Old 11th December 2024, 22:13   #32081  |  Link
jdobbs
Originally Posted by varekai View Post
That's interesting! Thanks for the info! Can I ask what NVIDIA GPU you use?
I have this Geforce RTX 4060 8GB and never tried encoding with it, next project I will try it with your settings.
I have a GeForce GTX 1660.
If you look at this link you'll see that your card has more capability than mine (like AV1 encoding). I would guess it is faster too.
Website: www.jdobbs.net
Old 12th December 2024, 05:43   #32082  |  Link
MrVideo
MrVideo's Avatar
Nice card, but I can't get one. The driver is Win10/11.
Give the software a run and see what you think of the results.
Old 13th December 2024, 09:43   #32083  |  Link
varekai
varekai's Avatar
@jdobbs
@MrVideo
Thanks for the link and info, will test with GPU on the next project.
Will run one encode with GPU and one with software/CPU and compare them.
varekai is offline   Reply With Quote
Old 16th December 2024, 01:48   #32084  |  Link
SquallMX
Special SeeD
Be aware GPU encoding is awful for grainy content. You should use software encoding with that kind of content.
SquallMX is offline   Reply With Quote
Old 16th December 2024, 03:21   #32085  |  Link
Lathe
Lathe's Avatar
That's interesting... Although I don't have the right GPU to do it, it seems odd that whatever you are using to do the mechanics of encoding, I don't understand why whether the GPU does it or the CPU, aren't the math and computations exactly the same? Why are there different results...? Just curious...
Lathe is offline   Reply With Quote
Old 16th December 2024, 10:55   #32086  |  Link
musiclover
For a project I had to convert a music video clip from PAL to NTSC. I used GPUENCC with INTEL GPU. The resulting video was fine but the audio was out of sync and kept getting further out of sync. Then I changed GPUENCC to reencoding with NVIDIA GPU and the audio in the result was completely in sync but the video was somewhat stammering or stuttering. The length of the original file was 3:32 minutes. The INTEL GPU changed that to 3:41 minutes while the NVIDIA GPU kept the 3:32 intact.
[12.16.24] GPU Reencoder v0.01.17
[10.36.20]Start Job [1 of 1]
- Reencoding "6. David Gilmour with Romany Gilmour - Yes, I Have Ghosts (Official Music Video).mp4"
-- Using INTEL GPU for Video Encode
-- Collecting input file information...
-- Input : AVC, 1920x1080, 25fps
-- Vid: H264 (AVC), No Resize, 23.976 fps, CQ 18
-- Aud: Intact (Keep Original), no reencode
-- Remuxing output with MKVMERGE
[10.36.56]Job Completed [1 of 1]
[10.49.52]Start Job [1 of 1]
-- Using NVIDIA GPU for Video Encode
[10.50.21]Job Completed [1 of 1]
musiclover is offline   Reply With Quote
Old 16th December 2024, 16:22   #32087  |  Link
jdobbs
Interesting. I personally haven't had any issues with that any kind of content using GPU.
Old 17th December 2024, 05:45   #32088  |  Link
SquallMX
Special SeeD
No, software encoding is slower but can use more advanced/complex ways to save bits.
Try something like Ghostbusters (the original one), even at BD50 bitrate the output created by NVEnc looks denoised and has this pulsating effect, the one encoded with x265 is superior in every way.
Old 17th December 2024, 05:50   #32089  |  Link
Lathe
Lathe's Avatar
Ah, good to know, thanks! Now I don't feel like I'm missing out so much... For me, re-encoding to a BD25 (movie only) even with very strong but compatible settings might take the better part of two hours. A film that is smaller and doesn't need quite so high settings may take about 45 minutes, so that is fine with me.
Old 17th December 2024, 18:05   #32090  |  Link
jdobbs
Unfortunately the resizing and syncing, etc, is done by NVENCC and QSVENCC (I think they use the FFMPEG libraries). You might want to try downloading a newer version of those and see if you have better luck.
Old 18th December 2024, 17:07   #32091  |  Link
musiclover
The newer versions didn't do it for me. So I used the video from the INTEL GPU and combined that with the audio that I stretched with 104,27%. It gave a good result. It's a pity that I couldn't get GPUENCC to do it. But I understand that is up to QSVENCC. And the choppy video was the fault of NVENCC.
UPDATE
I found an other way to get it done. Using BD_RB with the hidden option IMPORT_PAL_TO_FILM=1. It gave an excellent result. And BD_RB did the stretching for me.
Old 26th December 2024, 18:04   #32092  |  Link
DeathStalker77
Hello!
I have tried the last 3 versions & the current beta version, with & without the add-ons, different versions of AVISynth, and using different encoders, but I still get the error message - PredictAndEncode() 00006 2803
Thank you for any assistance!!!
--- DS
DeathStalker77 is offline   Reply With Quote
Old 26th December 2024, 18:23   #32093  |  Link
musiclover
Originally Posted by DeathStalker77 View Post
Hello!
--- DS
You get this error when the source stream was encoded at a framerate that is not allowed in Blu-ray. Acceptable framerates are: 23.976, 24, 25, 29.97, 50, 59.94 -- even then some are only compliant with certain frame sizes.
Old 26th December 2024, 18:55   #32094  |  Link
DeathStalker77
So how can I fix it? I am just shy of being able to just burn it -- 24,963MiB vs disc size of 23,866MiB. Can that much be done with Overburn?
--- DS
Old 26th December 2024, 21:46   #32095  |  Link
jdobbs
Hello!
--- DS
I can tell you that it is an overflow error, and that it is probably happening while trying to calculate space requirements (based on the 2803 error locator code). But that's about it.
Old 26th December 2024, 22:07   #32096  |  Link
DeathStalker77
There is more than enough space on the drive (over 100gb). It gets to ~93% Overall Progress. This was using FRIMSOURCE for Frame Serving (I've tried all the others except DGDecNV, as I do not have that exe). I have also tried AUTOMATIC QUALITY -
UPDATE: DoH! It was a bad file in the mix :-(
--- DS
Old 29th December 2024, 20:02   #32097  |  Link
Mark_Venture
Sorry if I missed it, but is it expected that GPUENCC/NVEncC removes DV/DoVi profile 7.6 (dvhe.07.06) when re-encoding video? Thankfully it does at least leave the HDR10 there.
Input file (ripped from disc using MakeMKV):
Video
ID in the original source medium         : 4113 (0x1011)
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5.1@High
HDR format                               : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Codec ID                                 : V_MPEGH/ISO/HEVC
Duration                                 : 2 h 45 min
Bit rate                                 : 65.2 Mb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.328
Stream size                              : 75.1 GiB (90%)
Language                                 : English
Default                                  : No
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0001 cd/m2, max: 1000 cd/m2
Original source medium                   : Blu-ray
Output file:
Video
Format                                   : HEVC
Format profile                           : Main 10@L5@High
HDR format                               : SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 38.0 Mb/s
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.191
Stream size                              : 43.9 GiB (84%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
GPULASTCMD.TXT
"D:\BD-RBV06212\tools\nvenc\nvencc.exe" --avhw -i "C:\ReEncode\Transformers Age of Extinction\Transformers Age of Extinction {edition-4K Disc}.mkv" --codec h265 --preset default --profile main10 --output-depth 10 --chromaloc auto --colorprim auto --transfer auto --colormatrix auto --master-display copy --max-cll copy --qp-min 0 --multipass 2pass-full --vbr 0 --vbr-quality 21 --aq --aq-temporal --aud --pic-struct --vbv-bufsize 45000 --max-bitrate 48000 --lookahead 24 --no-b-adapt --gop-len 24 --audio-copy 1 --audio-copy 2 --audio-copy 3 --audio-copy 4 --audio-copy 5 --sub-copy 1,2,3 --chapter-copy -o "C:\REENCODE\WORKING\Transformers Age of Extinction {edition-4K Disc}.mkv"
GPUREENC.LOG
[12/29/24] GPU Reencoder v0.01.17
[12:24:01]Start Job [1 of 1]
- Reencoding "Transformers Age of Extinction {edition-4K Disc}.mkv"
  -- Input : HEVC, 3840x2160, 23.976fps
  -- Vid: H265 (HEVC), No Resize, Keep fps, CQ 21
[13:15:12]Job Completed [1 of 1]
Mark_Venture is offline   Reply With Quote
Old 31st December 2024, 10:20   #32098  |  Link
iambryanknowles
The program hangs on trying to convert Opus audio.
iambryanknowles is offline   Reply With Quote
Old 4th January 2025, 12:05   #32099  |  Link
MrVideo
MrVideo's Avatar
Forcing no encoding
I want BDRB to read in a disc and not re-encode any of the videos it will end up keeping. The following is in the config:
FORCE_NOENCODE=1
FORCE-ENCODE=0
Yet, BDRB goes ahead and encodes anyway. Is there something else that needs to be set?
Old 4th January 2025, 13:11   #32100  |  Link
gonca
Originally Posted by MrVideo View Post
FORCE_NOENCODE=1
FORCE-ENCODE=0
Try FORCE_ENCODE=0
If this doesn't work then post the log
gonca is offline   Reply With Quote
