1st January 2011, 01:27 | #561 | Link | |
retired developer
[edit] ffmpeg cannot downmix (5.1 -> 2.0). You'll have to use AAC LC with a high bitrate. [edit 2] faac (1.28) fails to encode 6channels, but it works with nero. I'll remove FAAC and use ffmpeg instead. [edit 3] this update will take some time.. I'll update the whole audio part to pipe ffmpeg to the other encoders, so I'll only have 1 step (encoding) instead of extracting then encoding.
Detritus Software Last edited by Sirber; 1st January 2011 at 16:33. |
1st January 2011, 09:54 | #562 | Link |
Using the 101229_dev build batch encoding seems broken, just stops after one file unlike the previous build. I can press start again and it goes to the next file on the list.
1st January 2011, 16:20 | #563 | Link |
retired developer
Using 20101229dev, both files in the queue encoded successfully. Sorry, I cannot reproduce your problem.
Detritus Software |
4th January 2011, 18:50 | #564 | Link |
retired developer
new release:
v 20110104 dev * Compiled with Lazarus 0.9.31 (FPC 2.4.3 win32) * added: making place for a 64bit version (ffmpeg) * added: more bitrate for AAC LC (192kbps, 256kbps) for 5.1 audio * added: checkbox to force stereo (for 5.1 sources) * fixed: audio extracting force 2 channels (ffmpeg's -ac 2) (bug #5) * fixed: vorbis bitrate selection (-b --> -q) * fixed: uninstaller * updated: ffmpeg (static --> shared), oggenc2 download [edit] warning: audio seems broken. [edit2] fixed and reuploaded.
Detritus Software Last edited by Sirber; 4th January 2011 at 19:26. |
4th January 2011, 19:36 | #566 | Link |
retired developer
What do you mean? an option
Detritus Software |
4th January 2011, 22:48 | #567 | Link |
retired developer
audio is OK in the latest release. the log window has a duplicate entry, I'll fix that soon.
Detritus Software |
5th January 2011, 08:47 | #568 | Link |
Im a noob at this and i have a problem with BENCOS_20101105 skips the audio extraction and encoding... you said i needed an audio stream how do i do that?? need your help Thanks...
[IMG][/IMG] Last edited by edward666; 5th January 2011 at 08:58. |
5th January 2011, 12:51 | #570 | Link |
retired developer
you are using v2010-01-30, update
Detritus Software |
5th January 2011, 18:01 | #572 | Link |
retired developer
both version doesn't have the same encoding options and won't produce the same quality. Choose "MQ" or "LQ" in the newer release.
[edit] I'm wondering.. is bencos.exe using CPU while encoding on your PC?
Detritus Software Last edited by Sirber; 5th January 2011 at 18:11. |
6th January 2011, 02:48 | #573 | Link | |
User of X264
i have done some test on 5.1 channel audio file but i face audio problem.....help
6th January 2011, 03:27 | #574 | Link |
retired developer
Detritus Software Last edited by Sirber; 6th January 2011 at 03:43. |
6th January 2011, 14:05 | #575 | Link |
retired developer
On the todo now:
* Encode by file size * Multi track (audio) * Web view (basic, online, to see the main log + realtime status text)
Detritus Software |
6th January 2011, 14:37 | #576 | Link | |
User of X264
With neroAacEnc it work perfectly but without it i got an error like
I use AAC LC 192 Is there no way to downmix 6channel to 2 channel... i want to use AAC HE+PS/64 with normalization for small size encoding. Last edited by Alex_080; 6th January 2011 at 14:49. |
6th January 2011, 14:42 | #577 | Link |
retired developer
http://code.google.com/p/bencos/issues/detail?id=5
5.1 encoding works now with AAC LC and Vorbis. ffmpeg cannot downmix proprely 5.1 to 2.0. I'm making a release.. [edit] http://code.google.com/p/bencos/down...110106_dev.exe
Detritus Software Last edited by Sirber; 6th January 2011 at 14:49. |
6th January 2011, 16:10 | #578 | Link |
retired developer
Detritus Software |
aac, bencos, gui, webm, x264 |
