19th May 2011, 18:51 | #41 | Link | |
development folder, containing MPC-HC experimental tester builds, pixel shaders and more: http://www.mediafire.com/?xwsoo403c53hv |
23rd May 2011, 09:08 | #42 | Link |
I've found by accident an older (2010) German PC magazine about VLC IIRC 1.05. They had only nice words about it (it wasn't a "hidden ad", just a comparison of features, tips, tricks and hints for newbies etc.).
For newbies is probably the best player, if correctly installed and configured.
Born in the USB (not USA) |
23rd May 2011, 17:40 | #43 | Link | |
The fact it also doesn't use EVR or any other known renderer (or at least it doesn't call it by the appropriate names, all I see is retarded gibberish like DirectX or DirectDraw Renderer, when VMR/EVR are used in EVERY SINGLE OTHER PLAYER, and I don't even think they are the same thing) is really annoying too. It's a complete mess. I think MPC-HC is much more user friendly, in every single aspect. VLC had the edge to play broken files in the past, but I never found anything that MPC-HC can't play just fine in the last 3 years. |
23rd May 2011, 18:02 | #44 | Link | |
quack quack
Point is, if VLC is your main player, you don't need to rely on anything else. Not even codecs, etc. |
1st June 2011, 14:52 | #45 | Link |
I'm going to give a +1 for VLC. Ever since I migrated to it, I've never looked back and never used anything else (for movies). And never worried about codec packs or system stability either (when codec packs get messed up, things get REALLY hairy). Although I've had the odd VLC crash here and there, it's stable 99% of the time. Also I don't know what the complaints about subtitles are - I've watched hundreds of videos with subtitles, DVD and non-DVD alike, and I've never had any problems with them.
Just to be complete - yes, about 5 years ago I too disliked VLC because of its stability issues. For example, it would completely lock down the system if you ejected the DVD while it was playing it. But it's come a long way since then. |
2nd June 2011, 01:56 | #46 | Link |
.NET Web App Dev
From a pure performance standpoint, MPC:HC is the de-facto winner for me.
Dark Eiri also has another criticism that I have for VLC.
Intel i7 5820k / 16 GB DDR4 / NV 970 / 4K ASUS Windows 8.1 |
2nd June 2011, 08:57 | #47 | Link |
brontosaurusrex
gui wise i like this one:
http://www.youtube.com/watch?v=35DsphxQn_M usage wise would be mplayer cli version. (mpc-hc and vlc suffers from "featurities" > only my opinion) |
13th June 2011, 07:21 | #50 | Link |
Well, I have to say that VLC for Windows and VLC for Linux are like two different products. I used it with my underpowered laptop (with Win XP SP3) and my experience with the player was bad. Often crashes, bad subtitle support, and the high consumption of CPU cycles plus a lot of minor glitches. On the other hand, the Linux version of the player is rock stable, and not so resource hungry as I thought. Only the subtitle support is so-so, the rest is pretty OK.
20th June 2011, 08:26 | #51 | Link |
Derek Prestegard IRL
I don't care about subtitle support really, but the main reasons I use MPC-HC over VLC are the following:
1) MadVR, which is absolutely essential with my Plasma TV to get smooth jitter free playback. 2) ffdshow filters 3) Modularity (which can also be a curse)
These are all my personal statements, not those of my employer :) |
26th June 2011, 19:28 | #52 | Link |
guys with vlc 1.2 has much improved subtle support witch you can try out out here http://nightlies.videolan.org/build/win32/?C=M;O=D then click on the newest trunk link
15th August 2011, 10:52 | #55 | Link |
I did try to compile 1.2 on Ubuntu but it had stability problems and crashed often or sound stopped working. A nice feature was sound font support for MIDI files.
Also every ppa offers their own version of VLCPlayer that makes things confusing. Eg the latest VLC from one ppa had stuttery playback while another ppa with an older version, yet compiled recently, had no problems. I'll try the Windows build,it might be more stable. VLC made much progress and can compete with any media player. I ditched ffdshow and Reclock because they interefered with some games in-game fmv or sound output and crashed. If I have manually to configure every game for ffdshow, forget it. Players like VLC are more convenient. |
