Old 19th July 2012, 16:40   #1  |  Link
steinsgate
font color for ffinfo() and info() function
Hi, is there anyway to change the default font color for the ffinfo() function for ffms2? Same questions for info() function. Thanks!
steinsgate is offline   Reply With Quote
Old 19th July 2012, 17:36   #2  |  Link
Groucho2004
"ffinfo()" in ffms2.avsi uses "subtitle()" which allows to specify text colour, etc.
"Info()" doesn't allow changing the text colour.
Old 19th July 2012, 20:41   #3  |  Link
steinsgate
Wow. Thanks a lot!
I modified the ffms2 script a little bit to add support for text_color and halo_color. This is my first AviSynth script attemp. :P
# FFmpegSource 1.21 syntax compatibility
# Created by TheFluff
# added text_color and halo_color support to FFINFO() by SteinsGate 7/19/2012
#   ex. FFInfo(text_color=$FFFFFF, halo_color=$FFFFFF)
function FFmpegSource2(string source, int "vtrack", int "atrack", bool "cache", \
	string "cachefile", int "fpsnum", int "fpsden", string "pp", int "threads", \
	string "timecodes", int "seekmode", bool "overwrite", int "width", int "height", \
	string "resizer", string "colorspace", int "rffmode", int "adjustdelay", \
	bool "utf8", string "varprefix") {
	vtrack 		= default(vtrack,-1)
	atrack		= default(atrack,-2)
	cache		= default(cache,true)
	cachefile	= default(cachefile,source+".ffindex")
	fpsnum		= default(fpsnum,-1)
	fpsden		= default(fpsden,1)
	pp			= default(pp,"")
	threads		= default(threads,-1)
	timecodes	= default(timecodes,"")
	seekmode	= default(seekmode,1)
	overwrite	= default(overwrite,false)
	width		= default(width,-1)
	height		= default(height,-1)
	resizer		= default(resizer,"BICUBIC")
	colorspace	= default(colorspace,"")
	rffmode		= default(rffmode,0)
	adjustdelay	= default(adjustdelay,-1)
	utf8		= default(utf8,false)
	varprefix	= default(varprefix, "")
	((cache == true) && (atrack <= -2)) ? ffindex(source=source, cachefile=cachefile, \
		indexmask=0, overwrite=overwrite, utf8=utf8) : (cache == true) ? ffindex(source=source, \
		cachefile=cachefile, indexmask=-1, overwrite=overwrite, utf8=utf8) : nop
	v = ffvideosource(source=source, track=vtrack, cache=cache, cachefile=cachefile, \
		fpsnum=fpsnum, fpsden=fpsden, pp=pp, threads=threads, timecodes=timecodes, \
		seekmode=seekmode, rffmode=rffmode, width=width, height=height, resizer=resizer, \
		colorspace=colorspace, utf8=utf8, varprefix=varprefix)
	a = (atrack <= -2) ? blankclip(audio_rate=0) : ffaudiosource(source=source, \
		track=atrack, cache=cache, cachefile=cachefile, adjustdelay=adjustdelay, \
	return audiodubex(v,a)
function FFImageSource(string source, int "width", int "height", string "resizer", \
	string "colorspace", bool "utf8", string "varprefix") {
	varprefix	= default(varprefix,"")
	return FFVideoSource(source, cache=false, seekmode=-1, width=width, height=height, \
		resizer=resizer, colorspace=colorspace, utf8=utf8, varprefix=varprefix)
function FFCopyrightInfringement(string source) {
# Violates copyright
# * With audio
# * No annoying lawyers
# * Simple syntax
# * Do not use on Britney Spears' music videos or sex tapes
# And whatever you do:
#   DO NOT TELL NEURON2 THAT YOU USED THIS FUNCTION
	FFIndex(source=source)
	return audiodubex(FFVideoSource(source=source), FFAudioSource(source=source))
function FFFormatTime(int ms) {
	s = ms / 1000
	ms = ms % 1000
	m = s / 60
	s = s % 60
	h = m / 60
	m = m % 60
	return string(h) + ":" + string(m,"%02.0f") + ":" + string(s,"%02.0f") + "." + string(ms,"%03.0f")
function FFInfo(clip c, bool "framenum", bool "frametype", bool "cfrtime", bool "vfrtime", string "varprefix", int "text_color", int "halo_color") {
	framenum	= default(framenum,true)
	frametype	= default(frametype,true)
	cfrtime		= default(cfrtime,true)
	vfrtime		= default(vfrtime,true)
	varprefix	= default(varprefix, FFVAR_PREFIX)
	c.frameevaluate("""
		fftempstring = ""
		varprefix = """" + varprefix + """"""")
	framenum ? frameevaluate("""fftempstring = fftempstring + "Frame Number: " + string(current_frame) + " of " + string(framecount()) + "\n" """, after_frame=true) : nop()
	frametype ? frameevaluate("""fftempstring = fftempstring + "Picture Type: " + chr(eval(varprefix + "FFPICT_TYPE")) + "\n" """, after_frame=true) : nop()
	cfrtime ? frameevaluate("""fftempstring = fftempstring + "CFR Time: " + FFFormatTime(round((current_frame * 1000) / framerate())) + "\n" """, after_frame=true) : nop()
	vfrtime ? frameevaluate("""fftempstring = fftempstring + "VFR Time: " + FFFormatTime(eval(varprefix + "FFVFR_TIME")) + "\n" """, after_frame=true) : nop()
	#check whether text_color and halo_color are defined in parameter list
    text_color_string= (Defined(text_color)) ? "text_color="+string(text_color)+"," : ""
    halo_color_string= (Defined(halo_color)) ? "halo_color="+string(halo_color)+"," : ""
	return scriptclip("subtitle(fftempstring,"+text_color_string+halo_color_string+"lsp = 1)", after_frame=true)
http://pastebin.com/6tRfZQ5W
avsp, ffinfo, ffms2
