Old 17th June 2017, 10:32   #1  |  Link
ultron
Problems creating a externally playable dvd with Devede
Hello, I was trying to pass a video file to a dvd-r to use in an external dvd, saw a thread on ask ubuntu about it and there is mentioned devede. Decide to try it, but I am experiencing problems trying to do two different things.
The first is when I try to create a playable dvd with a single video file. When trying to create it, a pop up window shows up saying:
Failed to create the BIN/CUE files. Maybe you run out of disk space
However, there is an option called:
Media size:
where I putted the option
700 MB CD
. And I have more than 1GB of free space. Nonetheless, running it through command line it says
currentfile is: /home/leopoldo/movie/movie_01_01.mpg
Launching shell program: ln -s "/home/leopoldo/videos/Gilmore.Girls.S01/gilmore.girls.1x01.pilot.dvdrip.dual.xvid-vermi.avi" "/home/leopoldo/movie/movie_01_01.mpg"
Launching program: vcdimager -c /home/leopoldo/movie/movie.cue -b /home/leopoldo/movie/movie.bin -t vcd2 /home/leopoldo/movie/movie_01_01.mpg
elemento: /usr/bin
++ WARN: initializing libvcd 0.7.23 [linux-gnu/x86_64]
++ WARN:
++ WARN: this is the Beta development branch!
++ WARN: use only if you know what you are doing
++ WARN: see http://www.hvrlab.org/~hvr/vcdimager/ for more information
++ WARN:
++ WARN: mpeg scan: pack header code (0x000001ba) expected, but 0x52494646 found (buflen = 2324)
++ WARN: ...this looks like a RIFF header but a plain multiplexed program stream was required.
**ERROR: input mpeg stream has been deemed invalid -- aborting
Creating window /usr/share/devede/werror_dialog.ui
So there is something wrong with the header? Is there a way to fix it?
The other problem shows up when combining subtitle with a video file.
Doing the same as before but adding a srt file through the menu options I get stuck with a pop up window saying:
Adding subtitles to filename.avi
1/3
STAT: 0:00:02
that stays on this state eternally. Running devede through command line it says:
Launching shell program: cp "/home/leopoldo/videos/filename.avi" "/home/leopoldo/movie/movie_01_01.mpg"
Trying to create /home/leopoldo/movie/movie_sub.xml
Launching shell program: iconv -f ISO-8859-1 -t UTF8 "/home/leopoldo/videos/subtitlename.srt" -o "/home/leopoldo/movie/movie_sub_tmp.sub"
FPS sub 1 original
FPS sub 2 final
Launching shell program: spumux -m svcd -s 0 "/home/leopoldo/movie/movie_sub.xml" < "/home/leopoldo/movie/movie_01_01.mpg" > "/home/leopoldo/movie/movie_01_01.mpg.sub"
DVDAuthor::spumux, version 0.6.14.
Build options: gnugetopt magick iconv freetype
Send bugs to <dvdauthor-users@lists.sourceforge.net>
INFO: Locale=en_US.utf8
INFO: Converting filenames to UTF-8
INFO: Detected subtitle file format: subviewer
INFO: Opened iconv descriptor. *UTF-8* *UTF-8*
INFO: Read 547 subtitles
INFO: Unicode font: 5025 glyphs.
INFO: Skipped 17758 bytes of garbage
Even closing devede, spumux keeps running, using 100% of cpu.
On this case I think I can use ffmpeg to embed the subtitles in the video file , but it would be nice to fix it other way.
ultron is offline   Reply With Quote
Old 26th June 2017, 14:39   #2  |  Link
manolito
manolito's Avatar
Hi Ultron,
looks like nobody on this forum is familiar with Devede...
I did use it quite a bit, and I still have it installed on my WindowsXP machine. Some things you should clarify:
Are you under Ubuntu or Windows?
Is your target format a Video DVD or a VCD? You mentioned that you wanted to create a DVD, but your settings indicate that you instructed Devede to create a VCD.
For a DVD you need to select the top button (Video DVD), and your target size should be 4.7GB for a single layer blank and 8.5GB for a dual layer blank. In this case Devede will not try to create BIN and CUE files, it will author a DVD structure instead (a VIDEO_TS folder).
I am not familiar with subtitles, you should ask in the Devede support forum.
Cheers
manolito
Old 31st July 2017, 22:30   #3  |  Link
ultron
Thanks, I was able to successfully create a video dvd doing what you said. However what I really wanted to do was to be able to play the video files without changing them or to reduce their files, and at the time I wrote the topic, I thought the option to use them without modifications was only available under the vcd option (it wasn't).
In the end, I was able to directly play the video files on the player even without devede, so i ended being useless for me, since I don't need devede to write them to a dvd without modifications and the VideoCD option actually increases the size of the video files a little bit.
So I will end writing the files directly or using ffmpeg with libdivx to create my own reduced video files.
[IMG] code is Off
