Old 6th June 2024, 11:48   #25261  |  Link
nevcairiel
Originally Posted by Blight View Post
Nev:
Any chance of adding an interface so I can assign a user-agent and referrer strings or possibly just a formatting option in the URL specified?
For example "https://www.somesite.org/stream|user-agent|referrer" ?
I've added a new interface for the next version of LAV to explicitly specify the user agent and referer when opening an URL.
I didn't particularly like parsing it out of a string, so dedicated function it is.
https://github.com/Nevcairiel/LAVFil...rceFilterLAV.h
It should be exposed on the LAVSplitterSource filter, just like IFileSourceFilter
Old 7th June 2024, 12:51   #25262  |  Link
Blight
Software Developer
Blight's Avatar
Very cool, I'll try it out once the new version comes out.
Just a quick question, when is the best time to set the referrer/user-agent values, before assigning the URL? before running the graph?
Yaron Gur
Zoom Player . Lead Developer
Blight is offline   Reply With Quote
Old 7th June 2024, 17:25   #25263  |  Link
Prinz
According to build log on https://files.1f0.de/lavf/nightly/ , this change is already included in the lasted nightly build: LAVFilters-0.79.2-9.exe
So you should be able to test it out already.
Prinz is offline   Reply With Quote
Old 7th June 2024, 18:20   #25264  |  Link
lvqcl
lvqcl is offline   Reply With Quote
Old 7th June 2024, 21:48   #25265  |  Link
nevcairiel
The interface has you pass it in together with the URL you open, so that question doesn't even apply.
The function _replaces_ the Load function from IFileSourceFilter, so you just call this one if you want to specify this detail.
Old 8th June 2024, 19:07   #25266  |  Link
Siso
Soul Seeker
Siso's Avatar
There is a problem with subtitle workshop latest versions with lav filters LAVFilters-0.79.2-5, LAVFilters-0.79.2-6 and LAVFilters-0.79.2-9. I'm attaching a shot of the error. Version LAVFilters-0.79.2-3 works fine without the error. The error happens when I open mkv files with external srt subtitles.
Old 17th June 2024, 21:16   #25267  |  Link
nevcairiel
This should hopefully be resolved in the next build.
Old 18th June 2024, 12:31   #25268  |  Link
Siso
Soul Seeker
Siso's Avatar
Thank you. It is working properly.
