Old 3rd December 2019, 21:30   #17921  |  Link
slalom
slalom's Avatar
Originally Posted by slalom View Post
Added both 1 & 3
I found the new scripts in custom script instead of Denoise, is that OK?
Do I need to put those filters on every PC, or just the main?
I get errors on every job with the custom filter
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
slalom is offline   Reply With Quote
Old 4th December 2019, 00:21   #17922  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Why didn't you use Avisynth -> Output speed?
Hi slalom,
I think you misunderstood this post....that frame rate was the original file, not the one(s) that I ended up with, as I ran out of patience, and didn't complete any of them
Not poorly done, just doin' it my way !!!
Live every day like it's your last, because one day, it will be !! (M$B)
Pauly Dunne is offline   Reply With Quote
Old 4th December 2019, 00:25   #17923  |  Link
Pauly Dunne
Grumpy Old Man.
Hi again, slalom,
I would doubt that you have to add these to every pc, ONLY the pc(s) that you queue up jobs on.
Servers just "help".
So what kind of error are you getting, as I have just gone thru the same process...initialy I had an error due to the name I gave the filters.avs.
Old 4th December 2019, 09:01   #17924  |  Link
ReinerSchweinlin
@Ripman
Iīve been where you are - trying to achieve beste quality while encoding - often getting quite high bitrates and sizes...
After many years of listening and comparing - today I simply do it this way:
If for any reason, the quality hast to be preserved a 100%, I simply do not re-encode and jusr mux the original Audio
For all other cases, the given presets are sufficient (in my opinion, maybe with age the ears don't pick up enough detail... ).
In rare cases where I really need something different than the ripbot presets, I turn to another tool and encode audio there (dmmediaencoder,hybrid,staxrip,etc...) and remux afterwards.
After all, when going for max quality/size ratio, the topic becomes quite subjective and you actualy have to listen to what you encoded intensively.. AAC-LC can be done in VBR, AAC_HE Multichannel can`t, some encoders sound better than others with different source materials, some scale better between channels...
your idea of having a ram-drive as temp is interesting - do you really get a relevant speed advantage over a SSD? Does it make a big difference if you encode for 10 hours and then save 1 minute ssd/ramdisk? Or is the speed difference more noticable?
Old 4th December 2019, 09:05   #17925  |  Link
ReinerSchweinlin
I donīt think so, since the main pc is compiling the scripts and simply servs them via the shared dir to the servers...
Other wise, the server on the main pc should run ok, all others not..
Since errors are everywhere, maybe there is a typo in the filters?
Do the jobs without the custom filter run smoothly?
Old 4th December 2019, 13:43   #17926  |  Link
slalom
slalom's Avatar
MDegrain1.avs
#Denoise
Loadplugin("C:\Program Files\RipBot264\Tools\AviSynth plugins\mvtools\mvtools2.dll")
super=MSuper(video,pel=2)
bv1=MAnalyse(super,blksize=8,isb=true,delta=1,overlap=4)
fv1=MAnalyse(super,blksize=8,isb=false,delta=1,overlap=4)
video=MDegrain1(video,super,bv1,fv1,thSAD=400)
MDegrain3.avs
#Denoise
bv2=MAnalyse(super,blksize=8,isb=true,delta=2,overlap=4)
bv3=MAnalyse(super,blksize=8,isb=true,delta=3,overlap=4)
fv2=MAnalyse(super,blksize=8,isb=false,delta=2,overlap=4)
fv3=MAnalyse(super,blksize=8,isb=false,delta=3,overlap=4)
video=MDegrain3(video,super,bv1,fv1,bv2,fv2,bv3,fv3,thSAD=400)
Saved at Tools\AviSynth plugins\Scripts\Custom
Still don't know what this is
Just make sure path in LoadPlugin is correct
The error is general
Error: The file 'E:\Temp\RipBot264temp\job204\video.264' could not be opened for reading: open file error.
Elapsed Time: 00h:03m:53s
Old 4th December 2019, 13:53   #17927  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
If servers encode chunks then problem is not in custom script.
Old 4th December 2019, 14:39   #17928  |  Link
Ryushin
Ryushin's Avatar
MDegrain3
For those using MDegrain3, don't forget to add MDegrain3 to the list of multiple processing threads in the Main Settings window tab.
Ryushin is offline   Reply With Quote
Old 4th December 2019, 15:25   #17929  |  Link
slalom
slalom's Avatar
Same for MDegrain1, right?
Old 4th December 2019, 16:12   #17930  |  Link
slalom
slalom's Avatar
I changed to mdegrain2 and it started
Can someone write the steps to add the extra filters and how to use them please?
Old 4th December 2019, 16:36   #17931  |  Link
byteshare
ByteShare
byteshare's Avatar
Easier to just uncheck it IMO. I haven't had problems that I've noticed at least.
There are two methods I know:
Method A: Copy/paste(or type) your script into the #Custom section
Method B: Save them as a .avs file in *RipBot\Tools\AviSynth plugins\Scripts\Custom, then select the custom script in the AVS settings.
If you have custom filters (IE not included with RipBot) I've found it easier to have them saved in the same location on all of the machines or you need to write your script to use the network path of the RipBot temp Tools folder (assuming you've saved them in the Tools folder of the main RipBot machine).
If you want more in-depth than that it gets quickly into the subject of how to use AVS, which is more likely IMO solved with specific questions or looking a guides such as: http://avisynth.nl/index.php/Getting_started
Old 5th December 2019, 12:06   #17932  |  Link
Ryushin
Ryushin's Avatar
Atak, what are you thoughts on on limiting threads to specific filters? What circumstances should they limited or not limited.
Old 5th December 2019, 12:11   #17933  |  Link
Atak_Snajpera
Mt should be used only If you do some heavy filtering. If you just resize then using prefetch threads may even decrease performance.
Old 5th December 2019, 13:41   #17934  |  Link
slalom
slalom's Avatar
I used that method with the avs files. I'll copy them now to the other PCs before adding new jobs
Old 5th December 2019, 17:12   #17935  |  Link
byteshare
ByteShare
byteshare's Avatar
Ah, well that explains it. I'm always using some filters that are heavy.
Old 5th December 2019, 21:24   #17936  |  Link
Ronski
Originally Posted by stryker412 View Post
I currently have a 2nd drive for ripbot encodes. What drive type do you suggest as a 2nd drive?
How about one of these https://hexus.net/tech/reviews/stora...cie-gen-4-ssd/ to go with the 570 board.
Ronski is offline   Reply With Quote
Old 5th December 2019, 21:55   #17937  |  Link
slalom
slalom's Avatar
I tried a new job. MDegrain1 was used. Clients were starting and stopping on a loop. I don't know what is wrong
Old 5th December 2019, 22:48   #17938  |  Link
byteshare
ByteShare
byteshare's Avatar
I haven't tried MDegrain1, usually SMDegrain (MD3-4) with KLMeans as the prefilter but when I do use just MEdgrain it is usually 2-4.
Does the video play the preview on the main machine? If not, what error.
What errors are you getting on the clients?
Other ideas if you're waiting for another response:
-Try setting up a sample job on the client machines and see if that can encode as well.
--If they don't work, see if you get an error in the AVIsynth preview video.
Old 5th December 2019, 23:34   #17939  |  Link
slalom
slalom's Avatar
There is a message, it says
Cannot load file 'C:/Program Files/RipBot264/Tools/AviSynth plugins/mvtools/mvtools2.dll' Platform returned code 126
(E:\Temp\RipBot264temp\Job332/job332_preview.avs, line 39)
this is line 39
#Denoise
and my path of the program is
D:\DirectCD\Program Setup Files\RipBot264v1.25.0
so the path is wrong, I have to edit the path in the plugin, right?
missed thet part completely when creating the custom avs files (1 & 2)
Old 6th December 2019, 01:09   #17940  |  Link
Pauly Dunne
Grumpy Old Man.
this is line 39
#Denoise
Hi slalom,
Here's my simple way of checking what the path on your setup is..
So, open any job in your queue.
Chose the Avisynth "button"
Click on the "Show Video Script" at the top left side of the little preview screen.
Scroll down 'til you see #Denoise (it might be empty)
Then at the "Denoise" options list, chose "MDegrain2", this will instantly show all the info under #Denoise, and there's the plugin path you have to use....
I hope that works for you...
