Old 14th November 2007, 22:36   #21  |  Link
DiZzle.
Hi there,
I'm new on this forum, i've already read a lot of threads on this forum to find a gui to convert and playback video files on my ps3, and this one works great for me. Thx!
One suggestion, changing avc level by using hexedit is a lot faster, maybe something for your app?
DiZzle. is offline   Reply With Quote
Old 14th November 2007, 23:10   #22  |  Link
3r1c
Originally Posted by DiZzle. View Post
Hi there,
I tried this method first, using seek and put to modify the bytes without creating a duplicate .h264 file, but the resulting file did not play back on the ps3.
Changing it with h264info was the only way that worked.
3r1c is offline   Reply With Quote
Old 14th November 2007, 23:16   #23  |  Link
3r1c
Originally Posted by akirax View Post
Not working.
I have a .mkv with video 23.976fps and audio 25fps when mkvextrct extract the a/v and then remux to .vob the video play desincronized.
How can you have video/audio at different rates and expect it to play in sync?
All this program does is demux and mux.
It doesnt fix your audio so its the same length as video.
It doesnt care about or change the framerate or recompress or touch the video/audo in any way.
If your streams arent to spec in the first place, the output wont be either.
Your invalid file may work on your pc but the ps3 is very fussy about what it will play.
Old 15th November 2007, 04:35   #24  |  Link
djskribbles
so do you know why you can't fastforward/rewind? is it at all possible to fix the issue? other than that, it worked flawlessly.
djskribbles is offline   Reply With Quote
Old 15th November 2007, 15:20   #25  |  Link
akirax
I´m from Spain.
I download a .mkv, when demux to h.264 the video is 23.976fps and the audio (spanish) .ac3 is 25fps. Then when mux into a .vob the a/v is desincronized. In the .mkv is sincronized, but when demux the .mkv lost the a/v Synchronization.
Sorry for my bad english.
akirax is offline   Reply With Quote
Old 15th November 2007, 17:26   #26  |  Link
3r1c
because vob does not support different a/v rates.
if you can give me a sample i will see if i can fix it
Old 15th November 2007, 18:27   #27  |  Link
Grimmi Meloni
3r1c, would you mind sharing the ffmpeg commands your tool internally runs?
I have a script on my linux box, which does the same but reencodes the audio to AAC. I would like to adapt it.
What I basically do is:
- "mkvmerge -i" to get the info which track is what (audio/video)
- "mkvextract"
- change h264 level to 4.1
- decode ac3 with a52dec
- reencode audio with neroaac
- mp4box everything
From the tools that are included I think i just need the ffmpeg call you make.
Thanks!
Grimmi Meloni is offline   Reply With Quote
Old 15th November 2007, 18:47   #28  |  Link
akirax
Here is it:
http://rapidshare.com/files/65674336/S.P.3.x264.rar
Thank´s a lot 3r1c!
Regards.
Old 15th November 2007, 20:08   #29  |  Link
gigo979
http://www.3r1c.eu/mkv2vob/mkv2vob.rar
link's dead ??
You can re-up??
Thanks
bye
gigo979 is offline   Reply With Quote
Old 16th November 2007, 03:59   #30  |  Link
3r1c
Here is it:
Thank´s a lot 3r1c!
Regards.
Fixed in v 1.2
Old 16th November 2007, 09:23   #31  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Can anybody provide a "re-muxed" sample file yet?
Old 16th November 2007, 09:34   #32  |  Link
akirax
Fixed in v 1.2
Thank you for your interest, but again the a/v is desincronized .
Regards.
Old 16th November 2007, 17:28   #33  |  Link
3r1c
Regards.
It works for the sample file you gave me.
Old 16th November 2007, 17:59   #34  |  Link
hyperspaced
Can you share with us the commands you use for demuxing & muxing? Especially for muxing back to VOB.
thanks.
hyperspaced is offline   Reply With Quote
Old 16th November 2007, 20:07   #35  |  Link
akirax
Umm...
When I play the sample in the PS3, the video is more quickly than the audio.
My PS3 is PAL.
Regards.
Old 16th November 2007, 20:41   #36  |  Link
3r1c
Umm...
My PS3 is PAL.
Regards.
Make sure you are playing from the beginning of the file and you have the 2.0 firmware.
I do not have a PAL ps3 to try this on, but they should play it the same, if not its a bug in the ps3 itself.
In the first version the sample you gave me played the video back slower (at 23.976 instead of 25 fps) this was corrected in the 1.2 fix, after the fix it played correctly for me.
I just double checked it again with your sample and it does indeed play back properly.
If your streaming through tversity make sure in Settings/Transcoder is set to "Never", save and restart.
Tversity sometimes tries to transcode the vob if set to "only when needed", this must not happen.
Here is the vob file that played for me, converted from your sample.
http://www.3r1c.eu/mkv2vob/25fps-sample.rar
Old 16th November 2007, 20:43   #37  |  Link
3r1c
thanks.
ffmpeg -r 23.976 -f h264 -i video.h264 -f ac3 -i audio.ac3 -vcodec copy -acodec copy -f vob output.vob
Old 16th November 2007, 20:46   #38  |  Link
buzzqw
HDConvertToX author
the framerate is computed by analizing the media ... or not ?
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 16th November 2007, 20:49   #39  |  Link
glen8
Well done for being the first person to attempt this. I know of tons of people who would like to play .mkv on the ps3.
Unfortunately for me it doesn't work. Everything seems to go according to plan but the PS3 just tells me "no supported tracks" or something like that
glen8 is offline   Reply With Quote
Old 16th November 2007, 20:52   #40  |  Link
3r1c
buzzqw: Framerate is got from mkvinfo.
glen8: No supported tracks sounds like you dont have the latest firmware 2.0. Renaming .vob to .mpg should make it show up, but i think only firmware 2.0 will be able to play it.
