Old 17th February 2021, 02:52   #101  |  Link
guest
Posts: n/a
Hi, not sure if this has been asked before, I'm new here, and just started using this app.
Can TrueHD 7.1 be converted to E-AC3 5.1 ??
If so, how, or would this need to be added to the app ??
Cheers
Old 17th February 2021, 17:54   #102  |  Link
ProWo
Cheers
Will examine this.
ProWo is offline   Reply With Quote
Old 18th February 2021, 15:48   #103  |  Link
ProWo
Originally Posted by -QfG- View Post
Is there any chance to implate single mono wavs export?
5.1 (6 ch) and 7.1(8ch) to single wav's (pcm) conversion implemented in latest beta version (v2.7.3_05_Beta).
Try it and report here.
Old 18th February 2021, 15:51   #104  |  Link
ProWo
TrueHD 7.1 to eac3 (5.1) conversion implemented in latest beta version (v2.7.3_05_Beta).
Old 19th February 2021, 01:32   #105  |  Link
guest
Posts: n/a
Hi ProWo,
I have done a conversion test of a TrueHD track, to E-AC3, and even though I chose "channels" option as "as source", it still changed it from 7.1 to 5.1, HOWEVER, that is not a fault of the app, it's FFMPEG itself
The "brains" behind FFMPEG, need to figure out a way so that it does support 7.1 / 8 channels.
But it IS nice that there is now E-AC3 support
I noticed a 7.1 pcm option, I will see what that does.
edit:- I just tried the 5.1 & 7.1 single pcm option, and when chosen, all other options disappear, and nothing can continue
Cheers, keep up the excellent work
Old 19th February 2021, 08:28   #106  |  Link
ProWo
Thanks for the hint. Is now fixed.
Old 19th February 2021, 19:19   #107  |  Link
tebasuna51
tebasuna51's Avatar
For what? To have 2D audio is more than enough 5.1 channels, 7.1 is unnecesary.
Maybe is better than use the "brains" for 3D audio and support Atmos.
Old 20th February 2021, 02:20   #108  |  Link
guest
Posts: n/a
For what? To have 2D audio is more than enough 5.1 channels, 7.1 is unnecessary.
A bit aggressive....
I'd really want to say thanks for this (that I found a couple of days ago)
https://forum.doom9.org/showthread.p...04#post1929204
I'm just sayin', some ppl would like 7.1, and have the hardware to use it, I, on the other hand, can ONLY use 5.1.
Maybe in the future, the "brains" might come up with ATMOS support, but that would still be useless for me.
I'm just happy that I have found a quicker way of converting TrueHD / Atmos to E-AC3, instead of DTSMA-HD (or what ever it is).
Old 1st March 2021, 13:25   #109  |  Link
ProWo
March 01, 2021 update to version 2.7.3.
Fixed: Small bugs.
Added: Multiplex to mov.
Added: Profile selection (x264 and x265).
Improved: Duration detection, Multiplex logic, many fine tunings.
Old 4th March 2021, 17:16   #110  |  Link
ProWo
Reintegrated the prior simple IVTC function. In many cases it works flawlessly, in others is needed an improved Avisynth script. Both are now possible. Download the latest beta version (v2.7.4_03_Beta) and try it out.
Old 15th March 2021, 18:39   #111  |  Link
ProWo
March 15, 2021 update to version 2.7.4.
Fixed: Small bugs.
Rewritten: entire DVD Rip module (unprotected DVD's only).
Improved: Duration detection, Multiplex logic, Audio codec and channel logic, many fine tunings.
Old 18th March 2021, 11:42   #112  |  Link
ProWo
Originally Posted by toryjay View Post
In my case, I hired a web development team and they solve this problem for me.
And what does that tell us?
Old 19th March 2021, 11:18   #113  |  Link
ProWo
March 19, 2021 updated latest beta (v2.7.5_03_Beta)
Added: Hardcoding SRT and ASS Subtitles.
Old 2nd April 2021, 10:29   #114  |  Link
ProWo
April 02, 2021 update to version 2.7.5.
Fixed: Small bugs.
Added: Hardcoding SRT/SSA/ASS Subs to videostream.
Improved: Cut section, multiplex section, many fine tunings.
Old 15th April 2021, 13:40   #115  |  Link
ProWo
April 15, 2021 update to version 2.7.6.
Fixed: Small bugs, change audio speed & pitch issue.
Added: Mux to ASF container.
Improved: Multiplex section, Join section.
Old 19th April 2021, 12:45   #116  |  Link
ProWo
Added: Change Profile Level without recoding for h264 and hevc videos in the newest Beta (v2.7.7_02_Beta).
Old 23rd April 2021, 12:22   #117  |  Link
ProWo
April 23, 2021 update to version 2.7.7.
Fixed: Small bugs, stream selection issue (with multiple A+S streams).
Added: Change profile level without recoding (for h264 and hevc videos).
Improved: Multiplex section, Join section, Cut section.
Old 6th May 2021, 15:27   #118  |  Link
ProWo
May 06, 2021 update to version 2.7.8.
Fixed: Some annoying bugs.
Changed: Some cosmetics.
Old 7th June 2021, 17:52   #119  |  Link
ProWo
May 31, 2021 update to version 2.7.9.
Fixed: Some small errors.
Fixed: A problem that the tags of the previously edited streams are not taken over correctly.
Improved: Audiostream Info.
Old 11th June 2021, 11:31   #120  |  Link
guest
Posts: n/a
Hi ProWo,
I haven't used this little gem for a little while now, so I have a question...I notice that in "Video Conversion" there is a "Colorspace" option...does this allow a HDR to SDR conversion ??
I have since downloaded the latest beta build, and I am wondering if you could add an nVidia Decoder & Encoder options for those of us that have suitable nVidia GPU's.
http://rationalqm.us/mine.html
https://www.videohelp.com/software/NVEnc
