#1701 | Link |
sorry didn't worked
00000001 0.00000000 [2680] *** Using D3D9 adapter: AMD Radeon R9 200 Series 00000002 0.03274702 [2680] OpenCL is available 00000003 0.22503611 [2680] Platform count: 2 00000004 0.22506173 [2680] *** Platform #1 00000005 0.22509155 [2680] Extensions: cl_khr_icd cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_amd_event_callback cl_amd_offline_devices 00000006 0.22511385 [2680] Found KHR mem sharing extension 00000007 0.22514789 [2680] clGetDeviceIDsFromDX9MediaAdapterKHR error code: -1 00000008 0.22516958 [2680] Not the GPU that was used to create the DX9 device 00000009 0.22519279 [2680] *** Platform #0 00000010 0.22526719 [2680] Extensions: cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_spir cl_intel_exec_by_local_thread cl_khr_depth_images cl_khr_3d_image_writes cl_khr_fp64 cl_intel_dx9_media_sharing cl_khr_dx9_media_sharing cl_khr_d3d11_sharing cl_khr_gl_sharing 00000011 0.22528888 [2680] Found KHR mem sharing extension 00000012 0.22532202 [2680] clGetDeviceIDsFromDX9MediaAdapterKHR error code: -1 00000013 0.22534370 [2680] Not the GPU that was used to create the DX9 device 00000014 0.22536540 [2680] The GPU that was used to create the DX9 device does not support OpenCL mem sharing 00000015 0.22539553 [2680] Failed to init OpenCL for Dx9 memory sharing, error 0 |
#1706 | Link |
this is with test 9
number 0 00000001 0.00000000 [47120] *** Using D3D9 adapter: AMD Radeon R9 200 Series 00000002 0.01443766 [47120] OpenCL is available 00000003 0.20814273 [47120] Platform count: 2 00000004 0.20835163 [47120] *** Platform #1 00000005 0.20872423 [47120] Extensions: cl_intel_dx9_media_sharing cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_depth_images cl_khr_dx9_media_sharing cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_spir 00000006 0.20906045 [47120] Found KHR mem sharing extension 00000007 0.20937215 [47120] clGetDeviceIDsFromDX9MediaAdapterKHR error code: -1 00000008 0.20965646 [47120] Not the GPU that was used to create the DX9 device 00000009 0.20988548 [47120] *** Platform #0 00000010 0.21012942 [47120] Extensions: cl_khr_icd cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_amd_event_callback cl_amd_offline_devices 00000011 0.21036193 [47120] Found KHR mem sharing extension 00000012 0.21120289 [47120] clGetDeviceIDsFromDX9MediaAdapterKHR error code: -1 00000013 0.21187609 [47120] Not the GPU that was used to create the DX9 device 00000014 0.21244131 [47120] The GPU that was used to create the DX9 device does not support OpenCL mem sharing 00000015 0.21311221 [47120] Failed to init OpenCL for Dx9 memory sharing, error 0 number 1 00000001 0.00000000 [47432] *** Using D3D9 adapter: AMD Radeon R9 200 Series 00000002 0.01411890 [47432] OpenCL is available 00000003 0.20938437 [47432] Platform count: 2 00000004 0.20939624 [47432] *** Platform #1 00000005 0.20947592 [47432] Extensions: cl_intel_dx9_media_sharing cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_depth_images cl_khr_dx9_media_sharing cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_spir 00000006 0.20948598 [47432] Found KHR mem sharing extension 00000007 0.20955338 [47432] clGetDeviceIDsFromDX9MediaAdapterKHR error code: -1 00000008 0.20956211 [47432] Not the GPU that was used to create the DX9 device 00000009 0.20958082 [47432] *** Platform #0 00000010 0.20960639 [47432] Extensions: cl_khr_icd cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_amd_event_callback cl_amd_offline_devices 00000011 0.20963915 [47432] Found KHR mem sharing extension 00000012 0.20965409 [47432] clGetDeviceIDsFromDX9MediaAdapterKHR error code: -1 00000013 0.20968370 [47432] Not the GPU that was used to create the DX9 device 00000014 0.20969278 [47432] The GPU that was used to create the DX9 device does not support OpenCL mem sharing 00000015 0.20972547 [47432] Failed to init OpenCL for Dx9 memory sharing, error 0 number 2 00000001 0.00000000 [49376] *** Using D3D9 adapter: Intel(R) HD Graphics 4600 00000002 0.00605405 [49376] OpenCL is available 00000003 0.20056851 [49376] Platform count: 2 00000004 0.20058003 [49376] *** Platform #1 00000005 0.20065910 [49376] Extensions: cl_intel_dx9_media_sharing cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_depth_images cl_khr_dx9_media_sharing cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_spir 00000006 0.20066936 [49376] Found KHR mem sharing extension 00000007 0.20073131 [49376] Found the GPU that was used to create the DX9 device |
#1707 | Link |
Technically I do, but I can't use it with this motherboard, so this shouldn't be the problem.
It's trying with the GTX970 anyways. Code:
[2140] *** Using D3D9 adapter: NVIDIA GeForce GTX 970 [2140] OpenCL is *NOT* available |
#1709 | Link |
I have had an issue running version 9 on an amd dual graphics system 8500 series + R5 graphics. I disabled each one and also set the preferred card but it didn't work. I'll copy the debugview when I post updated results.
Geforce 820M 90 FPS Geforce 840M 105 FPS Geforce GTX 850 187 FPS HD Graphics (Broadwell) 115 FPS HD Graphics 4000 360 FPS HD Graphics 4400 (64 bit) 170 FPS HD Graphics 5500 346 - 358 FPS AMD M260 215 FPS AMD M265X 390 FPS AMD R5 / HD8570 [11560] *** Using D3D9 adapter: AMD Radeon(TM) R5 Graphics [11560] OpenCL is available [11560] Platform count: 1 [11560] *** Platform #0 [11560] Extensions: cl_khr_icd cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_amd_event_callback cl_amd_offline_devices cl_amd_hsa [11560] Found KHR mem sharing extension [11560] clGetDeviceIDsFromDX9MediaAdapterKHR error code: -1 [11560] Not the GPU that was used to create the DX9 device [11560] The GPU that was used to create the DX9 device does not support OpenCL mem sharing [11560] Failed to init OpenCL for Dx9 memory sharing, error 0 Last edited by ryrynz; 11th April 2015 at 02:56. |
#1714 | Link | |
you will never see good results with amd using an dx9 <-> openCL interop. the openCL performance is still way better on AMD than nvidia only the copyback work like a handbrake. |
#1715 | Link |
Suptitle, MediaPlayer.NET
OK you guys with AMD cards, can you try this out (DxClTest10.zip)? I think I've found the problem - silly thing that for some reason didn't bother Intel but does AMD.
#1716 | Link |
better i guess:
00000001 0.00000000 [3204] base\appmodel\execmodel\modern\lifetimemanager\appxexecutionutil.cpp(55)\modernexecserver.dll!00007FFDBBFFE8CA: (caller: 00007FFDBC0103BA) ReturnHr[PreRelease](16) tid(b04) 80073D57 The process has no application identity. 00000002 7.16983414 [2904] *** Using D3D9 adapter: AMD Radeon R9 200 Series 00000003 7.20206404 [2904] OpenCL is available 00000004 7.37989759 [2904] Platform count: 2 00000005 7.37991571 [2904] *** Platform #0 00000006 7.38002014 [2904] Extensions: cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_spir cl_intel_exec_by_local_thread cl_khr_depth_images cl_khr_3d_image_writes cl_khr_fp64 cl_intel_dx9_media_sharing cl_khr_dx9_media_sharing cl_khr_d3d11_sharing cl_khr_gl_sharing 00000007 7.38004827 [2904] Found KHR mem sharing extension 00000008 7.38008165 [2904] clGetDeviceIDsFromDX9MediaAdapterKHR error code: -1 00000009 7.38010693 [2904] Not the GPU that was used to create the DX9 device 00000010 7.38012075 [2904] *** Platform #1 00000011 7.38015461 [2904] Extensions: cl_khr_icd cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_amd_event_callback cl_amd_offline_devices 00000012 7.38016748 [2904] Found KHR mem sharing extension 00000013 7.38324404 [2904] Found the GPU that was used to create the DX9 device 00000014 7.44802427 [2904] Error Getting CL Surface 00000015 7.44828558 [2904] Error Acquiring Dx9 Surface 00000016 7.44832802 [2904] Error Releasing Dx9 Surface 00000017 7.46745014 [2904] Error Acquiring Dx9 Surface 00000018 7.46755838 [2904] Error Releasing Dx9 Surface 00000019 7.46781921 [2904] Error Acquiring Dx9 Surface 00000020 7.46787310 [2904] Error Releasing Dx9 Surface 00000015 7.44828558 [2904] Error Acquiring Dx9 Surface 00000016 7.44832802 [2904] Error Releasing Dx9 Surface things |
#1718 | Link | |
With that I'm getting around 947FPS on a GTX970 in a PCIe2.0x16 slot. |
#1720 | Link | |
direct3d, mpdn, nnedi3, opencl, reclock |
