#32101 | Link | |
![]() Join Date: Oct 2001
Things that will override FORCE_NOENCODE: - Having filters set -- it can't process filters without reencoding. - Setting a forced CRF value with FIXED_CRF=nn - Running in ARCHIVE mode - Having FORCE_ENCODE=1 set - Output of non-UHD source to UHD format - The source was an HEVC archive created by BD-RB And, of course, the source video must be legal. Last edited by jdobbs; 5th January 2025 at 17:14. |
#32103 | Link |
No encode still encoded
Unfortunately, it still tried to encode:
[01/04/25] BD Rebuilder v0.62.11 [20:44:29] Source: LOST_IN_SPACE-S1-D1 - Input BD size: 22.63 GB - Approximate total content: [04:42:36.272] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - AVS Filtering is enabled - Quality: High Quality (Default), 1-Pass VBR - UHD-BD source detected. - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [20:44:37] PHASE ONE, Encoding - [20:44:37] Processing: VID_00001 (1 of 5) - [20:44:37] Extracting A/V streams [VID_00001] - [20:46:11] Reencoding video [VID_00001] - Source Video: HEVC, 3840x2160 - Rate/Length: 23.976fps, 90,281 frames - Bitrate: 9,845 Kbs - [20:46:11] Reencoding: VID_00001, Pass 1 of 1 [20:46:12] - Failed video encode, aborted Code:
[Options] VERSION=0.62.0.11 ENCODER=1 MODE=0 TARGET_SIZE=23500 AUTO_BURN=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=0 SD_TO_1080=0 IGNORE_3D=1 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AUDIO_DRC=0 DECODER=2 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=1 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23500 MENU_BACKGROUND=F:\BD-Rebuilder\Lost_in_Space\Lost_In_Space-BD-bkg-S1-D1.jpg MENU_AUDIO=F:\BD-Rebuilder\Lost_in_Space\Lost_in_Space-S1-closingtheme.ac3 IMPORT_THRESHOLD=0 QUICK_PLAY_THRESHOLD=0 MENU_AUTO_BACKGROUND=0 MENU_AUTO_DVDAUDIO=1 MENU_FORCE_QUICK=1 MENU_PLAY_SEQUENTIAL=0 MENU_START_WITH_MENU=1 IMPORT_LIMIT_LANG=0 IMPORT_KEEP_PLAYALL=0 IMPORT_VFR_SCAN=0 FORCE_NOENCODE=1 MENU_FONT=Century Gothic MENU_FONT_BOLD=1 MENU_FONT_ITALIC=0 MENU_HORIZONTAL=320 MENU_VERTICAL=700 MENU_ACTIVE_COLOR=0xF6DC95 MENU_CUSTOM_COLOR= MENU_INACTIVE_COLOR=0xFBB902 MENU_BACKDROP_OPACITY=0 MENU_ROLLOVER=1 MENU_ITEMS_PAGE=10 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=0 IMPORT_VFR_FILM=0 IMPORT_PREPARE_MKV=0 NVENC_CAPABLE=1 UHD_CONVERT_ENABLE=0 UHD_V3_MODE=1 FORCE_ENCODE=0 AVSFilter01=addborders(0,120,0,120) [Paths] WORKING_PATH=F:\BD-REBUILDER\WORK\ SOURCE_PATH=F:\BD-REBUILDER\LOST_IN_SPACE\LIS-S1-D1-TEST\ DGIndexNV=C:\Program Files (x86)\DGAVCDecNV\DGIndexNV.exe DGDecNV=C:\Program Files (x86)\DGAVCDecNV\DGDecodeNV.dll [Batch] MAIN_MPLS=00002.MPLS MAIN_MPLS_ANGLE=0 FORCED_SUB=0 FORCED_AUD=0 AUDIO=11 SUBS=1111 I wondered if "USE_FILTERS=1" might have caused it to re-encode. Nope, setting it to zero only caused the re-encode not to fail. |
#32104 | Link |
[01/04/25] BD Rebuilder v0.62.11 [20:44:29] Source: LOST_IN_SPACE-S1-D1 - Input BD size: 22.63 GB - Approximate total content: [04:42:36.272] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - AVS Filtering is enabled - Quality: High Quality (Default), 1-Pass VBR - UHD-BD source detected. - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [20:44:37] PHASE ONE, Encoding - [20:44:37] Processing: VID_00001 (1 of 5) - [20:44:37] Extracting A/V streams [VID_00001] - [20:46:11] Reencoding video [VID_00001] - Source Video: HEVC, 3840x2160 - Rate/Length: 23.976fps, 90,281 frames - Bitrate: 9,845 Kbs - [20:46:11] Reencoding: VID_00001, Pass 1 of 1 [20:46:12] - Failed video encode, aborted To use filters you must re-encode Disable AVS Filtering One more thing HEVC sources are always encoded as per jdobbs. (see post before yours) Where is Lathe when you don't need him? Last edited by gonca; 5th January 2025 at 11:48. |
#32105 | Link | |
#32108 | Link |
Re-reading it: the source for the project is a UHD BDRB created folder with HEVC MKV videos that have DD+ ATMOS audio. Yes, the initial run resulted in the DD being recoded. I then ran the newer TSMuxer to rebuild the M2TS files with the original audio. That folder was then run thru BDRB to repackage the UHD formatted layout to make sure that the disc I would then create would play. The initially created folder fits within a 25GB disc. But, BDRB wan't to recode it, no matter what. The log even says reports "UHD-BD source detected."
After doing the above posting I started the reworking of the project by using the original MKV files, which I originally recoded to fit within 25GB. I did some work to update/add chapter marks. After doing the work I mentioned above, I then hauled that UHD-BD layout into BDRB to let it do the recoding so that the project fits within a 25GB disc. But, I ran into a problem. BDRB errored out. Turns out I not only needed to replace the tsmuxer.exe file in tools, but the tsmuxer4k.exe as well. I have two version of BDRB installed, one original and the other new. Can't remux DD+ audio with the older tsmuxer. Of course, with the newer tsmuxer the demuxing creates audio and subtitle files with file name that BDRB was not expecting. Therefore, BDRB fails during the recoding. I then rename the files back to what is expected and resume the job. I have to babysit the job for each of the videos within the project. It would be nice (begging) if BDRB would use the newer tsmuxer so that it would handle DD+ audio. Yes, I know, coreless DD+ is not compliant. But, if tsmuxer will created UHD disc folders with coreless DD+, why not BDRB? Way back when, BDRB initially had issues figuring out what bitrate to use to make everything fit because the TrueHD-MA audio streams weren't seen and not included in the overall size, resulting in my manually setting disc size. As the job is in progress as I write this, I don't know if BDRB will create a UHD-BD folder that will fit the 25GB disc. [...] The job is now finished and it fits! Burning disc now and will test later. Frankly, I don't even know what archive mode is, as I've never set anything to do that. If I read your posting correctly, what I am doing doesn't fit your requirement for recoding, i.e., if the sourced UHD-BD folder will already fit a disc. |
#32109 | Link |
Well, that was a bust. Letting BDRB do everything, i.e., taking the initial oversized UHD-BD and recode everything to fit 25GB failed to play. The menu plays just fine, but when I select an episode from the menu, the player goes back to the player's main menu. But, the initial UHD-BD disc that I created with the manually recoded videos and remuxed audio, plays just fine. I'm totally confused now.
#32110 | Link |
There is a workaround to this issue, although having BDRB do the whole thing from beginning to end would save a boat-load of work.
There is work outside of BDRB that needs to be done for this particular job and that is creating chapter marks and turning on the force flag for those foreign language translation subtitles. The first thing that needs to be done is to recode the videos so that they will fit on a BD25. That, unfortunately, is trial and error. Second is to import the videos that will be placed on a disc into BDRB. No need to use a modified BDRB installation that has the newer tsmuxer. BDRB will recode the DD+ audio streams, no matter what. Third, the original DD+ audio streams need to be remuxed into the newly created M2TS files, replacing the DD with DD+. In this case, the latest overnight build of tsmuxer must be used. The UHD-BD layout can then be burned to disc. Even though the audio streams are replaced, the configuration of the disc is not affected by the replaced audio and will play just fine. Your UHD hardware player must be able to play coreless DD+ audio (mine does). Lastly, to make things complete, the UHD beta version of BDEdit should be used to change the audio type of each of the playlists from DD to DD+. The disc will play fine without doing this change. At least it does for me. |
#32111 | Link |
Skipping recode but keeping the video
When I browse for a BD layout for doing a backup, it contains a bunch of short 1 second files. Various playlists are using them to add 1 sec of black to the end, which also creates a chapter point to jump to in order to skip to the end. Why they didn't add 1 sec of black to the main file and just chapter mark it is beyond me.
How do I tell BDRB to skip those files, but keep them in the final result? I have the following set: Code:
IMPORT_THRESHOLD=2 QUICK_PLAY_THRESHOLD=2 There are files missing from the list that are longer than 2 minutes. One of them is a special feature file of still images, yet BDRB isn't going to recode it. BDRB fails early on in the backup with a 720p/59.94 video in which the encoder did 30 frames, but expected 60. Right before this one, I did a UHD backup and it only contains 2160p and 1080p videos. It did skip a bunch of files, but what was weird is that it didn't skip files that were in the 18 KB range. Those got recoded to the 24 KB range. Five videos that were larger than that were skipped. Weird. I guess I do not know what the rules are for skipping files for recoding. Thanks for any pointers.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 9th January 2025 at 07:39. Reason: New info |
#32113 | Link | |
MIN_M2TS_SIZE=n (n=100 is the default) MIN_PLAYLIST_MINS=n (n=15 is the default) If you want to encode everything, you should set each option to 0 By default BD-RB doesn't reencode menus unless it is required for some reason. So if you want menus to be reencoded, you can do so by adding this hidden opt: REENCODE_MENUS=1 Last edited by jdobbs; 11th January 2025 at 00:32. |
#32114 | Link | |
I'll have to try something and report back. REPORTING BACK: I set MIN_M2TS_SIZE=10 and it left a bunch of files that are < 1 MB on the list to be processed. Come to think of it, the default of 100 left those same < 1 MB files on the list. No clue as to what it takes to remove files < 10 MB.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 11th January 2025 at 05:01. |
#32115 | Link | |
#32116 | Link |
Hi. I have the latest version of avisynth and my inspect shows that it is not recommended. Is this a problem?
[01.11.25] Checking System Settings - BD-Rebuilder v0.62.12 - Windows Version: 6.2 [9200] - Working Path Free Space: 1 384,26GB - AVISYNTH Version: 3.7.3.0, not recommended version - LAVFILTERS: Ok - AnyDVD Remove Short Titles: Incompatible - AnyDVD Remove Annoying Adverts: Incompatible - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [01.11.25] Systems Settings Check complete |
#32117 | Link | |
