Old 9th March 2025, 15:17   #621  |  Link
ProWo
Newest beta (v3.3.9.02), online now.
(Changelog will follow in the next full release).
ProWo is offline   Reply With Quote
Old 16th March 2025, 13:54   #622  |  Link
ProWo
Newest beta (v3.3.9.03), online now.
Old 17th March 2025, 13:21   #623  |  Link
ProWo
Newest beta (v3.3.9.04), online now.
(fixed bug with remnant test messagebox in audio encoding, thx to mannequin80 for the hint).
Old 18th March 2025, 16:05   #624  |  Link
ProWo
Newest beta (v3.3.9.05), online now.
Old 29th March 2025, 19:26   #625  |  Link
ProWo
March 29, 2025 release version 3.4.0.
Added:
Check for missing ffmpeg folder.
Preview player stream selection for mutiple video streams.
Multiple videostreams handling in video cut.
Chapters: video preview for chapters time search.
Source dar/crop dar retainig info in video encode.
Additional scale for video preview for rotated videos to remain into screen bounds.
You can now change both values (width and height), if mantain display AR is checked.
Video preview for unfiltered HDR/HLG/DV content. (Display can remain blocked with older CPU's).
Fixed:
Bug with missing crop reset at videostream change.
Bug with missing info box in subtitle conversion.
Bug with missing stream update with multiple videostreams in video encoding.
Bug with labels top right truncated.
Bugs with volume and downmix in audio encoding.
Bug with aac_mf and 3,4,5,7 channels (not working).
Bug with audio channels remapping.
Bug with DAR adaption on video stream change.
Bug with duration adaption on video stream change.
Bug with test messagebox in audio encoding.
Bug with ac3 drc box handling in audio encoding.
Bug in cut section with single videostream id > 0.
Bug in cut section with audiostream only.
Bug with missing reset of subtitle streams (if more then one).
Bug in video rotate preview.
Bug with missing temp files deletion, if change framerate was aborted.
Bug with wrong start at second value for video preview, with long videos.
Changed:
Audio filter code.
Audio downmix code.
Audio encode code.
Settings & Update.
Removed update reminder label.
Moved: video crop to filter & more.
Restored possibility to mux a single stream.
Help screens separated.
Formatting of Cut help, VirtualDub Help and Video preview help screens.
Restored audio channels from source as first selection.
Frames to encode count in cut section.
Fix framerate and rotate video (MD only) values not changeable now.
Enabled channel remap from 1 channel to 2 channels now.
Output container to mkv for mpg and dat videos in cut section (to prevent the ffmpeg mpg muxer issue).
Rewritten whole preview code to stay within the screen bounds.
Old 2nd April 2025, 13:25   #626  |  Link
ProWo
Newest beta (v3.4.0.01), online now.
Old 2nd April 2025, 23:59   #627  |  Link
Lathe
Lathe's Avatar
Added:
Fixed:
Changed:
Audio filter code.
Audio downmix code.
Audio encode code.
Settings & Update.
WOW! Someone's been busy! Thanks mate!
Lathe is offline   Reply With Quote
Old 3rd April 2025, 00:00   #628  |  Link
Lathe
Lathe's Avatar
Oh, I'm sorry to ask again, but do we still only need to replace the .exe in the current folder?
Thanks!
Old 3rd April 2025, 06:02   #629  |  Link
ProWo
Thanks!
Yes. But use the update button so it's done automatically.
Old 15th April 2025, 12:36   #630  |  Link
ProWo
Newest beta (v3.4.0.02), online now.
Old 20th April 2025, 17:04   #631  |  Link
ProWo
Newest beta (v3.4.0.03), online now.
Old 29th April 2025, 15:56   #632  |  Link
ProWo
Newest beta (v3.4.0.04), online now.
Old 2nd May 2025, 10:17   #633  |  Link
ProWo
May 02, 2025 release version 3.4.1.
Added:
Presets for change length and pitch with audio file only.
Attachment recognition with mjpeg as video.
cleverNorm max gain option.
Possibility to delete unused processed files and batch tasks at program start and close.
Unused files list at app start and end.
Checks for missing ffmpeg files and for missing target folder.
Fixed:
Bug with update routine.
Bug with cut_help screen missing on cut start.
Bug with missing file deletion if video sample encoding is aborted.
Bug with video preview and encoding using LUT's.
Bug with wrong attachment button behavior in mux section.
Bug with attachments extraction (mjpeg, png).
Bug in audio length & pitch custom calculator.
Bug with setting negative audiodelay, if related source stream has positive delay (thx to edwardwoeful for the hint).
Changed:
Cut help screen formatting.
Clear selected streams (instead of Del_PS and Del_BS) in mux section (without touching the files).
Selection control direction when setting subtitle to burn in.
Remove muxed streams from mux grid.
Only one check for update admitted now.
Removed:
clevernorm option from downmix options.
Special thanks to Findu for continuous testing.
Old 8th May 2025, 10:11   #634  |  Link
ProWo
Newest beta (v3.4.1.01), online now.
