Old 23rd March 2022, 18:41   #141  |  Link
lvqcl
8-bit video: SSE4.1 vs AVX2 vs AVX-512 (on 8C/16T Rocket Lake) - https://code.videolan.org/videolan/d..._requests/1301
lvqcl is offline   Reply With Quote
Old 23rd March 2022, 18:56   #142  |  Link
Beelzebubu
Do we know how much speedup AVX512 provided? We've not seen it to be particularly useful in encoder performance, so it'd be interesting if it helps more on the decode side.
dav1d uses the icelake subset (AWS: m6i/c6i, or: F, CD, VL, DQ, BW, IFMA, VBMI, VBMI2, VPOPCNTDQ, BITALG, VNNI, VPCLMULQDQ, GFNI, VAES), not skylake subset (AWS: m5*/c5*, or: F, CD, VL, DQ, BW). Icelake's performance of AVX512 instructions is in general much better than Skylake's, but the wider instruction subset also allows for certain additional code optimizations.
Extreme example of the latter: 8-bit film grain is more than 3x as fast with AVX512 compared to AVX2.
Beelzebubu is offline   Reply With Quote
Old 23rd March 2022, 20:05   #143  |  Link
benwaggoner
Wow, those are some very impressive speedups with AVX512! The new instructions are making at least as much of a difference than the "AVX2, but 2x wider" instructions.
Of course, Icelake CPUs don't have that much market share yet, but these kinds of speedups are quite promising in the long term for software decoding.
Ben Waggoner
My Compression Book
Old 24th March 2022, 12:21   #144  |  Link
Beelzebubu
... and software encoding!
Old 15th February 2023, 19:53   #145  |  Link
Spyros
dav1d 1.1.0 'Arctic Peregrine Falcon'
dav1d 1.1.0 was released yesterday. (Tag)
Changes for 1.1.0 'Arctic Peregrine Falcon':
1.1.0 is an important release of dav1d, fixing numerous bugs, and adding SIMD
  • New function dav1d_get_frame_delay to query the decoder frame delay
  • Numerous fixes for strict conformity to the specs and samples
  • NEON and AVX-512 misc fixes and improvements
  • Partial AVX2 12bpc transform implementations
  • AVX-512 high bit-depth cdef_filter, loopfilter, itx
  • NEON z1/z3 optimization for 8bpc
  • SSSE3 z1 optimization for 8bpc
"From VideoLAN with love"
Spyros is offline   Reply With Quote
Old 3rd May 2023, 07:43   #146  |  Link
hajj_3
Changes for 1.2.0 'Arctic Peregrine Falcon':
- Improvements on attachments of props and T.35 entries on output pictures
- NEON z1/z3 high bit-depth optimizations and improvements for 8bpc
- SSSE3 z2/z3 8bpc and SSSE3 z1/z3 high bit-depth optimziations
- refmvs.save_tmvs optimizations in SSSE3/AVX2/AVX-512
- AVX-512 optimizations for high bit-depth itx (16x64, 32x64, 64x16, 64x32, 64x64)
- AVX2 optimizations for 12bpc for 16x32, 32x16, 32x32 itx
Old 4th June 2023, 21:57   #147  |  Link
hajj_3
Changes for 1.2.1 'Arctic Peregrine Falcon':
- Fix a threading race on task_thread.init_done
- NEON z2 8bpc and high bit-depth optimizations
- SSSE3 z2 high bit-depth optimziations
- Fix a desynced luma/chroma planes issue with Film Grain
- Reduce memory consumption
- Improve dav1d_parse_sequence_header() speed
- OBU: Improve header parsing and fix potential overflows
- OBU: Improve ITU-T T.35 parsing speed
- Misc buildsystems, CI and headers fixes
Old 5th October 2023, 20:54   #148  |  Link
Barough
Barough's Avatar
Changes for 1.3.0 'Tundra Peregrine Falcon (Calidus)':
1.3.0 is a medium release of dav1d, focus on new APIs and memory usage reduction.
- Reduce memory usage in numerous places
- ABI break in Dav1dSequenceHeader, Dav1dFrameHeader, Dav1dContentLightLevel structures
- new API function to check the API version: dav1d_version_api()
- Rewrite of the SGR functions for ARM64 to be faster
- NEON implemetation of save_tmvs for ARM32 and ARM64
- x86 palette DSP for pal_idx_finish function
Do NOT re-post any of my Mediafire links. Download & re-host the content(s) if you want to share it somewhere else.
Old 5th October 2023, 21:02   #149  |  Link
Barough
Barough's Avatar
dav1d v1.3.0-3-g47107e3
Built on October 05, 2023, GCC 13.2.0
https://code.videolan.org/videolan/dav1d
DL :
Old 14th February 2024, 17:21   #150  |  Link
hajj_3
Changes for 1.4.0 'Road Runner':
1.4.0 is a medium release of dav1d, focusing on new architecture support and optimizations
- AVX-512 optimizations for z1, z2, z3 in 8bit and high-bit depth
- New architecture supported: loongarch
- Loongarch optimizations for 8bit
- New architecture supported: RISC-V
- RISC-V optimizations for itx
- Misc improvements in threading and in reducing binary size
- Fix potential integer overflow with extremely large frame sizes
Old 14th February 2024, 20:19   #151  |  Link
benwaggoner
RISC-V is interesting. It's starting to go into a lot of embedded things. License free (unlike ARM) and a very elegant architecture.
Ben Waggoner
My Compression Book
Old 9th March 2024, 17:41   #152  |  Link
hajj_3
v1.4.1 'Road Runner':
- Optimizations for 6tap filters for NEON (ARM)
- More RISC-V optimizations for itx (4x8, 8x4, 4x16, 16x4, 8x16, 16x8)
- Reduction of binary size on ARM64, ARM32 and RISC-V
- Fix out-of-bounds read in 8bpc SSE2/SSSE3 wiener_filter
- Msac optimizations
Old 20th April 2024, 21:22   #153  |  Link
dapperdan
dav1d pushed as part of a Google update going out to Android 12+
https://twitter.com/videolan/status/1781025929659392360
Apps will still use the Google developed alternative libgav1 unless they opt in though.
dapperdan is offline   Reply With Quote
Old 22nd April 2024, 16:28   #154  |  Link
Beelzebubu
See also: https://www.linkedin.com/feed/update...5577493544960/
"Apps need to opt into dav1d to benefit for now yet soon it will become the default av1 software decoder. "
Old 24th April 2024, 20:02   #155  |  Link
benwaggoner
The odds of Apple shipping someone else's precompiled binary in any of their OSes is very low these days. For security, portability, and optimization reasons.
They may leverage dav1d source code, but with their own tweaks and compile.
Ben Waggoner
My Compression Book
Old 24th April 2024, 20:47   #156  |  Link
Ritsuka
Apple has been shipping dav1d for years. The arm64 version is compiled with pointer authentication codes enabled.
Ritsuka is offline   Reply With Quote
Old 24th April 2024, 21:27   #157  |  Link
nevcairiel
Why would anyone with a serious distribution ever ship someone elses binary for an open-source project, instead of just compiling it for your target? Am I missing context for this comment?
Obviously they compile their own. As does Google for Android. And Microsoft for Windows.
Old 21st May 2024, 21:57   #158  |  Link
LigH
LigH's Avatar
dav1d 1.4.1-66-g3623543 (MSYS2; MinGW32 / MinGW64: GCC 14.1.0)
New German Gleitz board
Old 25th May 2024, 19:31   #159  |  Link
hajj_3
Changes for 1.4.2 'Road Runner':
1.4.2 is a small release of dav1d, improving notably ARM, AVX-512 and PowerPC
- AVX2 optimizations for 8-tap and new variants for 6-tap
- AVX-512 optimizations for 8-tap and new variants for 6-tap
- Improve entropy decoding on ARM64
- New ARM64 optimizations for convolutions based on DotProd extension
- New ARM64 optimizations for convolutions based on i8mm extension
- New ARM64 optimizations for subpel and prep filters for i8mm
- Misc improvements on existing ARM64 optimizations, notably for put/prep
- New PowerPC9 optimizations for loopfilter
- Support for macOS kperf API for benchmarking
Old 26th May 2024, 14:01   #160  |  Link
Beelzebubu
The 6-tap optimizations for AVX2/512 were inspired by an earlier patch-set (provided by someone from Arm) doing the same on arm platforms. On both Arm (included in the previous release already) and x86 (in this release), on affected sequences (particularly these encoded using faster presets in encoders, which is what you'd find on Youtube etc.) this can provide a ~10% overall performance improvement. Pretty spectacular at this stage of dav1d's life cycle.
