19th June 2021, 14:43 | #19161 | Link | |
Grumpy Old Man.
No prob's here, mate....maybe you could overwrite the x265.exe, with one from a previous build. OR, from here (take your pick) http://msystem.waw.pl/x265/
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 19th June 2021 at 14:46. |
19th June 2021, 23:20 | #19162 | Link | |
French Love
Rather here because it is possible that it also interests other people than me. I would like to have the procedure to gain some fps because for the moment the budget for a Ryzen is not there. I actually have 3 non-OC PCs An Intel i7 3930k An Intel E6700 An AMD 64 X2
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial Demo for MVC Player Free: Trailer 3D 3DBD's Free - v0.0.0.0005.exe Old Programing free for all. Last edited by frencher; 19th June 2021 at 23:22. |
20th June 2021, 01:47 | #19163 | Link | |
Grumpy Old Man.
So the next and most important thing is, are these on a network ?? It doesn't need to be anything special, and I don't think wireless works (I could be wrong, I've never tried it). Can't use DE on other PC's without them being connected. And you're correct, there's NO tutorials around, the one that Atak posted many years ago isn't available anywhere, any more, and it was pretty basic, and would now be very out dated. It would be great for all concerned, if Atak produced another more current & detailed, setup & usage video. Hint, hint.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) |
20th June 2021, 08:44 | #19164 | Link |
Ofcourse wireless works. Even old 54 Mbps (pre-N) will be more than enough for slow pcs.
20th June 2021, 09:57 | #19165 | Link |
Grumpy Old Man.
Thanks for confirming that, like I said I've never tried it.
20th June 2021, 11:31 | #19166 | Link | ||
French Love
I have a fairly good speed, but I intend to use a much faster Devolo 2400 CPL later. Of course a video would be welcome, by the way I just subscribed to the Atak_Snajpera youtube channel
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial Demo for MVC Player Free: Trailer 3D 3DBD's Free - v0.0.0.0005.exe Old Programing free for all. Last edited by frencher; 20th June 2021 at 11:45. |
20th June 2021, 12:07 | #19167 | Link | |
Let's say you have 50 Mbps 4k@24fps movie and 3 PCs in DE mode Each PC during encoding achieves 4 fps. This means that each PC will be downloading data from HOST PC @~8 Mbps (50Mbps/24fps*4fps). In this scenario three PCs will consume 24Mbps of wireless bandwidth. Ofcourse you have to also include encoded data which is being sent back to HOST PC so overall network usage will be higher. It all depends from bitrate used in encoded file.
20th June 2021, 12:30 | #19168 | Link | |
Grumpy Old Man.
20th June 2021, 12:59 | #19169 | Link | |
Grumpy Old Man.
OK, well to start with you'd need RipBot on all machines. So if you want to use all of them, you need to have one that you use as the client (where you do the encoding jobs), and the other 2 can be the server's (helpers, if you will), you just need to enable Distributed Encoding, apply the appropriate IP address. Say your Client pc (3930K) was 192.168.1.1, and the other pc's were 192.168.1.2, and so on. Don't forget to click APPLY once done. Left side column, #1 & 2 are the Client's IP settings #3 & 4 are say the 6700's IP settings #5 & 6 are the AMD's IP settings. And you will need to do simliar on the other PC's. (Apparently not, see Atak's comment below) So once that's done you need to test, and have say the 6700 with RipBot open, and start a job on the 3930K, and once it opens the Encoding Client window, it will prepare the encoding, and once it starts, it should start encoding on all PC's. That should work, it's harder to describe things sometimes, than doing them.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 20th June 2021 at 13:39. Reason: info from Atak |
20th June 2021, 13:30 | #19170 | Link | |
20th June 2021, 13:34 | #19171 | Link |
Grumpy Old Man.
Well, there's something I didn't know
Thanks for the info.......
20th June 2021, 16:02 | #19172 | Link |
French Love
My E6700 OS is Windows 7 x86 no x64
And require Avisynth+ for EncodingServer.exe It's possible to upgade Win7 Pro x86 directly to Win10 x64 ?
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial Demo for MVC Player Free: Trailer 3D 3DBD's Free - v0.0.0.0005.exe Old Programing free for all. |
20th June 2021, 16:05 | #19173 | Link | |
French Love
20th June 2021, 16:43 | #19174 | Link | |
Athlon x2 + E6700 will give you at best extra 0.5 fps. Also keep in mind that encoding 4k footage will consume 4 times more memory than typical 1080p. I doubt that your old PCs have more than 4 GiB of RAM.
20th June 2021, 19:49 | #19175 | Link | |
French Love
21st June 2021, 01:11 | #19176 | Link | |
Grumpy Old Man.
Don't forget you can use DE on 1 PC, it's just a little different with the IP address's. Although, seeing you use a Wireless network, you may not need to change anything. For example, I'm on a wired LAN, with 192.168.1.X's, and if I want to use just the one PC with DE, I just need to have the network switch / hub powered on. otherwise----- I think the IP address you'd need to use is 127.0.0.1, with the :1000 as well. Nothing ventured, nothing gained.
23rd June 2021, 22:36 | #19177 | Link | |
24th June 2021, 18:30 | #19178 | Link |
Hey guys, long time lurker here. I am planning to soon encode a lot of my blu-ray backups and want to maintain the best quality. I was originally going to do staxrip with my NVIDIA GPU but the more I researched it, I do not feel like the quality is up to my standards. Most of the GPU encoding I saw loses a lot of detail from the original bluray source. Would Ripbot be a good program to do x265 bluray backups? I want to be able to get the best possible quality as the original source and retain the lossless audio tracks on all of my encodes. If this is a great way to go, I plan on getting a better encoding PC dedicated to my encodes. Also, is there a guide anywhere that goes over what are good extra advanced settings I can use on all of my encodes? I want the encode to look similar to the orginal. I am fine with a bigger file size as well (as long as it is smaller by at least 20% of the original). I would really appreciate any guidance. Thanks guys!
24th June 2021, 23:40 | #19179 | Link | |
Just updated and immediately noticed that the output line is now editable. Thanks a lot, Atak. Major time saver. I don't think I'll ever be using the Save As dialog anymore.
I have a quick noob question: is there a lossy codec similar to AC3 that allows you to keep all 7.1 channels, not just 5.1? I can't afford to use uncompressed DTS or TrueHD audio and having the audio track being almost the same size (if not more) as the video track, but I'd like to keep all channels at least for some of the encodes as well. Is there a solution for this? I'm sure there must be, but I just got my first modest 7.1 system and this is the first time I have to worry about this. Quote:
As for the advanced settings, most of this stuff is fairly self-explanatory. It also depends on what you exactly you want and the kinds of video files you'll be processing. You may have to look up some of the terminology, but other than that, you'll probably be better off by taking a small sample file and doing several attempts to see how it looks on various settings, asking for help with specific issues, once you encounter them. Hope this helps. Last edited by Ripmann; 24th June 2021 at 23:50. |
25th June 2021, 00:31 | #19180 | Link | |
