#1241 | Link | |
#1242 | Link |
@Lowpro
Good to hear that you're making progress on this project. I'm wondering what the end product will look like. And how much know-how of BDedit it will need from us. Your work on the BDMV tab so far is all new terrain for me. I'm more familiar with how the PLAYLIST and CLIPINF tabs work. But I guess you will get us in the right direction and making a manual is also part of the project. Last edited by musiclover; 1st August 2024 at 17:11. |
#1243 | Link | |
#1244 | Link |
I'm making significant progress on my Universal Blu-ray Authoring Template this weekend. In the process I gave my GPR (General Purpose Register) scheme a complete overhaul. I also finished building out the third tier of the Blu-ray menus, cases where a given bonus feature has sub-menu items to choose from. (To check it out see my previous post, here.) Included is the ability to determine the "Play" behavior for each set of sub-menu items, i.e. whether a given menu item plays the "Title" its linked to or a "Chapter" from said title based on its button id. In any event, just thought I'd share. Hope everyone is having a nice weekend. Time to put BDedit to bed and call it a day.
#1245 | Link | |
I have received an email asking me to download a new version of BDedit (0.58b9).
I get an error when trying to access the IGS menu from the CLIPINF tab. The error that can be read in the pop-up window is this one: Quote:
#1247 | Link |
Hi Pel. Just replied to your email from the other day. The CLIPINF tab is giving me an error as well, "Access violation at address 004057EC in module 'BDedit v0.58b9'. Read of address DB5EC922." Look forward to testing out the next revision.
#1251 | Link |
Pel, using 056b7 (I see I'm a little old on that version so I have just donated for the new version so I'm not sure if this has been fixed?)
I have my Win10 scaling to 125 and now I can't get to some of the entries. Specifically I have an attached image to show in the Playlist screen I can't adjust the STN, under that area you can see the Video\Audio\Subtitle window the entry cannot be changed as it is not 'open' enough (next to play item where it gives the type of stream). I had to adjust some other areas of BdEdit to be able to see everything ok but this section cannot be adjusted. I have tried all the 'HIGHDPI" settings in Windows to no avail unfortunately. So at the moment the only way to edit that section where I need to do often is to set my Windows back to 100 scaling and then return to 125 after use. Is there anyway to be able to adjust this section for custom scales? |
#1252 | Link |
Pel, I received the new version (058b10) - Thank you for that.
You can also disregard the post just above. The issue was with a program called 'Windows10DPIFIX' - the program uses the Win8 DPI settings to ensure that older programs (like IMGBurn) do not look blurry when scaled up in size (in my case to 125). It works great for these older programs to not look so blurry but I suppose something with it and BDEdit don't work well together. As soon as I stopped using that and reverted back to the Windows 10 scaling settings BDEdit was fine once again (though IMGBurn is blurry again LOL). |
#1253 | Link | |
#1254 | Link |
Lowpro: Alas no such luck for me regarding dual monitors!
Interesting stuff I see you have going on with the 'Universal Blu-ray Authoring Template'. And FYI I still am using the process we came up with for adding in subtitles (& keeping menu) for UHD titles when I need it.
#1256 | Link | |
Is this error present even if you don't change anything in the playlist?
BDedit |
#1257 | Link | |
and yes even not change playlist, it gets error I try to check old version. After .54b2, it gets this error. Last edited by no-one; 25th November 2024 at 07:20. |
| Tags |
| bd menu, bdedit, blu-ray |
| Display Modes | |
