23rd March 2019, 13:47 | #4601 | Link | |
New version of AVS+ (2772 and older) got glitch with FFMS2 when using to encode audio.
I tried to use AVS+ to cut some scenes of video and audio to watch on my smartphone. After encode, video is OK but audio got some "noise". But when I tried to use "LWLibavAudioSource" instead of "FFAudioSource", It's OK. I used FFMS2 from here: https://forum.doom9.org/showthread.p...11#post1866411 Here's my simple script: Quote:
23rd March 2019, 14:17 | #4602 | Link | |
Formerly davidh*****
MT mode is not used. I'll try to whittle it down to a more minimal example, as currently I'm only seeing it happen with a combination of two filters. |
23rd March 2019, 14:53 | #4603 | Link |
@Wonkey
Frame Accurate source ? (although I guess frame should be cached anyways). EDIT: Maybe as debug assist, double frame height in constructor (vi.height), and return both frames stacked, maybe try ColorBars.ShowFrameNumber as source.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 23rd March 2019 at 14:59. |
23rd March 2019, 17:53 | #4604 | Link |
Ahhh, I think I've been an idiot. It didn't occur to me that, because my first filter is incomplete, it's not being entirely deterministic (only the first few columns are being written). And then it further didn't occur to me that when I call GetFrame on it twice, it is actually getting the frame twice, and not caching or anything - on the first GetFrame it's coming back with one set of garbage data and on the second GetFrame it's coming back with different garbage data. That was the discrepancy I was seeing with the second filter.
So the first filter is faulty (due to being a work in progress) but the second filter could also be a bit smarter. |
1st April 2019, 00:04 | #4605 | Link |
Can someone supply an updated 64 bit version of Variableblur?
My apologies in advance if this is the wrong thread to make such a request, but can someone supply a 0.7 64 bit version of Variableblur to replace the 0.5 version out there now? Thanks.
1st April 2019, 00:36 | #4606 | Link | |
I was gonna have a go at compile but requires VS2010 as per below
The 64 bit zip (via Wiki) on Archive.org seem not to be available. EDIT: The source has Assembler in it, so dont know if compilable for x64 on VS2010.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 1st April 2019 at 00:44. |
1st April 2019, 01:05 | #4607 | Link | |
Correct link is here: http://avisynth.nl/index.php/Variabl...ived_Downloads |
1st April 2019, 02:03 | #4608 | Link |
OK thanx RD, but v0.7 seems not available anywhere(wiki or d9, or archive.org) , so maybe somebody could do compile of SendSpace in my sig zip
(the v0.5 x64 source also has Assembler, so I presume that it is actually compilable in VS2010). EDIT: I spent some time searching web but could not find v0.7 x64, dll or source.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 1st April 2019 at 02:06. |
1st April 2019, 06:01 | #4609 | Link | |
There is none, v0.5 is the only x64 version available . |
2nd April 2019, 14:55 | #4610 | Link |
Sorry if this is yet another inane and obvious question, but is there a recommended/simple way to change video clip properties/colourspace/subsampling? Like if I get an 8-bit clip, but I want my filter to output a 16-bit or float clip while keeping all other properties the same (or doing something else like changing subsampling to 444, whatever the input is), is there a simple operation that will do this, and work for all inputs, including interleaved and planar RGB? Or are there always caveats?
2nd April 2019, 15:04 | #4611 | Link |
http://avisynth.nl/index.php/AviSynth%2B
http://avisynth.nl/index.php/Convert Easiest way to convert to 16bit is ConvertBits(16). But not all filters support filtering in 16bit.
3rd April 2019, 08:20 | #4613 | Link | |
Example for bit depth change |
3rd April 2019, 14:57 | #4614 | Link | |
Enabling MT together with returning a clip explicitly does not work as expected.
I created a test script for a more elaborate filtering, producing different alternative clips, and I let it return one of these clips to be able to switch quickly between different versions. The AviSynth Wiki – AviSynth+: Enabling MT tells: Quote:
PHP Code:
PHP Code:
Script error: Invalid arguments to function 'Prefetch'. (...\PrefetchTest.avs, line 2) PHP Code:
PHP Code:
3rd April 2019, 15:07 | #4615 | Link |
Yes it is. Ferenc will correct me if I'm wrong.
Groucho's Avisynth Stuff |
3rd April 2019, 17:27 | #4617 | Link |
ProtoType extracted by RT_Stats Make_Avisynth_BuiltIn_FunctionList.avs
AviSynth+_0.1_(r2772,_MT,_i386)_ORDERED_Function_List.txt Code:
AviSynth+_0.1_(r2772,_MT,_i386)_ORDERED_Function_List There follows a list of all function names together with CPP style argument specifiers that inform Avisynth the argument types and optional names. Optional arguments have square brackets surrounding their name as in [name] and are followed by a type specifier character that gives the type. Unnamed arguments are not optional. eg "cc[arg1]b[arg2]i" would be two compulsory unnamed clip args, followed by optional 'arg1' of type bool and optional 'arg2' of type int. # Argument type specifier strings. c - Video Clip i - Integer number f - Float number s - String b - boolean . - Any type (dot) # Array Specifiers i* - Integer Array, zero or more i+ - Integer Array, one or more .* - Any type Array, zero or more .+ - Any type Array, one or more # Etc ################################### Prefetch "c[threads]i"
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 3rd April 2019 at 18:35. |
3rd April 2019, 23:44 | #4619 | Link |
Avisynth language lover
What if the Prefetch call is followed by a return, but 'last' has been assigned somewhere earlier?
ColorBarsHD(1280, 720, "YV24") # 'last' assigned here c = KillAudio().AssumeFPS(25, 1).Trim(0, 249) Prefetch(4) return c Does it ever make sense to follow Prefetch() by a return statement? Perhaps instead of Prefetch(4) return x you always need to write return x.Prefetch(4) Last edited by Gavino; 3rd April 2019 at 23:49. |
4th April 2019, 00:06 | #4620 | Link | |
Yo big G, thats a long walkabout that you're on, come back when you've found youself, yeh.
Here Differences between Avisynth NEO and Avisynth+ (current versions). Seems that we are detecting multiple prototypes for builtins, but not detecting proper separate parameter strings for each, but still handy non the less. No idea what NEO 'n' type specifiers are [perhaps array index or something]. Code:
There follows a list of all function names together with CPP style argument specifiers that inform Avisynth the argument types and optional names. Optional arguments have square brackets surrounding their name as in [name] and are followed by a type specifier character that gives the type. Unnamed arguments are not optional. eg "cc[arg1]b[arg2]i" would be two compulsory unnamed clip args, followed by optional 'arg1' of type bool and optional 'arg2' of type int. # Argument type specifier strings. c - Video Clip i - Integer number f - Float number s - String b - boolean . - Any type (dot) # Array Specifiers i* - Integer Array, zero or more i+ - Integer Array, one or more .* - Any type Array, zero or more .+ - Any type Array, one or more # Etc ################################### Differences between Avisynth NEO and Avisynth+ ############################################## AviSynth_Neo_0.1_(r2822,_Neo,_i386)_ORDERED_Function_List AviSynth+_0.1_(r2772,_MT,_i386)_ORDERED_Function_List AddProp "csn" AlignedSplice "cci" AlignedSplice "cc+" AlignedSplice "cci" AverageChromaU "c[offset]i" AverageChromaU "ci" AverageChromaV "c[offset]i" AverageChromaV "ci" AverageLuma "c[offset]i" AverageLuma "ci" AVIFileSource "s+[audio]b[pixel_type]s[fourCC]s[vtrack]i[atrack]i" AVIFileSource "s+[audio]b[pixel_type]s[fourCC]s[vtrack]i[atrack]i[utf8]b" AVISource "s+[audio]b[pixel_type]s[fourCC]s[vtrack]i[atrack]i" AVISource "s+[audio]b[pixel_type]s[fourCC]s[vtrack]i[atrack]i[utf8]b" ChromaUDifference "cc" ChromaUDifference "cci" ChromaVDifference "cc" ChromaVDifference "cci" ConditionalFilter "cccn[show]b" ConditionalFilter "cccs[showx]b[args]s[local]b" ConditionalFilter "cccn[show]b" ConditionalFilter "cccs[showx]b[args]s[local]b" ConditionalFilter "cccn[show]b" ConditionalSelect "cnc+[show]b" ConditionalSelect "csc+[show]b" ConditionalSelect "cnc+[show]b" DumpFilterGraph "c[outfile]s[mode]i[nframes]i[repeat]b" FrameEvaluate "cs[show]b[after_frame]b" FrameEvaluate "cs[showx]b[after_frame]b[args]s[local]b" Func "n" GeneralConvolution "c[bias]i[matrix]s[divisor]f[auto]b" GeneralConvolution "c[bias]f[matrix]s[divisor]f[auto]b[luma]b[chroma]b[alpha]b" GetProp "cs[offset]i" IsFunction "." LumaDifference "cc" LumaDifference "cci" OnCPU "n" OnCPU "n" OnCUDA "n[device_index]i" OnCUDA "n[device_index]i" OpenDMLSource "s+[audio]b[pixel_type]s[fourCC]s[vtrack]i[atrack]i" OpenDMLSource "s+[audio]b[pixel_type]s[fourCC]s[vtrack]i[atrack]i[utf8]b" Prefetch "c[threads]i[frames]i" Prefetch "c[threads]i" RGBDifference "cc" RGBDifference "cci" RGBDifferenceFromPrevious "c" RGBDifferenceFromPrevious "ci" RGBDifferenceToNext "c[offset]i" RGBDifferenceToNext "ci" ScriptClip "cn[show]b[after_frame]b" ScriptClip "cs[showx]b[after_frame]b[args]s[local]b" ScriptClip "cn[show]b[after_frame]b" SegmentedAVISource "s+[audio]b[pixel_type]s[fourCC]s[vtrack]i[atrack]i" SegmentedAVISource "s+[audio]b[pixel_type]s[fourCC]s[vtrack]i[atrack]i[utf8]b" SetCacheMode "[mode]i" SetDeviceOpt "[opt]i[val]i" SetGraphAnalysis "b" SetMemoryMax "[]i[type]i[index]i" SetMemoryMax "[]i" TypeName "." UDifferenceFromPrevious "c" UDifferenceFromPrevious "ci" UDifferenceToNext "c[offset]i" UDifferenceToNext "ci" UnalignedSplice "cci" UnalignedSplice "cc+" UnalignedSplice "cci" UPlaneMax "c[threshold]f[offset]i" UPlaneMax "c[threshold]fi" UPlaneMedian "c[offset]i" UPlaneMedian "ci" UPlaneMin "c[threshold]f[offset]i" UPlaneMin "c[threshold]fi" UPlaneMinMaxDifference "c[threshold]f[offset]i" UPlaneMinMaxDifference "c[threshold]fi" UseVar "cs+" VDifferenceFromPrevious "c" VDifferenceFromPrevious "ci" VDifferenceToNext "c[offset]i" VDifferenceToNext "ci" VPlaneMax "c[threshold]f[offset]i" VPlaneMax "c[threshold]fi" VPlaneMedian "c[offset]i" VPlaneMedian "ci" VPlaneMin "c[threshold]f[offset]i" VPlaneMin "c[threshold]fi" VPlaneMinMaxDifference "c[threshold]f[offset]i" VPlaneMinMaxDifference "c[threshold]fi" WAVSource "s+" WAVSource "s+[utf8]b" WriteFile "c[filename]sn+[append]b[flush]b" WriteFile "c[filenamex]ss+[append]b[flush]b[args]s[local]b" WriteFile "c[filename]sn+[append]b[flush]b" WriteFileEnd "c[filename]sn+[append]b" WriteFileEnd "c[filename]ss+[append]b" WriteFileEnd "c[filename]sn+[append]b" WriteFileIf "c[filename]sn+[append]b[flush]b" WriteFileIf "c[filenamex]ss+[append]b[flush]b[args]s[local]b" WriteFileIf "c[filename]sn+[append]b[flush]b" WriteFileStart "c[filename]sn+[append]b" WriteFileStart "c[filename]ss+[append]b" WriteFileStart "c[filename]sn+[append]b" YDifferenceFromPrevious "c" YDifferenceFromPrevious "ci" YDifferenceToNext "c[offset]i" YDifferenceToNext "ci" YPlaneMax "c[threshold]f[offset]i" YPlaneMax "c[threshold]fi" YPlaneMedian "c[offset]i" YPlaneMedian "ci" YPlaneMin "c[threshold]f[offset]i" YPlaneMin "c[threshold]fi" YPlaneMinMaxDifference "c[threshold]f[offset]i" YPlaneMinMaxDifference "c[threshold]fi" Also contains complete function lists for these versions of avisynth. Code:
# AviSynth v2.58 AviSynth 2.58, build:Dec 22 2008 [08:46:51] # AviSynth v2.60 AviSynth 2.60, build:Mar 31 2015 [16:38:54] # AviSynth v2.61 Alpha AviSynth 2.61, build:May 17 2016 [16:06:18] VC2008Exp # Avisynth v2.60 ICL AviSynth 2.60 (ICL10) # Avisynth V2.60 MT AviSynth 2.60, build:Feb 20 2015 [03:16:45] # Avisynth+ v2.60 AviSynth+ 0.1 (r2772, MT, i386) AviSynth+ 0.1 (r2772, MT, x86_64) # Avisynth NEO AviSynth Neo 0.1 (r2822, Neo, i386) AviSynth Neo 0.1 (r2822, Neo, x86_64) # Avisynth NEO Forerunner Avisynth+ CUDA AviSynth+ 0.1 (r2533, CUDA, i386) AviSynth+ 0.1 (r2533, CUDA, x86_64) EDIT: Perhaps 'n' is name, ie function name, variable name, device name.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 4th April 2019 at 00:37. |
