Old 19th July 2024, 09:22   #31881  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by Lathe View Post
So, the ones where it says 2.6 and 'above', can I then just drop them in my new AVS+ plugins folder or do I have to put them in my old 2.6 plugins folder?
You can put the 32 bits versions in the old 2.6 (2.5 really) plugins folder, they can be used also with Avs+ 32 bits.
Old 19th July 2024, 11:13   #31882  |  Link
gonca
I'll check them out, thanks!
***EDIT
You can also keep them in their own folder and load them manually/explicitly
gonca is offline   Reply With Quote
Old 19th July 2024, 23:12   #31883  |  Link
Lathe
Lathe's Avatar
Thanks guys!
Lathe is offline   Reply With Quote
Old 21st July 2024, 02:58   #31884  |  Link
dietachi
@jdobbs
I want to check your requirements to test the encoding to check its compatibility with VCEEnc.
I have a Ryzen 5 5600G APU and a Radeon RX 7600 GPU for testing.
Maybe not in the planning, but it might be an add-on for the future.
Thank you.
dietachi is offline   Reply With Quote
Old 21st July 2024, 14:20   #31885  |  Link
Blurayhd
Originally Posted by MrVideo View Post
You are complainig about DTS being converted to AC3, when that is not the case:
[13:14:29] Importing MKV: SISU.2022.BDREMUX.1080P.H.264-LMHD
 - Collecting audio/video streams from source...
 - Converting audio, Track #3, THD to AC3...
Read again what you posted. It is THD that is being converted, not DTS.
I can't make it possible for bdrebuilder to create a disk for me with truehd
Blurayhd is offline   Reply With Quote
Old 21st July 2024, 15:58   #31886  |  Link
gonca
BD requires an AC3 core interleaved with a THD track.
MKV does not support that.
Maybe that is why BDRB will not create a BD with a THD track, not compliant in your case.
Old 21st July 2024, 21:22   #31887  |  Link
Lathe
Lathe's Avatar
MKV's do not natively have the AC3 core in the TrueHD file. So, you need to use a program like Eac3to (like I do to do this very thing) drop the MKV file in the interface, in the dropdown menu choose the True file, and then to the right of it, choose the TrueHD+AC3. I always also choose to the right of that 'No 2nd encode' just to avoid that, but that is your choice. Then below that you click on Run CMD Line.
The resulting file will be a TruHD+AC3 file which will show in TSMuxer so that you can mux it back into a BDMV folder format for BDRB to import and process.
(It's nice to be able to help somebody ELSE sometimes! )
Old 22nd July 2024, 14:27   #31888  |  Link
jdobbs
Originally Posted by dietachi View Post
@jdobbs
Thank you.
I'll take a look at it. One thing I noticed right away was its lack of a smart "constant quality" mode. You either have to set a cbr/vbr bitrate, or set a constant quantizer (selectable by frame type). But, other than that, most of the command line parameters seem to line up with NVENCC and/or QSVENCC. Personally, I use constant quality for most of my encoding. I even get annoyed at QSVENCC for only allowing an integer for the constant quality value. It limits how accurate the prediction/sizing can be in that mode.
Another limitation is that I don't personally have a system with the AMD GPU -- so I'd rely completely on someone else to test it.
Website: www.jdobbs.net
Old 23rd July 2024, 10:30   #31889  |  Link
dietachi
Thank you, I will try that out.
One problem I can tell is that each generation if AMD GPUs and APUs has different options that may not work in the next or the previous one. Example B-frames are not supported by all AMD cards, unfortunately.
As for QSVEnc the only option I found to further fine tune CQP is
--qp-offset <int>[:<int>][:<int>]...
Set qp offset of each pyramid reference layers. (default = 0)
But I did not test that for BluRay or UHD.
Old 23rd July 2024, 16:05   #31890  |  Link
jdobbs
I think I may try to implement it for testing at least... but trying that without having a VCE GPU of my own may be asking for trouble.
Would you mind running the following commands from a CMD window and post the output here?
\pathto\VCEEncC.exe --check-hw
\pathto\VCEEncC.exe --check-features
Old 23rd July 2024, 22:02   #31891  |  Link
Blurayhd
Hello, encoding with Nvidia or Intel also maintains the amazing quality than encoding with x264? thank you in advance
Old 23rd July 2024, 23:19   #31892  |  Link
dietachi
Sure
I'll run the commands once I'm back at one of the machines. Might take a while.
Old 23rd July 2024, 23:32   #31893  |  Link
jdobbs
I did extensive testing using SSIM and PSNR comparisons (to reduce subjectivity). Both scored with roughly equal quality at approximately the same output size. You just have remember to use different constant quality settings (the values aren't 1:1).
Old 24th July 2024, 09:15   #31894  |  Link
dietachi
I did run the checks.
For the RX 7600.
Please find below:
--check-hw
VCEEnc (x64) 8.23 (r1710) by rigaya, Jul 18 2024 12:57:57 (VC 1940/Win)
AMF Version 1.4.34
reader: raw, avs, vpy, avsw, avhw
VCE available
device #0: AMD Radeon RX 7600
Supported Codecs:
H.264/AVC
H.265/HEVC
AV1
--check-features
H.264/AVC encode features
acceleration:    Hardware-accelerated
max profile:     High
max level:       unknown
max bitrate:     1000000 kbps
ref frames:      1-16
Bframe support:  yes
HW instances:    1
pre analysis:    yes
max streams:     16
timeout support: yes
smart access:    no
H.264/AVC input:
Width:       128 - 4096
Height:      128 - 4096
alignment:   32
Interlace:   no
pix format:  YUV420P[7], YV12[2], BGRA[3], RGBA[5], ARGB[4], NV12[1](native)
memory type: DX11(native), OPENCL, OPENGL, HOST
H.264/AVC output:
Width:       128 - 4096
Height:      128 - 4096
alignment:   32
Interlace:   no
pix format:  NV12[1](native)
H.265/HEVC encode features
10bit depth:     yes
max profile:     main10
max level:       unknown
ref frames:      1-16
pre analysis:    yes
max streams:     16
smart access:    no
H.265/HEVC input:
Width:       128 - 8192
Height:      128 - 4352
alignment:   32
Interlace:   no
pix format:  YUV420P[7], YV12[2], BGRA[3], RGBA[5], ARGB[4], NV12[1](native), P010[10](native)
H.265/HEVC output:
Width:       128 - 8192
Height:      128 - 4352
alignment:   32
Interlace:   no
pix format:  NV12[1](native), P010[10](native)
AV1 encode features
10bit depth:     yes
max profile:     main
max level:       unknown
Temporal layers: 4
pre analysis:    yes
max streams:     1
timeout support: no
smart access:    no
AV1 input:
Width:       128 - 8192
Height:      128 - 4352
alignment:   32
Interlace:   no
AV1 output:
Width:       128 - 8192
Height:      128 - 4352
alignment:   32
Interlace:   no
H.264/AVC decode features
10bit depth:     no
max streams:     16
smart access:    no
H.264/AVC output:
Width:       32 - 4096
Height:      32 - 4096
alignment:   32
Interlace:   yes
pix format:  NV12[1](native), P010[10](native), P012[19](native), BGRA[3], RGBA[5]
H.265/HEVC decode features
10bit depth:     yes
max streams:     0
smart access:    no
H.265/HEVC output:
Width:       32 - 7680
Height:      32 - 4320
alignment:   32
Interlace:   yes
VP9 decode features
10bit depth:     yes
max streams:     16
smart access:    no
VP9 output:
Width:       32 - 7680
Height:      32 - 4320
alignment:   32
Interlace:   yes
AMFVideoConverter features
acceleration:    GPU-accelerated
input:
Width:       32 - 2147483647
Height:      32 - 2147483647
alignment:   2
Interlace:   no
pix format:  NV12[1](native), YV12[2](native), BGRA[3](native), ARGB[4](native), RGBA[5](native), YUV420P[7](native), YUY2[9](native), UYVY[12](native)
memory type: DX11(native), OPENCL(native), OPENGL(native), HOST
output:
alignment:   2
Interlace:   no
AMFHQScaler features
input:
Width:       32 - 8192
Height:      32 - 4096
alignment:   2
Interlace:   no
pix format:  NV12[1](native), BGRA[3](native), ARGB[4](native), RGBA[5](native), P010[10](native), RGBA_F16[11](native), R10G10B10A2[13](native)
output:
Width:       32 - 16384
Height:      32 - 8192
alignment:   2
Interlace:   no
AMFVQEnhancer features
input:
Width:       32 - 8192
Height:      32 - 4096
alignment:   2
Interlace:   no
output:
Width:       32 - 16384
Height:      32 - 8192
alignment:   2
Interlace:   no
Please find below results for the Ryzen 5 5600g APU (Vega 7 if I am not mistaken)
--check-hw
AMF Version 1.4.34
VCE available
Supported Codecs:
H.264/AVC
H.265/HEVC
--check-features
max profile:     High
max level:       unknown
ref frames:      1-16
Bframe support:  no
HW instances:    1
pre analysis:    yes
max streams:     16
smart access:    no
H.264/AVC input:
Width:       128 - 4096
Height:      128 - 4096
alignment:   32
Interlace:   no
H.264/AVC output:
Width:       128 - 4096
Height:      128 - 4096
alignment:   32
Interlace:   no
10bit depth:     yes
max profile:     main
max level:       unknown
ref frames:      1-16
pre analysis:    yes
max streams:     16
smart access:    no
H.265/HEVC input:
Width:       128 - 4096
Height:      128 - 4096
alignment:   32
Interlace:   no
H.265/HEVC output:
Width:       128 - 4096
Height:      128 - 4096
alignment:   32
Interlace:   no
10bit depth:     no
max streams:     16
smart access:    no
H.264/AVC output:
Width:       32 - 4096
Height:      32 - 2160
alignment:   32
Interlace:   yes
10bit depth:     yes
max streams:     0
smart access:    no
H.265/HEVC output:
Width:       32 - 7680
Height:      32 - 4320
alignment:   32
Interlace:   yes
MPEG2 decode features
10bit depth:     no
max streams:     16
smart access:    no
MPEG2 output:
Width:       32 - 1920
Height:      32 - 1080
alignment:   32
Interlace:   yes
VP9 decode features
10bit depth:     yes
max streams:     16
smart access:    no
VP9 output:
Width:       32 - 7680
Height:      32 - 4320
alignment:   32
Interlace:   yes
VC-1 decode features
10bit depth:     no
max streams:     16
smart access:    no
VC-1 output:
Width:       32 - 1920
Height:      32 - 1080
alignment:   32
Interlace:   yes
input:
alignment:   2
Interlace:   no
output:
alignment:   2
Interlace:   no
input:
Width:       32 - 8192
Height:      32 - 4096
alignment:   2
Interlace:   no
output:
Width:       32 - 16384
Height:      32 - 8192
alignment:   2
Interlace:   no
input:
Width:       32 - 8192
Height:      32 - 4096
alignment:   2
Interlace:   no
output:
Width:       32 - 16384
Height:      32 - 8192
alignment:   2
Interlace:   no
Old 24th July 2024, 13:38   #31895  |  Link
jdobbs
Thanks. That helps.
Old 25th July 2024, 14:07   #31896  |  Link
dietachi
Thanks. That helps.
Welcome.
Old 25th July 2024, 21:12   #31897  |  Link
jdobbs
New Release of BD-Rebuilder (v0.62.06)
I have updated the first post of this thread with a link to the most recent release (v0.62.06) of BD-RB. Changes for this release:
- Added code to correct resizing when using
  Intel GPU on imported sources that are not
  standard resolutions to make up for its
  unusual resize-before-padding behavior.
- Added similar resizing adjustments to
  GPUENCC for when padding and resizing are
  required.
- Corrected an issue in which resizing an SD
  4:3 source to 1080p or 720p source while
  forcing UHD output could result in output
  with an incorrect aspect ratio.
- Corrected an issue in which non-UHD HEVC
  files that are imported cause the pseudo
  BD Structure to be flagged as UHD-BD, and
  results in reencoding to HEVC and the
  creation of a UHD-BD structure when
  performing a rebuild.
- Removed QSYNC_TEST requirement to enable
  Intel Quick Sync testing/usage. It is now
  available by default -- but, of course, it
  only works for those with appropriate GPUs.
- Other minor corrections and cosmetic fixes.
Old 25th July 2024, 23:25   #31898  |  Link
Blurayhd
  required.
Thank You Jdobbs, how to know if my GPU Intel is good enough?
Old 26th July 2024, 01:57   #31899  |  Link
Lathe
Lathe's Avatar
Hmmm... I know I'm forgetting something, but I'm trying to convert an HEVC MKV file into an x264 archive file (AVC/AC3) but, I keep getting errors. I tried first using alternate output 1920x1080 keep intact audio, and then I tried the archive backup that I mention above. Both failed... I've attached the MediaInfo txt file of the original MKV file.
Oh, I see that attachments need to be 'Approved', so please forgive me, but I'll just add the file information below then.
***EDIT
Okay, I tried reinstalling AVS from your #1 page here. I had installed the newest version because everyone said it would work, but with BDRB it did not. But, it still failed. I'll include the failed information below the MediaInfo of the original file.
Here are the logs:
[Status]
LABEL=IL.SORRISO.DELLA.IENA.1972.1080P.BLURAY.DUAL.DDP.1.0.X265-SM737
VERSION=v0.62.01
SOURCE_SIZE=3290222716
SOURCE_VIDEO_SIZE=3290204160
TARGET_SIZE=24851251200
REDUCTION=7.55309744791034
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=-1
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
UHD_V3_MODE=0
QUICK=1
ENCODE_STEP=1.5
[00000]
AUDIO=111
PGS=11
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=24851232644
SPLITS=1
[17:47:08] Importing MKV: IL.SORRISO.DELLA.IENA.1972.1080P.BLURAY.DUAL.DDP.1.0.X265-SM737
- Preparing MKV for processing...
- Building pseudo-BD source structure...
[17:47:49] Video import completed successfully.
[07/25/24] BD Rebuilder v0.62.01
[17:50:24] Source: IL.SORRISO.DELLA.IENA.1972.1080P.BLURAY.DUAL.DDP.1.0.X265-SM737
- Input BD size: 3.06 GB
- Approximate total content: [01:28:20.420]
- Windows Version: 6.2 [9200]
- Archive Backup (AVC/AC3) mode enabled
- Quality: High Quality (Default)
- X264 Tweak(s) enabled
- UHD-BD source detected.
- Decoding/Frame serving: FFMPEG
- Resuming from previously started job.
[17:50:26] PHASE ONE, Encoding
- [17:50:26] Processing: VID_00000 (1 of 1)
- [17:50:26] Reencoding video [VID_00000]
- Source Video: HEVC, 1920x1080
- Rate/Length: 23.976fps, 127,083 frames
- [17:50:26] Reencoding: VID_00000, Pass 1 of 1
- Encode failed. Aborting.
- BD-Rebuilder v0.62.01
- Working Path Free Space: 184.86GB
- AVISYNTH Version: 2.5.8.0, Ok
- LAVFILTERS: Ok
- X264: Ok
- X265: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[17:50:28] - Failed video encode, aborted
[17:51:08] Importing MKV: IL.SORRISO.DELLA.IENA.1972.1080P.BLURAY.DUAL.DDP.1.0.X265-SM737
[17:51:46] Video import completed successfully.
[17:51:54] Source: IL.SORRISO.DELLA.IENA.1972.1080P.BLURAY.DUAL.DDP.1.0.X265-SM737
[17:51:55] PHASE ONE, Encoding
- [17:51:55] Processing: VID_00000 (1 of 1)
- [17:51:55] Extracting A/V streams [VID_00000]
- [17:52:08] Reencoding video [VID_00000]
- [17:52:08] Reencoding: VID_00000, Pass 1 of 1
- LAVFILTERS: Ok
- X264: Ok
- X265: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[17:52:09] - Failed video encode, aborted
Original HEVC MediaInfo file:
General
Unique ID : 67595281969964806923358460752008863402 (0x32DA60B52D0A1DC136A0CDC9BAB45EAA)
Complete name : D:\__MKVMerge\Il.sorriso.della.iena.1972.1080p.BluRay.DUAL.DDP.1.0.x265-SM737.mkv
Format : Matroska
Format version : Version 4
File size : 2.84 GiB
Duration : 1 h 28 min
Overall bit rate : 4 600 kb/s
Frame rate : 23.976 FPS
Encoded date : 2024-07-26 00:44:55 UTC
Writing application : mkvmerge v86.0 ('Winter') 64-bit
Writing library : libebml v1.4.5 + libmatroska v1.7.1 / Lavf60.16.100
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L4.1@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 3 501 kb/s
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 0)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.095
Stream size : 2.16 GiB (76%)
Writing library : x265 3.5+1-f0c1022b6:[Linux][GCC 13.2.0][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=3 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x800 / interlace=0 / total-frames=0 / level-idc=41 / high-tier=1 / uhd-bd=0 / ref=6 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-eob / no-eos / no-hrd / info / hash=0 / temporal-layers=0 / open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=8 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / no-hist-scenecut / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / no-weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=3500 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=4 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=1 / chromaloc-top=0 / chromaloc-bottom=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass / no-mcstf / no-sbrc
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 192 kb/s
Channel(s) : 1 channel
Channel layout : M
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : 1 s 600 ms
Stream size : 121 MiB (4%)
Title : Commentary with Author Troy Howarth and Film Maker Nathaniel Thompson
Language : English
Service kind : Complete Main
Default : No
Forced : No
Dialog Normalization : -31 dB
dialnorm_Average : -31 dB
dialnorm_Minimum : -31 dB
dialnorm_Maximum : -31 dB
Audio #2
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 kb/s
Channel layout : M
Stream size : 283 MiB (10%)
Language : Italian
Default : No
Forced : No
Audio #3
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 kb/s
Channel layout : M
Language : English
Default : Yes
Forced : No
Text #1
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Bit rate : 16.8 kb/s
Frame rate : 0.215 FPS
Count of elements : 1138
Stream size : 10.6 MiB (0%)
Title : SDH
Language : English
Default : Yes
Forced : No
Text #2
Format : PGS
Muxing mode : zlib
Duration : 1 h 27 min
Bit rate : 14.7 kb/s
Frame rate : 0.186 FPS
Count of elements : 978
Stream size : 9.24 MiB (0%)
Language : English
Default : No
Forced : No
Last attempt:
[18:20:28] Importing MKV: 00000
[18:21:17] Video import completed successfully.
[18:21:22] Source: 00000
[18:21:22] PHASE ONE, Encoding
- [18:21:22] Processing: VID_00000 (1 of 1)
- [18:21:22] Extracting A/V streams [VID_00000]
- [18:21:40] Reencoding video [VID_00000]
- [18:21:40] Reencoding: VID_00000, Pass 1 of 1
- Working Path Free Space: 182.02GB
- AVISYNTH Version: 2.6.0.6, Ok
- LAVFILTERS: Ok
- X264: Ok
- X265: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[18:21:41] - Failed video encode, aborted
Attachments Pending Approval
File Type: txt Il.sorriso.della.iena.1972.1080p.BluRay.DUAL.DDP.1.0.x265-SM737.mkv.MediaInfo.txt
Last edited by Lathe; 26th July 2024 at 02:26. Reason: Adding MediaInfo txt file of original MKV file...
Old 26th July 2024, 11:49   #31900  |  Link
gonca
@Lathe
Try using LAV as frame server and disable your "tweaks" temporarily.
