#121 | Link | |
HDR to SDR conversion is be done by conversion of HDR stream without the check of HDR encoding. What about Nvenc i'll see what can be done. |
#122 | Link | |
Posts: n/a
Not sure why there are 2 identical posts (might as well delete one). OK, so thanks for replying, and I did a little test yesterday with HDR to SDR, or your BT 709 option... I loaded a HDR HEVC movie (Batman), and basically only chose the BT 709 option, and let it go....other than being extremely slow (even with my 12 core CPU), I only let it run for about 10 minutes, and played what it had processed, and it looked pretty good, I checked it with Mediainfo, and it definitely wasn't HDR anymore ![]() If that conversion could be done using nVidia GPU's, that might speed up the process. Anyway, that's my feedback. Regards |
#123 | Link | |
Sorry, but for further there will be no support for hardware acceleration. Too many limitations, many options and filters can't be used, output quality can suffer. My motto: Better slow, but good quality. Read also: https://forum.videohelp.com/threads/...e-acceleration Last edited by ProWo; 14th June 2021 at 22:36. |
#124 | Link | |
Posts: n/a
Well, that's sad, but if you don't think it's the way to go, then that's it. Thankyou for at least looking into for me. But having said that, since posted my request, I went looking, and found another FFMPEG based app called Axiom....it seems to do a lot. Have been testing it, seems OK, but like every new thing one tries, requires a steep learning curve. Cheers |
#129 | Link |
August 05, 2021 update to version 2.8.4.
Fixed: A major bug in IVTC execution. Improved: Recognition of a eventual video offset, Automatic stream sorting before muxing (In the multiplex section). Added: Automatic adjustment of the audio delay in the presence of a video offset. |
#132 | Link |
September 07, 2021 update to version 2.8.7.
Changed: Layout: new background color. Added: 5.1 (side) audio encoding. Improved: Audio: multichannel encoding (for faulty multichannel audio streams, to avoid channels mapping errors); Multiplex: stream analysis, program logic, A/V synchronization, automatic output file; Entire video analysis completely renewed. |
#133 | Link |
Posts: n/a
Does this REALLY convert audio to E-AC3 7.1 ??
I tried a couple of times, and just got an error, and that was it. I extracted the .dts and then re loaded that as the source file, and tried the conversion, but I couldn't understand how to then process it ![]() |
#135 | Link |
Just discovered this app, thanks much, ProWo!
Would it be possible to introduce a file integrity check/verification of some sort? I see FFMPEG has a "error" and "debug" flag, so perhaps it wouldn't be too difficult to implement? I don't know if there's a newer/easier FFMPEG feature, but I found these postings from 2015 describing usage of some of the flag options: https://superuser.com/questions/5736...mpeg-exe-in-wi https://superuser.com/questions/1002...e-avi-mpeg-mp4 Thanks! |
#136 | Link |
@ aigo
The error messages from FFmpeg don't really help. At most, they serve as information; if a video stream is really defective, then in the vast majority of cases it cannot be used anyway. Small correction algorithms that FFmpeg provides are already built into clever FFmpeg-GUI, in audio and video conversion, cutting, joining or multiplexing. |
#137 | Link |
September 28, 2021 update to version 2.8.8.
Fixed: A major bug in multiplex mapping, pcm codec selection not executed, bug in audio length & pitch change. Solved: Missing pkt_pts_time in newer ffprobe releases. Improved: Multiplex section. Last edited by ProWo; 18th October 2021 at 20:11. Reason: typo |
#138 | Link |
October 26, 2021 update to version 2.8.9.
Fixed: 0file bug, delete language tag bug, add files bug in multiplex section, aborted check bug Added: Ability to extract raw h264/h265 videostreams, mux dvb_subtitle into m2ts Removed: Mux hdmv_pgs_subtitle into m2ts, mkv, ts (not working) Changed: Output filenames, keyframe check from I to IDR |
#139 | Link |
November 26, 2021 update to version 2.9.0.
Fixed: minor bug (29.97fps recognition), bug in default+forced tags in subtitles, bug in subtitle track test Added: Multiplex to 3gp, Ability to show source info (clicking on source file) Improved: Change language tag Changed: .net 4.6 to 4.8 |
#140 | Link |
December 21, 2021 update to version 2.9.1.
Fixed: ac3 decoder drc on/off, minor bugs on info labels, bug in cut section for source without videostream. Added: ac3 mux in mpg, missing video codec and video language info, set default audiostream tag, selected streams counter and sum in multiplex section, homepage link. |
