Old 15th November 2015, 21:53   #21  |  Link
Originally Posted by MysteryX View Post
Edit: ah great... it doesn't support MT
What you mean by that ?
It dont work under MT ?
I dont use MT so would not know (life is just too short to be messing with dodgy stuff).
StainlessS is online now   Reply With Quote
Old 15th November 2015, 22:00   #22  |  Link
Motenai Yoda
Motenai Yoda's Avatar
Originally Posted by qyot27 View Post
The -map parameter is completely unnecessary when there's only one video and one audio input. Just saying.
Yep, but using muxed streams that one of them has coverart or some strange metadata can happens.
@Stains TWriteWAV how work?
ie Soundout write the file when the script is loaded
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 15th November 2015, 23:15   #23  |  Link
TWriteAVI/TWriteWAV:- http://forum.doom9.org/showthread.php?t=172837
Can write Video and/or Audio, and does not return immediately (as SoundOut does), it will only return when eg WAV is written and exists so that it
can be available in same script for second pass processing.
EDIT: TWriteWAV writes audio as an avs file is played, BUT,
ForceProcessAVI/ForecProcessWAV force reads the video/audio so that it is output without playing file.
Can use same to eg forcibly write some kind of metrics file (deshaker log or whatever), so it is available
for a second pass, within the same avs file.
Also, eg ForceProcessAVI scans an AVI file faster than VDub Video Analysis Pass does, about 70% of VDub taken time.
Old 15th November 2015, 23:38   #24  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Since you don't support scanning back and forth, it makes sense it crashes. MT causes your plugin to process frames in a random order while opening various instances of your script at once.
Which means you're probably trying to open and write to the file 8 times at once while seeking back and forth.
MysteryX is offline   Reply With Quote
Old 15th November 2015, 23:44   #25  |  Link
Yes, I insisted on strict 1st to last frame processing, god knows how it would perform (old version) in MT, totally messed up AVI file I would guess.
As I said, dodgy stuff.
Old 16th November 2015, 00:44   #26  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Blue screen followed by laptop batteries melting
Old 16th November 2015, 01:32   #27  |  Link
Arh, not too bad then
Old 16th November 2015, 08:32   #28  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
If I have the WAV file and the encoded AAC file, is there a way to do a "diff" and measure the difference? Something that would easily tell if the quality is high enough to preserve the details?
Old 16th November 2015, 09:01   #29  |  Link
smok3
brontosaurusrex
smok3's Avatar
@MysteryX: no, ABX test is what you want.
smok3 is offline   Reply With Quote
Old 16th November 2015, 10:05   #30  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
... and what about a AI software that does the ABX test for the user and then just displays the result?
Old 16th November 2015, 10:12   #31  |  Link
smok3
brontosaurusrex
smok3's Avatar
Digital ear/AI = lossy audio codecs, so you would need something smarter than whats already there, so no.
Old 16th November 2015, 10:25   #32  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
It *was* working, until I started re-tuning the audio with
AssumeFps(FrameRate*.981818, true)
at which point I get my WAV file but Nero says:
ERROR: could not open AAC encoder
Old 16th November 2015, 12:27   #33  |  Link
Groucho2004
It obviously doesn't support non-standard sample rates.
You have to change the pitch (only). If TimeStretch() does not satisfy your needs you might consider writing a plugin based on Subband Sinusoidal Modeling Synthesis (SBSMS).
Old 16th November 2015, 18:58   #34  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
TimeStretch(pitch=100.0 * 0.981818)
This causes bad distortion. Not an option.
R = AudioRate
ReSampleAudio(R)
This works. It actually sounds better than if I don't resample(?)
As for SBSMS, I wanted to try the command-line conversion to see how it compares. The default download is a very basic GUI that really doesn't do much, and it has no documentation whatsoever. Calling the exe with "-help" doesn't do anything either expect launching the window.
The other download links with the source code don't contain any compiled library, and I still haven't seen any kind of documentation about how to use it from the command line. Would love to give it a try though.
Old 16th November 2015, 19:08   #35  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
OK I got SBSMS to work through the GUI for a test. Quality sounds good.
However
1. It is extremely slow to initialize and create the .sbsms file
2. The .sbsms file is huge 255MB off of a 55MB WAV file
3. I don't have enough fine-grained control over the pitch to get the desired tone
Old 16th November 2015, 19:31   #36  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Rubberband might do.
http://rubberbandaudio.com/
It can be integrated into FFMPEG but I don't think it's in the default builds, unless I'm mistaken.
This command works
rubberband.exe -p -0.3176665363342977 in.wav out.wav
