Old 16th March 2010, 21:57   #261  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
There is no (simple) way to re-create java based menus or to detect if a title has a pop-up menu. For IGS it is easy (menus are either muxed with the movie or in separate files). For Java discs you need to de-compile the jars to find what each BDJO object does.
Old 17th March 2010, 13:13   #262  |  Link
Pelican9
Coder
Pelican9's Avatar
I've completely rewritten the graphic engine, so the next version can handle transparency, in and out effects, background picture, full screen or 1:1 view, etc.
Pelican9 is offline   Reply With Quote
Old 17th March 2010, 15:04   #263  |  Link
PurpleMan
Looks nothing short of amazing! Good work, and thank you!
PurpleMan is offline   Reply With Quote
Old 19th March 2010, 15:49   #264  |  Link
Pelican9
Coder
Pelican9's Avatar
New version is available (v0.22b)
Edit:
After two days hard debugging I've finished the new version.
If somebody try it please write a short feedback here.
I'm looking for a clpi file with font names in the ClipInfo window and a bdjo file with more than one line in the ApplicationManagementTable window.
For those who want to see more hexadecimal number on the screen I've made some new window in BDedit...
Changes for v0.22
- Rewritten graphic engine for menu displaying
- Show InEffects and OutEffects including palette changing and cropping in realtime (option to disable)
- Built-in background graphic and loadable background image
- Two view modes: 1:1 or fit-to-window (keep aspect ratio)
- Selectable bitmap preloading
- New infos on CLIPINF tabsheet: ClipInfo, CPI, ExtensionData
- Play button for an external player to play m2ts on CLIPINF
- New tabsheet: BDJO Read xxxxx.bdjo (AppCacheInfo,TableOfAccessiblePlayLists, KeyInterestTable, TerminalInfo, FileAccessInfo, ApplicationManagementTable)
- Minor bugfixes (and a strange one)
Old 20th March 2010, 04:36   #265  |  Link
setarip_old
setarip_old's Avatar
@Pelican9
Hi!
In light of your earlier efforts with EVOdemux, perhaps you can share your knowledge of HD-DVD chaptering and timestamps with "deank", who has provided us with the ability to convert BluRays to HD-DVDs?
setarip_old is offline   Reply With Quote
Old 20th March 2010, 06:25   #266  |  Link
Pelican9
Coder
Pelican9's Avatar
I can definitely do that but I think he knows much more than me about both of the blue formats...
Old 20th March 2010, 10:28   #267  |  Link
crl2007
Great work. Now is faster, well organized, it won't be a hassle at all to later edit the menu. Congratulations.
crl2007 is offline   Reply With Quote
Old 20th March 2010, 19:20   #268  |  Link
deank
deank's Avatar
Not enough about the RED (HD-DVD) format
I need to recreat the ff/rew tables in the IFO files for chapter jumps. It may seem easy for the guys that know DVD format, but not to me. If you can help with that it will be much appreciated.
Dean
Old 20th March 2010, 20:03   #269  |  Link
Pelican9
Coder
Pelican9's Avatar
Dean
Sorry but I had have information about the EVO file only...
I saw an IFO file last time in IFOedit but it was a few years ago
I guess you don't have documentation...
But there is a HD-DVD mux program, maybe the writer(s) of it can help.
Old 20th March 2010, 20:41   #270  |  Link
deank
deank's Avatar
Well he's in-and-out for the last year and being not much of a helper... and he used Nero-created IFO files for base (without chapters).
Reverse engineering is really a though thing to do.
Old 20th March 2010, 21:43   #271  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
I have just picked up Ulead DVD-MF 6+ with HD-DVD muxing capabilities for 40 USD + tax,
maybe I can help with some passes...
Old 21st March 2010, 11:10   #272  |  Link
chompy
Hi, here you have some bdjo with more than one line:
http://www.mirrorcreator.com/files/1...bdjo.rar_links
When you say you need clpi file with font names, what do you mean? I have some with ATC_delta_entries (all of them are clipcodec m2ts), it's that what you're looking for?
Greetings
chompy is offline   Reply With Quote
Old 21st March 2010, 12:53   #273  |  Link
Pelican9
Coder
Pelican9's Avatar
New version: v0.23b
A new snapshot is available to download.
Changes for v0.23
- Rewritten button animation (animate on/off, all button states)
- More double click follow
- Improved tracing
- bug fixes
No. If the application type text subtitle then there are a table with font files above the ATC deltas. But I have received that from someone else.
Old 22nd March 2010, 09:31   #274  |  Link
crl2007
I have a problem with a Blu-Ray IGS menu. When I choose to see the IGS from CLIPINF TAB it spits out this error:
Does this with almost every Blu-Ray, even if I let them on disc or if I rip them to my hdd.
Old 22nd March 2010, 14:15   #275  |  Link
Pelican9
Coder
Pelican9's Avatar
Could you send the smallest clpi and m2ts to me?
Which version?
Old 22nd March 2010, 14:23   #276  |  Link
crl2007
The last version. I will send you the files.
LE: You have PM.
Old 22nd March 2010, 18:13   #277  |  Link
Pelican9
Coder
Pelican9's Avatar
New version v0.24b
Changes for v0.24
- There is a mandatory delay at the program start for 10 sec.
Every copy of BDedit has a serial number since v0.17
You can register this serial with donation (min. 10 EUR) or lot of help.
Registered users skip the waiting procedure.
- Bug fixes with IGS load and tracing commands
LE: You have PM.
Received.
You have a PM too.
Old 23rd March 2010, 00:33   #278  |  Link
crl2007
Tested now and that IGS with problems is loaded fine.
LE: Spoke too soon. I found 2 new bugs.
1.
The navigation does not work when you try to select buttons from the second page of the menu.
2. After the first thing happens, you can't return to 1st page either, so you try to close the program and re-read the disc. In this moment, an entire wall of "access violation" errors appear. They literally covered my desktop. I had to use Ctrl + Alt + Del and end the bdedit process. Tried three times, the same result. I just wanted to be sure that it's not an isolated event. It's the same disc that had that error from above.
Old 23rd March 2010, 01:27   #279  |  Link
Pelican9
Coder
Pelican9's Avatar
1. The navigation does not work when you try to select buttons from the second page of the menu.
2. After the first thing happens, you can't return to 1st page either, so you try to close the program and re-read the disc. In this moment, an entire wall of "access violation" errors appear. They literally covered my desktop. I had to use Ctrl + Alt + Del and end the bdedit process. Tried three time, the same result. I just wanted to be sure that it's not an isolated event. It's the same disc that had that error from above.
The first one is not a bug (usually), you have to check what the program do.
Usually the button programs expect a lot of presetting GPR and PSR values and as I can tell these programs are very unoptimized (even this one you sent me today) and easily turn to an infinite cycle (Is this the term for a never ending program?).
You strongly recommended to run the program step by step, see which register need a value to go further. Before every step you can set the registers, so you can navigate the program in to the right direction.
Start the program at the page zero and don't change the page manually it will change by the SetButtoPage commmand.
You can run the movie object commands before you start the menu because the two command sets are using the same registers, but it's not an easy task to follow this mess.
The second one is definitely a bug I will play with it.
Edit: You can stop the constant loop just tick the trace checkbox.
Edit2: Could you send me the two bdmv files for this?
Old 23rd March 2010, 08:55   #280  |  Link
crl2007
Yes. You have a PM.
LE: Tested again with the trace checkbox ticked and the menu pages do not unfold. Just shows me the commands but when I choose U D L R Sel still nothing happens. And a second part of a menu appears in the top part of the screen. I've made 2 screenshots.
The second portion.
The normal part.
If you want, I can give you access to my computer through TeamViewer and test this out more.
bd menu, bdedit, blu-ray
