Old 9th January 2024, 07:24   #20381  |  Link
nakTT
Hi, where can I download the latest version?
nakTT is offline   Reply With Quote
Old 9th January 2024, 10:43   #20382  |  Link
tebasuna51
tebasuna51's Avatar
https://forum.doom9.org/showthread.p...53#post1995953
Old 12th January 2024, 00:11   #20383  |  Link
darkio
Hi Atak, please, can you update qtgcm avsi script in ripbot264 ?
darkio is offline   Reply With Quote
Old 12th January 2024, 01:28   #20384  |  Link
FTLOY
Friend of a friend..
FTLOY's Avatar
I know you meant QTGMC....
Yes, the included build is pretty old, v3.33, and the latest available is v3.83.
Go here, download it, rename it, and copy into the scripts folder, and see if it does what you want.
http://avisynth.nl/index.php/QTGMC
Or if you're feeling adventurous, you could try an even newer version from Dogway...
https://github.com/Dogway/Avisynth-S.../QTGMC%2B.avsi
FTLOY is offline   Reply With Quote
Old 12th January 2024, 08:21   #20385  |  Link
darkio
hi ftloy,
thanks for your reply.
I have already tried to replace the script but I get errors.
Maybe I need to add or update some dependent dlls.
I will check better later.
Old 12th January 2024, 09:46   #20386  |  Link
FTLOY
FTLOY's Avatar
hi ftloy,
OK,
You may have to update these, then :-
http://avisynth.nl/index.php/QTGMC#Requirements
It seems that newer builds require Zs_RF_Shared, which RB hasn't got.
You will probably have to write a Custom script to use later builds.
Old 13th January 2024, 15:15   #20387  |  Link
slalom
slalom's Avatar
Open RipBot264.ini and change this line with [top,right,bottom,left]
JobWindowDefaultPosition=center
Ok, that worked
Something else, I have a job and this file
1_audio_English_DEFAULT_DELAY4379ms.thd
audio delay is not added in the end
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
slalom is offline   Reply With Quote
Old 25th January 2024, 12:12   #20388  |  Link
Superkolobok
Hi
Is it possible to make a button to rotate video instead of using this ?
video=turnleft(video)
video=turnright(video)
Thank you
Superkolobok is offline   Reply With Quote
Old 26th January 2024, 11:48   #20389  |  Link
FTLOY
FTLOY's Avatar
Originally Posted by Superkolobok View Post
Hi
"D:\RipBot264v1.27.1\Tools\AviSynth plugins\Scripts\Custom"
Thank you
Hi, have you been using RipBot for very long ??
So, I think the easiest way to get this done, is create a Custom script with that command in it, and then you can use it whenever you need to.
add this into Notepad :-
#Custom
save and rename it to turnright.avs, then copy it to here--(do the same for the left)
then you can access it from the "Custom Scripts" drop down list, from within the Avisynth Filters for that particular Job, and it will be there everytime you need it, so there's your button
Old 27th January 2024, 18:17   #20390  |  Link
slalom
slalom's Avatar
The "add cover" feature is broken again
Old 30th January 2024, 20:10   #20391  |  Link
Ryushin
Ryushin's Avatar
Yea, doesn't work for me in batch mode. There was a bug not that long ago that replaced the cover with another one that I used when creating a single job. Not sure if that bug was fixed or not since adding cover to batch mode is not working at the moment.
Ryushin is offline   Reply With Quote
Old 14th February 2024, 02:07   #20392  |  Link
cypher007
noticed a odd bug with Blade Runner final cut. doing a 2 pass down to 23800mb there is a short section at 58:47 aprox were the image breaks up into lots of pixels then clears. i didnt notice it until recently so i re did the encode from the same source and its still there. its almost like when a video file isnt quite finished downloading and you try and play it.
cypher007 is offline   Reply With Quote
Old 14th February 2024, 02:14   #20393  |  Link
FTLOY
FTLOY's Avatar
So I have to ask the obvious....
Is the original OK ?
Maybe you need to acquire or rip it again.
Old 14th February 2024, 20:21   #20394  |  Link
cypher007
yep original fine at same point. going to try the slow profile rather than default and see if it goes away.
Old 15th February 2024, 19:14   #20395  |  Link
cypher007
that fixed it. guess it had something to do with the people walking close to the camera that are effectively like a black wipe left to right and right to left in the scene, im guessing the encoder dropped the bit rate and then got caught out by the sudden increase in detail.
might run another encode using default but turn off fast first pass see what that does.
Old 16th February 2024, 00:54   #20396  |  Link
FTLOY
FTLOY's Avatar
that fixed it. guess it had something to do with the people walking close to the camera that are effectively like a black wipe left to right and right to left in the scene, I'm guessing the encoder dropped the bit rate and then got caught out by the sudden increase in detail.
Don't ya love it, when a hunch pays off
If your next test proves something, that's even better, however, I guess that's just what can happen, when doing 2 pass encodes, with those settings.
Good luck.
Old 21st February 2024, 07:17   #20397  |  Link
FTLOY
FTLOY's Avatar
I am getting an interesting but annoying error with adding extra audio tracks when also editing with the segment feature.
If I add a 2nd or 3rd audio track (same original track, just different encoding format, AC3, or AAC or Flac, etc), and when encoding using DE, it gets to the last chunk, it progresses to a random %, then restarts, and it will NEVER finish .
It's fine with only 1 track, tho.
I have tried it on several different sample clips, just to practise the segment editing, so thank goodness it's not a full length movie.
Old 25th February 2024, 13:15   #20398  |  Link
cypher007
update
did the same file with default speed but slow first pass and it also worked fine.
Old 26th February 2024, 13:40   #20399  |  Link
valnar
How does one change the strength of MDegrain in batch mode?
Attachments Pending Approval
File Type: jpg batch1.jpg
valnar is offline   Reply With Quote
Old 26th February 2024, 14:00   #20400  |  Link
FTLOY
FTLOY's Avatar
I actually had to double check this, but it's easy...
On the batch setup page, choose the "CPU Denoise" drop down list, all 3 MDegrain are selectable.
BTW, attaching a picture (or similar) can take a LONG time to be approved, and viewable...
