Old 1st May 2012, 23:39   #361  |  Link
Cedvano
It's my fault ! My h264 files isn't good.
I have an error :
x264 [info]: profile High, level 4.1
An unintentional loss of pictures occurs! Exit/s, eta 0:00:34
A gap in frame number is found, try to fill it.
PicParset 1 references an invalid (uninitialized) Sequence Parameter Set with ID 1, expect the unexpected...
And stop here. I can't do anything. Have you got an idea ? Thanks
Cedvano is offline   Reply With Quote
Old 2nd May 2012, 12:36   #362  |  Link
Cedvano
I continue with this error. I can play my video.
When I read on my 3DTV, I have a dancing image.
Here the command line :
x264 --level 4.1 --sar 1:1 --aud --frames 4000 --frame-packing 5 -o "c:\test\final.264" "c:\eac3to\avs.avs"
My AVS:
LoadPlugin("C:\eac3to\H264StereoSource.dll")
lv = DirectShowSource("C:\test\left.h264").crop(0,0,0,-8)
rv = H264StereoSource("decoder.cfg",577)
Interleave(lv, rv)
ConvertToYV12()
Where is the mistake ?
Old 3rd May 2012, 06:58   #363  |  Link
kypec
User of free A/V tools
kypec's Avatar
Originally Posted by Cedvano View Post
I use Win7 64, x264 32bits and Avisynth 64bits.
Have you got a soluce ?
Yes, ditch AviSynth x64 in favor of 32-bit version. It's known to be utterly unstable.
kypec is offline   Reply With Quote
Old 3rd May 2012, 07:41   #364  |  Link
Cedvano
Ok, thanks. I do that.
But, I can't use H264StereoSource.dll ???
Edit:
All is good. I reinstall 32bit Avisynth.
I find the real avs options and can create a good framepacking. 60fps
On my LG, good quality.
Thanks for your help.
Old 11th August 2012, 03:52   #365  |  Link
eule2010
Free MVC Encoder in 2012 ?
are there any planned developments for 2012 ?
GSoC 2011 extensions, Fraunhofer ?
Greets
eule2010
eule2010 is offline   Reply With Quote
Old 11th August 2012, 03:59   #366  |  Link
SassBot
Posts: n/a
Except that GSoC page says that more than half the tasks were never started.
Old 11th August 2012, 04:27   #367  |  Link
eule2010
Sorry, i am a little bit confused !
Old 30th December 2012, 22:18   #368  |  Link
rica
Hi guys, Happy New Year to you all!
After months, I discovered "interleave" option always resulted with a shaking movie; not because of the encoder but aviscript itself.
Please check out these scripts on VirtualDubMod or GraphStudio and play the script frame by frame.
You will realize that right video (or left video) shifts through the bottom from the horizon line about 5-7 degrees, and this causes the shaking issue.
You may use one of these scripts to test:
lv=FFVideoSource("C:\folder\left.mkv")
rv=FFVideoSource("C:\folder\right.mkv")
interleave(lv,rv)
or,
lv=DirectShowSource("C:\folder\left.mkv", fps=25.00, audio=false)
rv=DirectShowSource("C:\folder\right.mkv", fps=25.00, audio=false)
interleave(lv,rv)
ConvertToYV12()
While there is no issue with this script:
StackHorizontal(lv,rv)
And here are the test files:
http://www.mediafire.com/?g1o0z67obrhp7qm
http://www.mediafire.com/?znydd51nosmny0n
Any feedback will be appreciated.
(Source: Test files have been extracted from Heidelberg 720.wmv from 3dtv.at.)
rica is offline   Reply With Quote
Old 30th December 2012, 22:55   #369  |  Link
J_Darnley
J_Darnley's Avatar
Of course the video will shake if you look at the output of avisynth or x264 without a 3D player. The left and right views are interleaved. Are you encoding with --frame-packing 5? Are you using a 3D player?
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 30th December 2012, 23:02   #370  |  Link
rica
Yes to all your questions.
Even it is interleaved, both views must keep staying horizontally. (or parallelly.)
It is not related with a 3D viewer. (please check how stackhorizontal script keep staying on the same horizontal line. Shaking is normal for interleave while belly dancing is not.)
This is what I mean: (left view, here, is not on the horizon line.)
right view:
left view:
_ _ _ _ _ _ _
Old 31st December 2012, 16:58   #371  |  Link
kieranrk
Erm...your eyes are at different horizontal positions so why should the pictures stay the same horizontally?
kieranrk is offline   Reply With Quote
Old 31st December 2012, 17:48   #372  |  Link
rica
No, I am not squint. You may compare both scripts to check out if the left video keeps staying in horizontal position with stack-horizontal script.
Old 4th January 2013, 00:11   #373  |  Link
rica
Solved:
http://forum.doom9.org/showpost.php?...7&postcount=32
_ _ _ _ _
Old 21st July 2014, 13:36   #374  |  Link
tal.aloni
Originally Posted by nm View Post
That file uses the same standard frame packing SEI (45) as x264 does. The only difference is that the stream has the SEI before every frame (with current_frame_is_frame0 flag set for each other frame) while x264 only inserts the message once for each GOP.
Solved #2,
After some reading and using the guidance on this thread, I was able to fix the issue with x264, see here for more info.
You also need a PS3 compatible container in order to play back 3D FS on the PlayStation 3, For more information see here.
tal.aloni is offline   Reply With Quote
stereo-3d, stereoscopic, useless
