Old 17th April 2021, 10:52   #1  |  Link
algia
Restore old vhs
Hi all,
I'm trying restore old vhs and this is the code I used
clip="C:\Users\alojal\Desktop\sample disk\ZIA ROSA\ZIAROSA-IN\zia rosa.mov"
video=FFMpegSource2(clip, atrack=-1).Crop(240,18,-240,-18).ConvertToYV12(interlaced=true)
Crop(24,18,-24,-18)
AssumeBFF()
QTGMC(preset="slow",FpsDivisor=2,ChromaMotion=false,border=true,ChromaNoise=true,DenoiseMC=true,NoiseDeint="Generate",StabilizeNoise=true,GrainRestore=0.0,Sharpness=2)
RemoveDirt(limit=10,_grey=false)
ConvertToRGB(matrix="Rec601", interlaced=false)
GamMac(LockChan=1,LockVal=130,RedMul=1,GrnMul=1,BluMul=0.9,Show=false,Verbosity=2,hith=0.5,loth=0.5,th=1,scale=2)
ConvertToYV12(interlaced=false)
FFT3DFilter(sigma=8, beta=1.0, plane=4, bw=16, bh=16, ow=8, oh=8, bt=3, kratio=3.0, sharpen=1.0, scutoff=0.3, svr=1.0, smin=4.0, smax=30.0, measure=true, interlaced=false, wintype=0, degrid=1.0, dehalo=1.0, hr=2.0, ht=50.0)
ChromaShiftSP(2,4)
DeHalo_Alpha(rx=2.0, ry=2.0, darkstr=1.0, brightstr=1.0, lowsens=50, highsens=50, ss=1.5)
LSFmod(defaults="slow", strength=39, kernel=12, preblur="OFF", secure=false, Szrp=2, Spwr=4, SdmpLo=4, SdmpHi=48, overshoot=1, undershoot=1, overshoot2=2, undershoot2=2, soothe=true, keep=20, edgemode=0, show=False, screenW=720, screenH=576)
StackHorizontal(video,last)
return last
after GamMac I see light blu haloing around the hair and in the wall
I would like, more shapness and some suggestion
thank you in advance
[IMG]
https://www.mediafire.com/view/tnrzk...ZIROS.png/file
[/IMG]
algia is offline   Reply With Quote
Old 24th April 2021, 16:06   #2  |  Link
Arx1meD
Arx1meD's Avatar
You need a color denoiser. Try using one of these: Veed, Cnr2 or CCD (Camcorder color denoise for VirtualDub).
As for me CCD gives the best result.
For example:
LoadVirtualDubPlugin("...\ccd_32bit.vdf", "ccd", 0)
ConvertToRGB()
AddBorders(10,0,0,0) #The source frame size (height and width) must be a multiple of 16.
ccd(30,1)
Crop(10,0,0,0)
ConvertToYV12()
Or try:
MiniDeen(radiusY=1, radiusUV=2, thrY=1, thrUV=20, y=2, u=3, v=3)
f3kdb(preset="medium/nograin", sample_mode=2)
Arx1meD is offline   Reply With Quote
Old 25th April 2021, 08:11   #3  |  Link
Sharc
Also, you may want to try MCDegrainSharp. It denoises and fixes other typical VHS issues without requiring tons of settings and tweaks. The defaults are good for most cases in my experience.
Old 26th April 2021, 10:05   #4  |  Link
Mounir
you're doing it wrong to begin with
You should crop only at the end of the script especially if you deinterlace right after
avisource()
assumetff (or bff) # TFF for vhs unless you have captured in DV !!
qtgmc("fast")
selecteven()
~Other filters~
crop()
Mounir is offline   Reply With Quote
Old 26th April 2021, 11:36   #5  |  Link
lollo2
lollo2's Avatar
You should crop only at the end of the script espcially if you're deinterlace right after
Am I wrong or I read something different here?
https://forum.doom9.org/showthread.p...659#post690659
What is right?
lollo2 is offline   Reply With Quote
Old 26th April 2021, 11:56   #6  |  Link
You should use eg AssumeTFF() if necessary, as AssumeBFF() is the default.
Almost always TFF in PAL land, when interlaced, if PAL BFF interlaced, then problably done in error.
If cropped off part contains valid image, then may be useful to crop later and so
have a bit more image to use during deinterlace, however I would mostly crop first.
I'm not saying that Mounir is wrong, but perhaps he/she can give a reason for crop last.
EDIT: As your crop is left only (not top nor bottom) I dont see it making much difference,
although if crop first, then must comply with vertictal interlaced cropping restrictions due to
colorspace (chroma granularity) and interlacing. [ie multiples of 4 where interlaced YV12]
If cropping first makes you lose some image due to crop restrictions on interlaced,
might then be better to crop last. (So I would say not a concrete rule either way).
restore, vhs
