Old 18th July 2023, 13:47   #301  |  Link
ProWo
Newest beta (v3.1.2.04), online now.
Changed: raw h264/hevc video stream handling again.
Improved: start screen.
Added: automatic scale change with rotate 90° cw/ccw in encoding section.
ProWo is offline   Reply With Quote
Old 25th July 2023, 17:13   #302  |  Link
ProWo
Newest beta (v3.1.2.05), online now.
Fixed: bug in audio 5.1 to 2 ch conversion, bug in HDR10+ cll value detection.
Changed: ffmpeg version detection.
Improved: main menu button handling, start screen handling, audiostream handling with multiple audiostreams.
Added: Fix Timstamps with given FPS reading.
Old 27th July 2023, 17:17   #303  |  Link
ProWo
July 27, 2023 release version 3.1.3.
Fixed: bug in audio 5.1 to 2 ch conversion, bug in HDR10+ cll value detection, bug in audio volume handling.
Improved: raw h264/hevc videostream handling, start screen handling, main menu button handling, audiostream handling with multiple audiostreams, smoother form changing, audio channels handling.
Changed: various options/settings handling in main section and video encoding section, selected streams handling in multiplex section, ffmpeg version detection.
Added: dat videofile(vcd/svcd) handling, rotate video without reencoding (metadata only, main section), rotate and flip, automatic scale change with rotate 90° cw/ccw (video encode section), fix timestamps by reading with given framerate.
Old 3rd August 2023, 15:31   #304  |  Link
ProWo
Newest beta (v3.1.3.01), online now.
Changed: start screen again, loading hevc video without scan type info presuming progressive, audiostream selection with multiple audiostreams, filterchain in videoencoding, HDR to SDR encoding with all avaiable videocodecs (not only hevc), moved HDR settings to various.
Fixed: encode button visible after encoding start in audioencoding, automatic 8 Bit bitdepth selection for videostreams without bitdepth info.
Added: automatic DAR selection with DVD resolutions.
Old 4th August 2023, 09:59   #305  |  Link
ProWo
Newest beta (v3.1.3.02), online now.
Fixed: HDR to SDR with h265 bug.
Added: dvd_subtitle (vobsub) mux to mp4.
Old 11th August 2023, 13:09   #306  |  Link
ProWo
Newest beta (v3.1.3.03), online now.
Added: Set bitdepth with HDR10 to SDR, set encoding matrix with mpeg2, mjpeg muxing to asf/avi/mkv/mp4.
Improved: mpeg1 and mpeg2 encoding quality, HDR recognition.
Fixed: Bug in color_transfer recognition.
Old 24th August 2023, 17:04   #307  |  Link
ProWo
Newest beta (v3.1.3.04), online now.
Added: change video properties (contrast, brightness,saturation, croma), preview video with selected filters.
Improved: after volume detection goes directly to the encoder, video filter chain handling.
Changed: cut section.
Old 31st August 2023, 18:02   #308  |  Link
ProWo
Newest beta (v3.1.3.05), online now.
Added: eia_608, eia_708,hdmv_pgs_subtitle extraction, eia_608, eia_708 conversion, eia_608, eia_708, hdmv_pgs_subtitle burn in, preview for HDR10 to SDR and LUT's.
Fixed: bug in subtitle selection for burn in, bug in HDR/SDR selection with HDR10 source, tooltip in HDR10 settings.
Old 1st September 2023, 11:02   #309  |  Link
ProWo
September 1, 2023 release version 3.1.4.
Fixed: encode button visible after encoding start in audioencoding, automatic 8 Bit bitdepth selection for videostreams without bitdepth info, HDR to SDR with h265 bug, Bug in color_transfer recognition, bug in subtitle selection for burn in, bug in HDR/SDR selection with HDR10 source, tooltip in HDR10 settings.
Changed: start screen again, loading hevc video without scan type info presuming progressive, audiostream selection with multiple audiostreams, filterchain in videoencoding, HDR to SDR encoding with all avaiable videocodecs (not only hevc), moved HDR settings to various, cut section.
Improved: mpeg1 and mpeg2 encoding quality, HDR recognition, after volume detection goes directly to the encoder, video filter chain handling.
Added: automatic DAR selection with DVD resolutions, dvd_subtitle (vobsub) mux to mp4, Set bitdepth with HDR10 to SDR, set encoding matrix with mpeg2, mjpeg muxing to asf/avi/mkv/mp4, change video properties (contrast, brightness,saturation, croma), preview video with selected filters, eia_608, eia_708,hdmv_pgs_subtitle extraction, eia_608, eia_708 conversion, eia_608, eia_708, hdmv_pgs_subtitle burn in, preview for HDR10 to SDR and LUT's.
Old 5th September 2023, 17:38   #310  |  Link
ProWo
Newest beta (v3.1.4.01), online now.
Added: coupling switch for DynAudNorm (on request by JOAOP).
Old 22nd September 2023, 08:37   #311  |  Link
ProWo
Newest beta (v3.1.4.02), online now.
Improved: dynaudnorm settings, Inverse telecine.
Added: indexing videostream for keyframe cutting, v210 codec can be muxed now in admitted containers.
Fixed: missing variable reset.
Changed: whole cut code.
Old 29th September 2023, 15:31   #312  |  Link
ProWo
Newest beta (v3.1.4.03), online now.
Changed: audio filter handling, video cut code again.
Added: speechnorm filter, compand filter, choice to handle missing audio channels (omit, downmix) if audio channels reduction occours, video indexing for video cut.
Old 2nd October 2023, 08:55   #313  |  Link
ProWo
Newest beta (v3.1.4.04), online now.
Fixed: Bug in 2nd pass on loudnorm filter, removed 7.1 channels option for eac3 encoder, typos.
Old 22nd October 2023, 10:10   #314  |  Link
ProWo
October 22, 2023 release version 3.1.5.
Fixed: bug in fix timestamps, bug in video encoding with LUTs, bug in HDR10 handling with smpte2084 files without HDR10 metadada, typos.
Added: automatic return to UI after audio filter selection, automatic selection of colorspace and colorrange if this info is missing from the source.
Improved: video filter handling, cutting code.
Old 23rd October 2023, 10:09   #315  |  Link
ProWo
Newest beta (v3.1.5.01), online now.
Fixed: little bug in output folder selection.
Added: output folder info and quit button on start screen.
Changed: button symbol (after encode audiostream), automatic return to select source screen after multiplex, cut and join.
Old 27th October 2023, 08:54   #316  |  Link
ProWo
Newest beta (v3.1.5.02), online now.
Added: You can now select the streams to extract.
Old 28th October 2023, 08:31   #317  |  Link
ProWo
Newest beta (v3.1.5.03), online now.
Fixed: little bugs.
Added: can now handle multiple videostremas in one file, sample video encoding.
Old 1st November 2023, 15:02   #318  |  Link
ProWo
November 1, 2023 release version 3.1.6.
New:
Possibility to extract single or all streams.
Possibility to reorder the streams in the muxing grid.
Unsharp filter in video encoding.
The confirmation after successful task execution has been removed.
Automatic return to start screen after multiplexing.
Sample video encoding.
Can now handle multiple video streams in one file.
Output folder info on start screen.
Quit button on start screen.
Fixed:
Bug in output folder selection.
Other little bugs.
Improved:
The complete streams analysis recoded.
Changed:
Welcome screen.
Eia 607/708 captions extraction.
Background colors.
Old 1st November 2023, 19:07   #319  |  Link
Grimsdyke
Thanks for the new version !!
Can you maybe add a function that chapters can automatically be created after merging/joining based on the induvidial file titles and lengths ?
MPC-BE feature wishlist: 1) DiscID
2) Two independent volume control sliders in the UI when using directsound dual-audio-out.
Grimsdyke is offline   Reply With Quote
Old 2nd November 2023, 17:22   #320  |  Link
ProWo
Thanks for the hint.
I'm working on it. Will be added in the next beta.
