |
#100 | Link |
Acid fr0g
TemporalDegrain2(degrainTR=4,postFFT=0,postSigma=3,postDither=-1,limitFFT=1) 1.70 fps
TemporalDegrain2(degrainTR=4,postFFT=0,postSigma=3,postDither=-1,limitFFT=2) 1.66 fps TemporalDegrain2(degrainTR=4,postFFT=4,postSigma=3,postDither=-1,limitFFT=1) 1.12 fps TemporalDegrain2(degrainTR=4,postFFT=4,postSigma=3,postDither=-1,limitFFT=2) 1.03 fps So there should be a bottleneck somewhere...
@turment on Telegram Last edited by tormento; 18th November 2018 at 11:24. |
