Old 23rd September 2015, 13:44   #1261  |  Link
tormento
Acid fr0g
tormento's Avatar
What happens if you comment out the Prefetch() statement?
This night I'll try. It was already in my mind, such as use an older build.
@turment on Telegram
tormento is offline
Old 23rd September 2015, 14:48   #1262  |  Link
Reel.Deel
@tormento
Just out curiosity do you have the MT modes script loaded? Also I see that you're using SMDegrain with prefilter=4, I beleive that uses KNLMeans which the author said it's not MT friendly. Try adding SetFilterMTMode("KNLMeans", 3).
Reel.Deel is offline
Old 24th September 2015, 01:25   #1263  |  Link
tormento
Acid fr0g
tormento's Avatar
@Groucho2004 @Reel.Deel
Even without MT or with SetFilterMTMode("KNLMeansCL", 3), the corruption is still there.
tormento is offline
Old 24th September 2015, 01:29   #1264  |  Link
Reel.Deel
Is the video corrupted before SMDegrain?
Old 24th September 2015, 01:46   #1265  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Originally Posted by Reel.Deel View Post
@tormento
I was told that KNLMeans requires mode 5 or 6. 6 was considerably slower, 5 is working well for me.
MysteryX is offline
Old 24th September 2015, 02:17   #1266  |  Link
Reel.Deel
AviSynth+ MT only has modes 1-3.
Old 24th September 2015, 03:39   #1267  |  Link
burfadel
I really wish development of this would start up again soon.. getting this is a fully workable state to finally replace AvisynthMT would be great.
+1
People with programming skills are more than welcome to assist... I guess lol.
burfadel is offline
Old 24th September 2015, 04:58   #1268  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Smooth Video Project is greatly moving forward and is also waiting for a functional version of AviSynth+; as AviSynth is what makes SVP unstable and causes it to crash all the time.
I guess everybody wants it and nobody wants to touch the code lol
MysteryX is offline
Old 24th September 2015, 06:25   #1269  |  Link
ryrynz
ryrynz's Avatar
That was part of the reason why Avisynth+ was made, code maintainability.
ryrynz is offline
Old 24th September 2015, 19:53   #1270  |  Link
tormento
Acid fr0g
tormento's Avatar
The raw video or the result from AviSynth without filters?
tormento is offline
Old 24th September 2015, 19:54   #1271  |  Link
tormento
Acid fr0g
tormento's Avatar
KNLMeansCL works perfectly with mode 3. See AviSynth comparison.
tormento is offline
Old 24th September 2015, 22:33   #1272  |  Link
tormento
Acid fr0g
tormento's Avatar
Ok, it seems to be SMDegrain, both with prefilter=2 and with prefilter=4. No problems with standard AviSynth.
tormento is offline
Old 24th September 2015, 22:51   #1273  |  Link
tormento
Acid fr0g
tormento's Avatar
I am trying to use 64bit part of AviSynth+.
I am getting some strange errors and I can't understand why. I put KNLMeansCL in the plugins64 or plugins64+ and it gives me two different error.
Script:
PHP Code:
LoadPlugin("D:\eseguibili\media\DGDecNV\x64\DGDecodeNV.dll")
DGSource("E:\in\2_01 favoloso mondo di Amelie, Il\amelie.dgi")
KNLMeansCL(D=1A=1h=7.0,device_type="GPU"
Error:
[E:\in\2_01 favoloso mondo di Amelie, Il]d:avs4x264mod-x64.exe -o amelie_64.mkv amelie_64.avs
avs [error]: Script error: There is no function named 'KNLMeansCL'.
(amelie_64.avs, line 4)
Script:
PHP Code:
LoadPlugin("D:\programmi\media\AviSynth+\plugins64+\KNLMeansCL-0.6.11.dll")
Error:
avs [error]: Cannot load file 'D:/programmi/media/AviSynth+/plugins64+/KNLMeansCL-0.6.11.dll'. Platform returned code 126:
Impossibile trovare il modulo specificato.
(amelie_64.avs, line 2)
I am sure it is a very stupid thing but can't go thru.
tormento is offline
Old 24th September 2015, 23:09   #1274  |  Link
LigH
LigH's Avatar
Are you sure you put the 64 bit version of KNLMeansCL{-0.6.11}.dll into the plugins64 directory? A 64 bit AviSynth won't load a 32-bit plugin from there. I would possibly avoid the plugins64+ directory for generally AviSynth compatible plugins (not very specific to AviSynth+) unless I am certain what the difference is.
Does the same work when you use 32-bit AviSynth in a 32-bit application?
_
Not sure if and how that will work, just an idea: Can DependencyWalker Win64 confirm that it can use a 64-bit OpenCL driver? LoadLibrary error 126 seems to be related to unavailable dependencies sometimes.
Ah, another idea: I believe to remember that some plugins already use API version 6 while AviSynth+ may still use API version 5, might be a reason why it can't load plugins with a higher API version?
New German Gleitz board
LigH is offline
Old 24th September 2015, 23:30   #1275  |  Link
Groucho2004
What error does AVSMeter64 return?
Groucho2004 is offline
Old 25th September 2015, 00:39   #1276  |  Link
If you did something, and other people followed your lead, then your wish could come well come true. (EDIT: So we are all waiting for YOU !)
StainlessS is offline
Old 25th September 2015, 00:59   #1277  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
It's a wonderful codebase, I almost cried for joy the first time I dove in to debug something. Unfortunately, now all the easy stuff and most of the hard stuff is done, and what remains is one of the hardest problems in all of computer science: Performant but correct synchronization of bits of code that were never meant to be threaded (plugins, especially old ones). Since failures are unreproduceable by nature, it's a real head-desk problem.
Fixing it completely might require a threading expert who has tools like VTune, though even small improvements would be welcome!
foxyshadis is offline
Old 25th September 2015, 08:43   #1278  |  Link
RazorBurn
Error:
I have the same exact error on KNLMeansCL or any plugin that use VC redist 2013..
The problem relies on the bug in upgrading your Build in Windows 10..
My Solution was Install clean state windows 10 build 240.. And Dont upgrade to new Win10 Builds..
RazorBurn is offline
Old 25th September 2015, 11:10   #1279  |  Link
tormento
Acid fr0g
tormento's Avatar
AVS script:
PHP Code:
KNLMeansCL(D=1A=1h=7.0,device_type="GPU")
CompTest(1
AVSMeter 2.1.2 (x64)
AviSynth+ 0.1 (r1825, MT, x86_64) (0.1.0.0)
Number of frames:                 1764
Length (hh:mm:ss.ms):     00:01:13.500
Frame width:                      1920
Frame height:                      816
Framerate:                      24.000 (24/1)
Colorspace:                       YV12
Frames processed:               1764 (0 - 1763)
FPS (min | max | average):      2.087 | 41.93 | 22.76
Memory usage (phys | virt):     101 | 389 MB
Thread count:                   23
CPU usage (average):            10%
Time (elapsed):                 00:01:17.497
OMG.
I means two things:
  1. DGDecNV and KNLMeansCL works in 64 bit and not in 32 bit
  2. there must be something I forget when using avs4x26x
Is possible to use x264 directly with avs or can you tell me how to pass it thru without avs4x26x?
tormento is offline
Old 25th September 2015, 11:11   #1280  |  Link
tormento
Acid fr0g
tormento's Avatar
Read my previous reply.
tormento is offline
