#41 | Link | |
Would you know where I could find out more about the --frame-packing option? Many thanks. |
#43 | Link | |
mariner, give it a go with MeGui 0.3.5.0: just select x264 BluRay preset and select film, it's gonna give you this:
program --tune film --crf 20 --level 4.1 --bframes 3 --ref 4 --slices 4 --aud --nal-hrd vbr --b-pyramid strict --keyint 24 --min-keyint 2 --vbv-bufsize 30000 --vbv-maxrate 40000 --weightp 0 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --output "output" "input" Quote:
If you mean real frame packing 1080+45+1080, you will need a MVC encoder. Last edited by rica; 19th December 2010 at 02:11. |
#44 | Link | ||
Greetings rica. Thanks for the reply.
x264 --frame-packing 3 -o 700.mkv 3d700.avs Best regards |
#45 | Link | |
What is "frame packing 3"? I don't know what it is and what it's for? Last edited by rica; 19th December 2010 at 02:48. |
#48 | Link | |||
--frame-packing <integer> For stereoscopic videos define frame arrangement - 0: checkerboard - pixels are alternatively from L and R - 1: column alternation - L and R are interlaced by column - 2: row alternation - L and R are interlaced by row - 3: side by side - L is on the left, R on the right - 4: top bottom - L is on top, R on bottom - 5: frame alternation - one view per frame |
#49 | Link | |
By the way, I encoded a 1920x2160 top/bottom using --frame-packing 3 by mistake. Seems to work fine though. Any reason? Last edited by mariner; 19th December 2010 at 15:06. |
#50 | Link |
Why 60 fps?
Here is what i get with MeGui preset: Left-Right: ![]() Top-Bottom: ![]() I used Adam Stanislav's tool: http://www.pantarheon.org/AviSynth3DToolbox/ _ _ _ _ _ _ _ _ _ _ _ Last edited by rica; 19th December 2010 at 15:35. |
#51 | Link | ||
Btw, do you have some specific hardware player that supports side-by-side 3D with frame sizes above 1920x1080, or why are you using Blu-ray presets for the encodes? I don't think they'll be 3D Blu-ray compatible, afterall, or have you read the specs? Last edited by nm; 19th December 2010 at 16:16. |
#52 | Link | |
Name: 700_v17.mkv Size: 112.13MB Description: 1920x2160/60p 3D Top/Bottom http://www.sendspace.com/file/x0fr5l This is the file properties: Code:
General Complete name : D:\3D\700_v17.mkv Format : Matroska File size : 112 MiB Duration : 13s 981ms Overall bit rate : 67.3 Mbps Writing application : x264 r1834 a51816a Writing library : Haali Matroska Writer b0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 13s 981ms Bit rate : 65.9 Mbps Width : 1 920 pixels Height : 2 160 pixels Display aspect ratio : 0.889 Frame rate : 59.940 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.265 Stream size : 110 MiB (98%) Writing library : x264 core 112 r1834 a51816a Encoding settings : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Language : English Last edited by mariner; 19th December 2010 at 15:59. |
#56 | Link | |
I can watch them in 3D mode with -only TMT5 over my nVidia 430 and Acer 5360 PJ. But i can get 1920*1080 3D files as well: (Both TMT 5 and PDVD 10 plays them flawlessly in 3D mode: LEFT-RIGHT: Code:
LoadPlugin("C:\DG\DGDecodeNV.dll") lv = DGSource("C:\H264StereoSource_a2\left.dgi") rv = DGSource("C:\H264StereoSource_a2\right_new.dgi") LeftRight3DReduced(lv, rv) ConvertToYV12() Code:
lv = FFVideoSource("C:\H264StereoSource_a2\left.m2ts") rv = FFVideoSource("C:\H264StereoSource_a2\right_new.m2ts") LeftRight3DReduced(lv, rv) ConvertToYV12() Code:
lv = directshowsource("C:\H264StereoSource_a2\left.m2ts") rv = directshowsource("C:\H264StereoSource_a2\right_new.m2ts") LeftRight3DReduced(lv, rv) ConvertToYV12() Code:
LoadPlugin("C:\DG\DGDecodeNV.dll") lv = DGSource("C:\H264StereoSource_a2\left.dgi") rv = DGSource("C:\H264StereoSource_a2\right_new.dgi") TopDown3DReduced(lv, rv) ConvertToYV12() Last edited by rica; 19th December 2010 at 23:45. |
stereo-3d, stereoscopic, useless |
