#6 | Link |
given the new Media Gateway Devices BCM7422 SOC from Broadcom, id expect to see these SVC/MVC STB's start appearing by this time next year perhaps 18 months from now so an open SVC/MVC Encoder that doesn't suck might be a good thing sometime sooner.
http://www.multichannel.com/article/...l_Res_3DTV.php " System-on-Chip Aimed at Media Gateway Devices By Todd Spangler -- Multichannel News, 12/14/2010 3:40:24 PM Broadcom wants to take cable subscribers deeper into the third dimension, with a supercharged set-top system-on-chip that has more than twice the horsepower of previous generations to deliver full-resolution 3DTV. The BCM7422 -- designed for media gateway devices that stream IP video in the home -- provides a 1.3-Gigahertz central processor, along with H.264/MPEG codecs that enable 1080p high-definition video and full-resolution HD 3DTV. The SoC also features a 1-gigapixel-per-second 3D graphics processing unit for advanced 3D graphics acceleration, as well as home networking connectivity including MoCA and DLNA support. ... The new Broadcom chip supports both Scalable Video Coding (SVC) and Multiview Video Coding (MVC) standards. MVC, the spec used in 3D Blu-ray Disc players, uses two separate full HD streams, whereas SVC uses an "enhancement" stream for the second-eye image that can reduce bandwidth by 40% to deliver full 3D video...." |
#10 | Link |
Software Developer
![]() Join Date: Jun 2005
I think for the user, this is the important part:
http://git.videolan.org/?p=x264.git;...b88dfa7edbccb6
#11 | Link |
So now x264 is a full fledged MVC encoder? Is MVC really only adding those Flags (and reordering the two streams accordingly)?
*edit* This post clarified it. This is "only" a patch to create 3D flagged AVC and not MVC. Last edited by Disabled; 16th December 2010 at 03:47. |
#12 | Link | |
x264 developer
#13 | Link |
Dark Shikari: Is one stereoscopic packing mode more effective compression-wise than the others? Column interlacing and checkboard look pretty awful to me in this aspect, but I'm not sure how top/bottom compares with left/right.
#14 | Link | |
x264 developer
Top/bottom is better than left/right for parallelism. left/right should probably never be used. Frame interleaving may be better for compression, especially once x264 gets awareness of the frame interleaving occurring. I will probably be working on this after the end of this semester. |
#17 | Link |
http://www.pantarheon.org/AviSynth3DToolbox/
avisynth script > MVC encoding capable x264- inside MeGui... |
#20 | Link | |
Derek Prestegard IRL
![]() Join Date: Nov 2003
The bits of test encoding I did last year was mostly left/right encoded, stuffed in a 1920x1080 frame, so each view got ~ 960x1080 pixels. I had assumed the same as kieranrk, that the loss in horizontal resolution was preferable to vertical resolution.
How would you encode two pictures side by side without cutting resolution? I'd guess Double width frames, i.e. 3840x1080 or 2560x720? Interesting! Also, @eddman: Quote:
Derek
These are all my personal statements, not those of my employer :) Last edited by Blue_MiSfit; 16th December 2010 at 11:51. |
| Tags |
| stereo-3d, stereoscopic, useless |
| Display Modes | |
