Old 20th July 2020, 23:12   #18621  |  Link
jlpsvk
Originally Posted by GZZ View Post
if you are already on 3.4+9 and it works, then keep it. No reason to use time on a build that is almost identical. The only reason we updated was because the version included with Ripbot was on version 3.2 or 3.3.
it works... but there is a problem...
when i want to mux it to dvhe.04, muxer will fail, as BL has different number of frames as EL+RPU... so it is a problem.. without HDR10+ metadata, encode has the same exact frame numer... so problem would be in x265, whe used with HDR10+ JSON
AMD Ryzen 9 5950X, 32GB DDR4-3200 CL16, RTX 3060, 2TB NVMe PCIE4.0, NAS with 8x16TB HDD
jlpsvk is offline   Reply With Quote
Old 20th July 2020, 23:31   #18622  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Is frame number correctly detected in ripbot?
Is frame number correctly displayed in x265 during encoding?
Old 20th July 2020, 23:47   #18623  |  Link
jlpsvk
yes and yes. but output is not correct. it doesn't matter which GUI i use... always few frames missing at the end. without HDR10+ JSON everything is OK, encoded with the same JSON but with nVidia GPU, frames are OK.
Old 28th July 2020, 14:15   #18624  |  Link
blublub
Hi
What could be the reason why the Encoding server won't start up correctly? In 9 out of 10 reboots the encodingserver process shows in taskmanager but I do not see the tray icon and whenever this happens the encoding client can't connect.
thx for any help
blublub is offline   Reply With Quote
Old 28th July 2020, 16:27   #18625  |  Link
Atak_Snajpera
Originally Posted by blublub View Post
Hi
thx for any help
Some application running in background (from MSI/Gigabyte/Logitech and so on) blocks encodingserver.exe. Known issue. There is nothing I can do about that because that is not my fault.
Old 28th July 2020, 16:33   #18626  |  Link
blublub
OK, thx. I do have MSI Afterburner running, I guess that's it - sorry to ask if it's a known issue
Old 29th July 2020, 13:19   #18627  |  Link
Ryushin
Ryushin's Avatar
Auto Cropping and 4K
Atak, can an option be added for a number of threads to open for cropping or to limit it based on memory. Using auto cropping with 4K will use up 16GB of memory and Windows will kill other processes, including the Encoding Client.
I'm having to use manual cropping for 4K if I don't want processes killed.
Ryushin is offline   Reply With Quote
Old 3rd August 2020, 14:33   #18628  |  Link
SKPN
I'm having a slight issue with colors, specifically skin tones. For some reason, when I encode with RipBot, it's altering the colors slightly on the video, and I cannot figure out why.
Here is an example:
https://imgsli.com/MjAwMTM
The encoded video makes the skin look slightly orange. Other colors are affected as well, but the skin is the most noticeable. I'm not using any settings that would change the colors, so I'm not sure what the deal is.
SKPN is offline   Reply With Quote
Old 3rd August 2020, 14:35   #18629  |  Link
Atak_Snajpera
Here is an example:
Post mediainfo report from original file and encoded one.
Old 3rd August 2020, 15:43   #18630  |  Link
SKPN
Original
Video
ID in the original source medium : 224 (0xE0)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Format settings, picture structure : Frame
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Duration : 24 min 21 s
Bit rate mode : Variable
Bit rate : 4 412 kb/s
Maximum bit rate : 9 000 kb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.426
Time code of first frame : 00:59:59:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
GOP, Open/Closed of first frame : Closed
Stream size : 769 MiB (92%)
Language : English
Default : No
Forced : No
Original source medium : DVD-Video
Encoded
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L3@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 1 477 kb/s
Width : 632 pixels
Height : 480 pixels
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.162
Stream size : 257 MiB (79%)
Writing library : x265 3.2+34-8e6db24c1517:[Windows][GCC 9.2.0][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=4 / numa-pools=+ / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=632x480 / interlace=0 / total-frames=1797 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=30 / keyint=300 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=0 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=16 / min-cu-size=8 / no-rect / no-amp / max-tu-size=16 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=9 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / selective-sao=4 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=18.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=16 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Old 4th August 2020, 07:12   #18631  |  Link
LigH
LigH's Avatar
DVD video usually has color primaries BT.601, as usual for "vintage" media with SD resolutions. Between BT.601 and BT.709, you will experience some green/red shift: see http://avisynth.nl/index.php/Colorimetry
The simple solution should be to tell the encoder to flag its encoded output as BT.601 (or Rec601).
New German Gleitz board
Old 4th August 2020, 12:11   #18632  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Would that be possible with RB ??
Either a Custom Script or modding one ???
Not poorly done, just doin' it my way !!!
Live every day like it's your last, because one day, it will be !! (M$B)
Pauly Dunne is offline   Reply With Quote
Old 8th August 2020, 11:20   #18633  |  Link
archiel
Over the last week the Output Speed option has started giving problems. If I use any setting other than default then
  1. The FPS on the main screen does not change
  2. The Duration on the main screen does not change
  3. Once encoding is started a 'info.txt does not exist' error is generated
After which the script goes directly to the final re-encode and shows 'Error: The file 'H:\Temp\RipBot264temp\job2\video.265' could not be opened for reading: open file error.'
Re-setting Output Speed to default allow the program to run.
I use this option where I have used MkvCutter to edit and re-encode the start of a video. As it re-encodes at 24 fps regardless of the speed of original, I need to use the Output Speed to prevent the audio and video being out of sync.
I have tested on the same video, before and after using MkvCutter, in each case RipBot264 runs normally if Output Speed is default and fails for any other setting.
archiel is offline   Reply With Quote
Old 8th August 2020, 13:12   #18634  |  Link
Pauly Dunne
Grumpy Old Man.
Good luck...
Have you heard of VideoRedo or AviDemux ??
https://www.videohelp.com/software/s...itors-h264-avc
Old 8th August 2020, 13:57   #18635  |  Link
archiel
Originally Posted by Pauly Dunne View Post
Good luck...
While I realise I can look at other solutions, I have been using RipBot264 with the Output Speed option for many years without any difficulty. What I am more interested in is how this can be fixed so that it works as intended.
Old 8th August 2020, 14:01   #18636  |  Link
Pauly Dunne
Grumpy Old Man.
That's why I said "Good Luck"....
There's not a lot going on with RB, atm, unfortunately.
Old 10th August 2020, 03:59   #18637  |  Link
Ripmann
Another minor potential improvement idea:
When you enter the AviSynth menu and immediately exit it without changing the settings (I do it all the time to double check I didn't forget to setup denoising, etc.), the program still hangs for a while with the "Please Wait...Gathering Information..." tooltip. Usually it's quick, but in some cases the waiting process can take a while.
Theoretically (and again, without knowing the internal workings of the program), it should be very easy to set up a quick boolean flag code for tracking changes and allow exiting the menu without any delays or updates if no changes were made. Not sure if you want to bother with this one, but as a loyal and dedicated user of your software I'll just keep throwing every minor flaw or room for improvement I can find out there in case they may interest you.
Ripmann is offline   Reply With Quote
Old 10th August 2020, 08:00   #18638  |  Link
Pauly Dunne
Grumpy Old Man.
Did you happen to read the previous post(s) ???
Old 23rd August 2020, 13:54   #18639  |  Link
blacksapprow
New x266 codec is coming,
https://www.extremetech.com/extreme/...tep-towards-8k
I hope ripbot will get that add on soon....
blacksapprow is offline   Reply With Quote
Old 24th August 2020, 07:30   #18640  |  Link
LigH
LigH's Avatar
Any H.266 / VVC codec is not automatically "x266". These x26# brands are usually related to the VideoLAN network.
