#4481 | Link | |
Most downscaling methods end up softening the image. The SSIM downscaler basically sharpens the image just enough to make it as sharp as the original. It's subtle, but it is noticeable. |
#4485 | Link |
Problem is there is only one core dev and he is offline since a couple of months, I was once offline 1,5 years, I hope he is fine.
#4486 | Link | |
Suptitle, MediaPlayer.NET
Just been busy with work. There's not much I wanted to do to improve the player anyway that is beyond what needs to be done within the core app. It's so extensible that anyone could add features to it. |
#4488 | Link |
I was just trying to say you haven't been posting since a few months. Who is the other core dev then? I didn't notice anybody seriously trying to help. I've not figured out what is wrong, I was hoping a dev will tell what to do. Please note that when I first tried the player when it was new the exact same problem was happening and it had something to to with the subtitle filter so obviously there was no properly working error handling.
#4489 | Link |
There's Shiandow too.
When you said it beeped when you tried starting the player, did you mean the player window itself wouldn't even appear? If so that's way before anything to do with MPDN. The first thing MPDN does is it shows the player window, before it loads Configs etc. |
#4490 | Link |
I was thinking Shiandow makes plugins and don't work on the core.
The window is only visible a few milliseconds.
#4492 | Link |
I tried the portable and the installer both x64 and x86, it works in my vmware client Win 7 but not on my system Win 10, in Visual Studio it shows:
Exception thrown at 0x7498B802 in MediaPlayerDotNet.exe: Microsoft C++ exception: std::exception at memory location 0x00EFE914. There is nothing logged in the Windows Event Log. Suggestion: Upload a build with debug symbols.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 28th July 2017 at 15:19. |
#4493 | Link |
Is Windows 10 officially supported and have you tested it on Windows 10 1703? Has anybody got it working on Windows 10 1703?
#4495 | Link |
I've been using MPDN since release with zero issues on Windows 10 (including build 1703). Whatever problems you're having is something interfering on your end. The least you can do is provide some detail of what you have tried, your setup, what processes are running, etc. I mean you're a dev and all, you know what you can do to help us help you.
#4496 | Link |
I'm just starting as player dev
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 29th July 2017 at 01:25. |
#4498 | Link |
I did not know it along, I didn't spend much thought on it until being reminded being a dev and that if I don't help myself probably nobody will.
#4499 | Link |
You need to work on your reading comprehension.
Anyway, 4k works fine. The issue is that 288DPI you have set. I've tried a few other odd custom DPI values thinking there's an issue with odd custom values, but what I tested worked fine. |
#4500 | Link | |
Unfortunately right now not all parts of the core code can be made open source (and therefore need to be obfuscated, so no debug symbols). |
direct3d, mpdn, nnedi3, opencl, reclock |
