16th January 2021, 10:09 | #18861 | Link |
What happens if use untouched recording in de mode? Try also remuxing in mkvtoolnix your edited MKV file.
16th January 2021, 15:34 | #18862 | Link |
Variations of MDegrain with a different thSAD failue. Here is one:
#Denoise MDegrain2 Modified Loadplugin("C:\Program Files\RipBot264\Tools\AviSynth plugins\mvtools\mvtools2.dll") super=MSuper(video,pel=2) bv1=MAnalyse(super,blksize=8,isb=true,delta=1,overlap=4) bv2=MAnalyse(super,blksize=8,isb=true,delta=2,overlap=4) fv1=MAnalyse(super,blksize=8,isb=false,delta=1,overlap=4) fv2=MAnalyse(super,blksize=8,isb=false,delta=2,overlap=4) video=MDegrain2(video,super,bv1,fv1,bv2,fv2,thSAD=200) |
16th January 2021, 15:36 | #18863 | Link | ||
16th January 2021, 15:47 | #18864 | Link | |
Thanks Pauly and Atak. |
17th January 2021, 02:34 | #18866 | Link | |
Grumpy Old Man.
Also a screenshot of another file from the same "set" (see attached) https://www.mediafire.com/file/r0ygk...eries.jpg/file That first screenshot I sent (other post) WAS thru mkvtoolnix However, if I run them thru Handbrake, they are fine, in DE..
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) |
17th January 2021, 10:43 | #18867 | Link |
Will you be ale to send original file? Trimmed 200MiB should be enough.
17th January 2021, 10:46 | #18868 | Link | |
Grumpy Old Man.
The original is just over 600mb (rar'ed up), not sure what to trim it with, that might affect it's problem... Let me know what you'd prefer...
17th January 2021, 12:04 | #18869 | Link |
If you have fast upload speed then send whole 600MiB to Mediafire.
17th January 2021, 12:43 | #18870 | Link | |
Grumpy Old Man.
Will send you a link, when it's ready.
17th January 2021, 13:21 | #18872 | Link | |
Grumpy Old Man.
I mentioned to you in FB Messenger that I loaded a job, and enabled those filters, and it worked ok. Hopefully Atak will have an answer...
17th January 2021, 13:24 | #18873 | Link | |
Grumpy Old Man.
https://www.mediafire.com/file/xy2t8.../Ep_4.rar/file I just hope that it has the same errors for you, as it did for me...
17th January 2021, 14:15 | #18874 | Link |
Incorrect AviSynth+ version? EncodingServer.exe shows what AviSynth version you have installed at the bottom field.
17th January 2021, 14:40 | #18875 | Link | |
example from video.mkv.lwi Code:
<LSMASHWorksIndexVersion=0.0.2.0> <LibavReaderIndexFile=16> <InputFilePath>C:\Temp\RipBot264temp\job2\video.mkv</InputFilePath> <FileSize=625585425> <FileHash=0x65d6f4a4> <LibavReaderIndex=0x00000000,0,matroska,webm> <ActiveVideoStreamIndex>+0000000000</ActiveVideoStreamIndex> <ActiveAudioStreamIndex>-0000000002</ActiveAudioStreamIndex> <StreamInfo=0,0> Codec=27,TimeBase=1/1000,Width=720,Height=576,Format=yuv420p,ColorSpace=2 </StreamInfo> Index=0,POS=362,PTS=0,DTS=-9223372036854775808,EDI=0 Key=1,Pic=1,POC=0,Repeat=1,Field=1 Index=0,POS=9479,PTS=120,DTS=0,EDI=0 Key=0,Pic=2,POC=6,Repeat=1,Field=1 Index=0,POS=10636,PTS=40,DTS=40,EDI=0 Key=0,Pic=3,POC=2,Repeat=1,Field=1 Index=0,POS=10781,PTS=80,DTS=80,EDI=0 Key=0,Pic=3,POC=4,Repeat=1,Field=1 Index=0,POS=10924,PTS=240,DTS=120,EDI=0 Key=0,Pic=2,POC=12,Repeat=1,Field=1 Index=0,POS=12324,PTS=160,DTS=160,EDI=0 Key=0,Pic=3,POC=8,Repeat=1,Field=1 Index=0,POS=12478,PTS=200,DTS=200,EDI=0 Key=0,Pic=3,POC=10,Repeat=1,Field=1 Index=0,POS=12657,PTS=360,DTS=240,EDI=0 Key=0,Pic=2,POC=18,Repeat=1,Field=1 Index=0,POS=13920,PTS=280,DTS=280,EDI=0 Key=0,Pic=3,POC=14,Repeat=1,Field=1 Index=0,POS=14070,PTS=320,DTS=320,EDI=0 Key=0,Pic=3,POC=16,Repeat=1,Field=1 Index=0,POS=14263,PTS=480,DTS=360,EDI=0 Key=0,Pic=2,POC=24,Repeat=1,Field=1 Index=0,POS=15419,PTS=400,DTS=400,EDI=0 Key=0,Pic=3,POC=20,Repeat=1,Field=1 Index=0,POS=15562,PTS=440,DTS=440,EDI=0 Key=0,Pic=3,POC=22,Repeat=1,Field=1 Index=0,POS=15735,PTS=600,DTS=480,EDI=0 Key=0,Pic=1,POC=30,Repeat=1,Field=1 Index=0,POS=24816,PTS=520,DTS=520,EDI=0 Key=0,Pic=3,POC=26,Repeat=1,Field=1 Index=0,POS=24976,PTS=560,DTS=560,EDI=0 Key=0,Pic=3,POC=28,Repeat=1,Field=1 Index=0,POS=25164,PTS=720,DTS=600,EDI=0 Key=0,Pic=2,POC=36,Repeat=1,Field=1 Index=0,POS=26479,PTS=640,DTS=640,EDI=0 Key=0,Pic=3,POC=32,Repeat=1,Field=1 Index=0,POS=26656,PTS=680,DTS=680,EDI=0 Key=0,Pic=3,POC=34,Repeat=1,Field=1 Index=0,POS=26843,PTS=840,DTS=720,EDI=0 Key=0,Pic=2,POC=42,Repeat=1,Field=1 Index=0,POS=28110,PTS=760,DTS=760,EDI=0 Key=0,Pic=3,POC=38,Repeat=1,Field=1 Index=0,POS=28274,PTS=800,DTS=800,EDI=0
18th January 2021, 02:02 | #18876 | Link | |
Grumpy Old Man.
So let me try and get my head around this....the "decoder", which is Lsmash, correct ??, isn't "seeing everything" ??. So before you implemented Lsmash into RB, was it FFMPEG that was used ?? Can that still be used ?? It seems strange that RB's decoder has this problem with this type of file (and unfortunately I have a LOT of them), BUT Handbrake doesn't (not knowing what decoder HB uses). It would be nice NOT having to use HB, it just adds another step to the process, although there are a couple of advantages. Anyway, do you have any suggestions ?? or do I just carry on with the current workflow ?? Cheers & thanks again.
18th January 2021, 02:06 | #18877 | Link | |
Grumpy Old Man.
Just found the latest version of Avisynth...go and grab it https://github.com/AviSynth/AviSynthPlus/releases If you're unsure of which to download, pick AviSynthPlus_3.7.0_20210111_vcredist.exe
18th January 2021, 02:30 | #18878 | Link |
Grumpy Old Man.
Update's
Atak,
I've found a few "important" updates :- Avisynth 3.7.0 as in above post #18877 FFMPEG 20210106 https://ottverse.com/ffmpeg-builds/ L-Smash 12.12.2020 https://cloud.owncube.com/s/MXk3zBcZfNkrGF9 L-Smash 16.12.2020 https://cloud.owncube.com/s/C8SBjF53JTL7s73 https://forum.doom9.org/showthread.p...62#post1930562 also x265, 3.4+36 http://msystem.waw.pl/x265/ and x264, r3033 https://artifacts.videolan.org/x264/release-win64/
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 29th January 2021 at 11:41. |
18th January 2021, 08:50 | #18879 | Link |
KNLMeansCL also had an update for compatibility with recent AviSynth+ versions by pinterf: https://github.com/pinterf/KNLMeansCL/releases
18th January 2021, 13:43 | #18880 | Link |
Light MDGrain2
I wanted to give an example of what light MDegrain2 (thSAD value) can do for some files.
This is with Hickok (2017) 4K (Original source size of video is 50GB). Settings used CQ18 x265: No MDegrain: 12.80GB thSAD=100: 8.98GB thSAD=150: 5.45GB thSAD=200: 4.51GB This is all relative to the video. I suspect the film is recorded with a digital camera and there is very light grain structure. Then MDegrain can remove just this light grain and then it cleans up beautifully. Hard to believe the file with thSAD=200 is less than 1/10 it's original size I think it would be good to add an adjustable thSAD value to the UI. I had not mentioned this in the past, but for those that use MDegrain3, you should be aware of something I've noticed over the last couple of years. The temporal function of MDegrain3 uses three frames and this can lead to some odd looking results. For example, what I've found, depending on the movie, if the camera is still and someone turns their face, the skin texture will smooth out during the turn and then the texture returns when they stop moving. Just something to be aware of. I don't use MDegrain3 very often and I'm more reluctant to do so now since I've been noticing this. The size difference from MD2 compared to MD3 is not that great. For example, 22GB vs 25GB. For super grainy sources, MD3 still the way to go. |
