#464 | Link |
Newest beta (v3.2.8.04), online now.
Added: Change destination folder option (request by mannequin80 and oniiz86). Fixed: Bug in remember settings handing in audio/video encoding grids. The change destination folder option can be activated with the checkbox on the start screen. |
#465 | Link |
Newest beta (v3.2.8.05), online now.
Added: Attached font and image extraction. Add image and font as attachment (atm for mkv only). Select scale algorythms (if resizing). Fixed: Bug in destination folder reset. Bug in target file naming. Improved: Rewrote the whole chapters code. You can now use embedded chapters, create and edit new chapters or use /edit an external chapters file. |
#466 | Link |
Hey there! I tried to do the usual conversion from a UHD HDR 4k file to a playable Blu-ray (1080) I tried it twice, and about 31% the way through it threw this odd error. Do you know what this means? Should I run the MKV file through MKV Merge first before encoding it with CleverFFmpeg?
I've tried every which way of converting this full 4k file (from a full BDMV folder) first basically muxing the main movie file together using BDRB into one file of about 64 Gigs. The original and resulting movie file has 2 video streams in it (?) One almost the entire size in the UHD resolution, and a small part (1080) I muxed the movie file without the 1080 part (because CleverFFmpeg rejected the file outright as is) and retained the UHD video file. Using CleverFFmpeg it now accepted the UHD video file just fine and encoded about 31% and then stopped. Any suggestions? Thanks! Text File: Video ---> x264 (avc) - Stream ID 0 from ?E:\TSMUXER\BDMV\STREAM\00000.m2ts?5409862?-y -fflags +genpts -i "E:\TSMUXER\BDMV\STREAM\00000.m2ts" -vf fps=24000/1001,scale=1920:1080,zscale=t=linear:npl=100,format=gbrpf32le,zscale=p=709,tonemap=mobius:desat=2,zscale=t=709:m=709:r=tv,format=yuv420p,sidedata=delete -map 0:0 -c:v libx264 -profile:v main -preset medium -tune film -crf 20 -aspect 1.78 -color_primaries bt709 -color_trc bt709 -colorspace bt709 -an -sn -dn -metadata:g encoding_tool="clever FFmpeg-GUI" ?E:\TSMUXER 2\00000_0_0_x264 (avc).mkv?1 |
#470 | Link |
Yep, thanks! That is basically what I found out. So I muxed the rest of the movie file without that, but there must've been something wrong with it if CleverFFmpeg was encoding it just fine for about 30% of it. I think I can get a different source without the Dolby track.
#471 | Link |
September 06 2024 release version 3.2.9. ---------------------------------------------------------------------------------- Added: Change destination folder option (target/source folder, request by mannequin80 and oniiz86). (This option has to be activated with the checkbox on the start screen.) Attachments extraction (font and image). Add image and font (request by neptune84) as attachment (atm for mkv only). Select scale algorythms (if resizing). Fixed: Bug in remember settings handing in audio/video encoding grids. Bug in destination folder reset. Bug in target file naming. Bug in change framerate. Bug in mux truehd to mp4. Improved: Rewrote the whole chapters code. You can now use embedded chapters, create and edit new chapters or use /edit an external chapters file. HDR recognition (request by ingsoc). Cropdetect. ---------------------------------------------------------------------------------- |
#472 | Link |
For some odd reason, when I select HDR, the prompt showing the settings is not displaying properly, so I cannot set the settings. To my knowledge, I've not changed any resolution or display properties, and the REST of the interface looks fine. Here is a picture of my screen: (also, below the picture, I have another important question please)
Also, if I am supposedly importing an HDR encoded 4k Blu-ray movie file, and I get the prompt to the effect that 'There is no HDR metadata or data' do I still need to tell it to convert from HDR to SDR? Or, does that mean that the file simply is not encoded with HDR data and I can just resize it and convert to x264 and forget the HDR settings? Thanks! PS: Here is the MediaInfo information for the file I'm trying to encode: General Unique ID : 316352657827055018449204827836816384843 (0xEDFF4E405C41BC308F6EC254A231634B) Complete name : G:\___TL\Torso.1973.2160p.Italian.Version.UHD.Blu-ray.REMUX.DV.HDR.HEVC.DTS-HD.MA.1.0-W32.mkv Format : Matroska Format version : Version 4 File size : 63.4 GiB Duration : 1 h 33 min Overall bit rate mode : Variable Overall bit rate : 96.8 Mb/s Frame rate : 23.976 FPS Movie name : TORSO - 4K UHD Encoded date : 2024-08-29 20:25:13 UTC Writing application : mkvmerge v86.0 ('Winter') 64-bit Writing library : libebml v1.4.5 + libmatroska v1.7.1 Cover : Yes Attachments : cover.jpg Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 33 min Bit rate : 93.4 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.470 Stream size : 61.1 GiB (96%) Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.2020 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Audio #1 ID : 2 Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec ID : A_DTS Duration : 1 h 33 min Bit rate mode : Variable Bit rate : 1 031 kb/s Channel(s) : 1 channel Channel layout : M Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossless Stream size : 691 MiB (1%) Language : Italian Default : Yes Forced : No Audio #2 ID : 3 Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec ID : A_DTS Duration : 1 h 33 min Bit rate mode : Variable Bit rate : 1 032 kb/s Channel(s) : 1 channel Channel layout : M Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossless Stream size : 691 MiB (1%) Language : English Default : Yes Forced : No Audio #3 ID : 4 Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec ID : A_DTS Duration : 1 h 33 min Bit rate mode : Variable Bit rate : 1 042 kb/s Channel(s) : 1 channel Channel layout : M Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossless Stream size : 698 MiB (1%) Language : English Default : Yes Forced : No Audio #4 ID : 5 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 1 h 33 min Bit rate mode : Constant Bit rate : 255 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 171 MiB (0%) Title : Commentary by Kat Ellinger, author of All the Colours of Sergio Martino Language : English Default : Yes Forced : No Text #1 ID : 6 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 30 min Bit rate : 19.7 kb/s Frame rate : 0.196 FPS Count of elements : 1068 Stream size : 12.8 MiB (0%) Language : English Default : Yes Forced : No Text #2 ID : 7 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 28 min Bit rate : 1 912 b/s Frame rate : 0.018 FPS Count of elements : 96 Stream size : 1.22 MiB (0%) Language : English Default : Yes Forced : No Text #3 ID : 8 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 31 min Bit rate : 25.8 kb/s Frame rate : 0.301 FPS Count of elements : 1648 Stream size : 16.8 MiB (0%) Language : English Default : Yes Forced : No Menu 00:00:00.000 : en:Capítulo 01 00:06:42.110 : en:Capítulo 02 00:13:25.429 : en:Capítulo 03 00:20:58.131 : en:Capítulo 04 00:31:11.452 : en:Capítulo 05 00:39:12.475 : en:Capítulo 06 00:46:14.563 : en:Capítulo 07 00:54:52.872 : en:Capítulo 08 01:02:22.738 : en:Capítulo 09 01:08:18.219 : en:Capítulo 10 01:16:14.778 : en:Capítulo 11 01:24:57.133 : en:Capítulo 12 |
#475 | Link |
And... it failed anyway just doing it with no HDR setting...
Video ---> x264 (avc) - Stream ID 0 from ?G:\___TL\Torso.1973.2160p.Italian.Version.UHD.Blu-ray.REMUX.DV.HDR.HEVC.DTS-HD.MA.1.0-W32.mkv?5619629?-y -fflags +genpts -i "G:\___TL\Torso.1973.2160p.Italian.Version.UHD.Blu-ray.REMUX.DV.HDR.HEVC.DTS-HD.MA.1.0-W32.mkv" -vf fps=24000/1001,scale=1920:1080,format=yuv420p -map 0:0 -c:v libx264 -profile:v main -preset medium -crf 20 -aspect 1.78 -an -sn -dn -metadata:g encoding_tool="clever FFmpeg-GUI" ?E:\TSMUXER\Torso.1973.2160p.Italian.Version.UHD.Blu-ray.REMUX.DV.HDR.HEVC.DTS-HD.MA.1.0-W32_0_0_x264 (avc).mkv?1 |
#477 | Link | |
![]() Well, there appear to be a number of weird things happening with the interface, which I've posted very clear pictures of (I know... ending on a preposition, sorry...) Right now I'm using Handbrake and it's actually a little over half way through now, so I'm holding my breath (I'll just about take anything now) It is set to use the BT709 filter, and I've checked the resulting file and it seems to look okay, so maybe I'll finally get it... |
#480 | Link | |
please cut 30 seconds of this video, upload it to any hoster and post the link here. Then I will analyze it. |
