Old 10th January 2009, 20:54   #81  |  Link
CruNcher
CruNcher's Avatar
It's quiet common for a Video Engineer to use Hz instead of FPS especially if it's one from the Analog days
It is about Time
Old 10th January 2009, 22:42   #82  |  Link
IgorC
Originally Posted by Kurtnoise13 View Post
hey, I'm not stupid...It was just a notice.
Then why do you ask? Is there somethig odd?
Admit that you didn't know that. It's simply to see. That's not shamy. Many people don't know what is Hz, Watt, Volt, Ampère, Faraday, Henry.....
For many people Hz is just for audio measurements.
Imagine situation:
John: Hey, how is your dog?
Paul: My pet is fine.
Is that talk odd for you?
The same way Hertz and fps.
but quite unsual...
video frame != audio frame
It means that if boys are weighted in kg then girls can't be weight in kg. Right?
IgorC is offline   Reply With Quote
Old 10th January 2009, 23:23   #83  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
wtf...
I wasn't asking (did I posted a question ?)...It was just a notice. I quite *understand* that we can use Hz for this. Period. Damn.
mmh...you like to play, isn't it ? First, it's not weight but mass. And my point is : it's quite unusual to see in video tools fps measure expressed in Hz nowadays. That's all.
So, now back on topic. Did you try this encoder ?
Old 11th January 2009, 01:49   #84  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
wtf...
1) Mainconcept use Hz since more than 2 years for internal CLI test.
2) You have exactly the same quality output than Mainconcept SDK without AQ and FGO (exactly same PSNR and same speed). DivX use Mainconcept SDK 7.3.0.4316 core codec. DivX7 CLI or Converter are really poor tools if you compare with Cinevision from Sonic or Reference from Mainconcept.
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 11th January 2009, 10:20   #85  |  Link
Kurtnoise
Kurtnoise's Avatar
sure...it's in alpha stage. Hoping to have new features in the next builds.
Old 11th January 2009, 11:48   #86  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
No for me it's simply volontary limitation for Mainconcept SDK core from DivX Network. Mainconcept SDK is not in alpha and all the feature are well know since very long time (more than 2 years now). I have here really complete CLI from Mainconcept (2 years old) with all the fonctionality. DivX use internaly exactly the same tools. Here the command line that you can find in the h264vout.001 file from DivX Converter:
PrintProgress CalcQuality Buffering LiveMode NumThreads CpuOpt PicNumOffset FrameMBsMode Log2MaxFrameNum Log2MaxPOC WritePPS WriteSPS WriteSingleSEI WriteTS WriteEOS WriteAUD AnnexB StreamType NumUnitsInTick TimeScale PAR_Height PAR_Width SAR_Height SAR_Width SAR_IDC VUIFlags BlackLevel DenoiseStrengthC DenoiseStrengthY Lambda FGOStrength GrainOptimization QuantOptimization FastSBME FastMRME FastInterDecision FastIntraDecision HadamardTransform InsaneRDO EnableRDO OffsetsMatrixFile UseOffsetsMatrix ScalingMatrixFile UseScalingMatrix BetaOffset AlphaC0Offset DeblockMode EnableInter_PCM EnableInter_4x4 EnableInter_8x8 EnableInter_16x16 EnableIntra_PCM EnableIntra_4x4 EnableIntra_8x8 EnableIntra_16x16 ConstrainedME OutOfPicMVs SearchRange NumRefFrames WeightedBiPred WeightedPred SubBlockMode SubPelMode EnableME Pass StatFile MaskingStrength MaskingType CpbRemovalDelay CpbFullnessUnits CpbFullnessTarget CpbFullness CpbSize HssRate UseVclHRD UseNalHRD AvgBitrate CrOffset CbOffset QuantMax QuantMin QuantB QuantP QuantI RCMode IDRPeriod AdaptiveB EnableSCD PyramidCoding BFramesReference BFramesCount MinIntraPeriod MaxIntraPeriod SliceArgument SliceMode TopFieldFirst InterlaceMode LosslessCompression TransformType EntropyMode ChromaFormat Level Profile ColorSpace Height Width FramesCount StartFrame StatFileName ConfigFileName ReconstFileName TargetFileName SourceFileName
For me at this time DivX Converter is simply really useless and limited gui for Mainconcept SDK. Moreover the gui don't even use the lastest SDK build (7.5.xxxx from reference) or the more interessing build (7.4.xxxx from sonic with independant AQ strength for all mask MaskingStrengthCplx MaskingStrengthContr MaskingStrengthLuma).
Make MeGui support for this tools is at this time really useless because the codec from DivX is really crappy. x264 will always produce by far really better result.
Old 11th January 2009, 16:55   #87  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
crappy or not, the divx encoder is alpha1 and we all know what alpha1 means...
Old 11th January 2009, 17:21   #88  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Well problem is here ... Mainconcept SDK is not alpha at all ... since more than 2 years. And DivX encoder use the complete Mainconcept SDK binary with exactly the same command line. Really easy for DivX Network to compile executable with complete and native command line. Anyway DivX Network use really limited build ... and it's IMO completely volontary.
h264vout.001 from DivX Converter
7.3.0.4316 ... something like 08/2007 for this build
h264vout.001 from MC Converter
7.5.0.35746 ... 2008/10/02
You can if you want remplace the h264vout.001 file and DivX Converter or DivX Encoder Alpha 5 will work perfertly. DivX Converter or DivX Encoder Alpha 5 are not completely new encoder. It's just simple Mainconcept SDK core codec compilation.
Old 11th January 2009, 19:47   #89  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Here little sample with same speed for all AVC encoding.
I use simply insane speed setting for VC1 SDK.
http://jfl1974.free.fr/Sample/ParkRun_Ateme.mp4
http://jfl1974.free.fr/Sample/ParkRun_DivX7.mp4
http://jfl1974.free.fr/Sample/ParkRun_Mainconcept.mp4
http://jfl1974.free.fr/Sample/ParkRun_x264.mp4
http://jfl1974.free.fr/Sample/ParkRun_VC1MS.vc1
DivX7 AVC can potentialy produce exactly the same result than Mainconcept and certainely better with more recent build with more advanced HVS tools.
Little observation: Mainconcept SDK update stat file at each second pass. If you have problem with RC you can make Npass encoding.
Old 11th January 2009, 21:28   #90  |  Link
IgorC
I'm downloading the videos. Can I ask you to upload video to another server in future? free.fr is very slow. Maybe mediafire.com
cli, divx, encoder, h.264, tutorial
