Old 2nd January 2022, 17:00   #31061  |  Link
gonca
Might be a good idea to have a HIDDENOPTS type file for NVENCCRE.
That is two apps to maintain now.
gonca is offline   Reply With Quote
Old 2nd January 2022, 18:39   #31062  |  Link
DrinkLyeAndDie
DrinkLyeAndDie's Avatar
Sure. No problem.
[Edit] I added the beep. You can get the new EXE from this link. It works just like BD-RB. To enable the beep on completion just add the following to you NVENCCRE.INI file:
COMPLETION_BEEP=1
It will play the contents of Ding.wav in the MISC folder under BD-RB's folder. If that doesn't exist it will play the default "Beep" for your system. The sound will only play if a job is completed (all files), and it will not play if you abort a job.
This will be helpful when multi-tasking. Thank you!
DrinkLyeAndDie is offline   Reply With Quote
Old 3rd January 2022, 05:17   #31063  |  Link
MrVideo
MrVideo's Avatar
For some strange reason, I can't get the menu colors to work. Here are the related INI lines:
MENU_ACTIVE_COLOR=0xA6D1D7
MENU_CUSTOM_COLOR=
MENU_INACTIVE_COLOR=0x32819A
Instead I am getting the default white colors. Even if I change MENU_INACTIVE_COLOR to 0x0000FF, I do not get the red. It is still white.
I'm at a loss.
Old 3rd January 2022, 12:41   #31064  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
For a quick UHD-BD-R/-RE playability test on standalones https://forum.doom9.org/showthread.php?t=183578
I would kindly ask for known to be working (hidden or open) options which enable building such disc.
I will be testing BD-RE-25, BD-RE-50, BD-RE-100 (2 of 3 layers, 3 of 3 layers)
(too long that I did not follow development, my bad, and it took longer until hardware became affordable for me)
Old 3rd January 2022, 15:03   #31065  |  Link
jdobbs
If your source is a UHD disc and outputting to Full Backup or Movie-Only mode, then UHD output will be selected automatically. You can directly select BD-25 and BD-50 from the SETTINGS/OUTPUT OPTIONS menu. In order to output to BD-100, add the following to the "[Options]" area of you BDREBUILDER.INI file:
CUSTOM_TARGET_SIZE=94734
That's twice the default target size BD-RB uses for BD-50. You can use any other value if you think it suits BD-100 better.
You can then select "Custom Target Size" from SETTINGS/OUTPUT OPTIONS.
Please note that if your source is smaller than your output target, BD-RB may decide to not reencode (because if fits as-is). If you want to force reencoding, add the following line to your INI file:
FORCE_ENCODE=1
Even with that set, though, trying to take a smaller source (say BD-25) and stretching to fit a BD-100 will sometimes reach a maximum size for the encoder used. But that is less common.
If you are trying to put a standard BD source to UHD format, you can select "Convert BD to UHD-BD (HEVC) Format" from the SETTING/OUTPUT OPTIONS menu. That might occur if you do something like take two or more BDs and combine them into a single UHD disc. You can do that by simply putting the source BD structures under a single folder and selecting that folder within BD Rebuilder.
Hope that answers your question.
Website: www.jdobbs.net
Old 3rd January 2022, 15:34   #31066  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Originally Posted by MrVideo View Post
For some strange reason, I can't get the menu colors to work......
Out of interest...
If you are backing up one movie per disc, what do you need a menu for?
Old 3rd January 2022, 17:14   #31067  |  Link
jdobbs
MENU_CUSTOM_COLOR=
I'm at a loss.
I just put those values into my INI file and did a test. They seem to have worked correctly. I think the the value you have for ACTIVE is high enough in all three colors (and close enough in value) that is appears whiteish (beige) (A6, D1, and D7).
Make sure the values are located in the "[Options]" section of the INI. Also make sure there are no other instances of that setting higher up in the INI file (the MS subroutine that handles reading INI files will act of the first setting it encounters).
[Edit] I also tried setting MENU_INACTIVE_COLOR=0x0000FF and it came out a bright red.
Old 3rd January 2022, 18:06   #31068  |  Link
Emulgator
Emulgator's Avatar
Many thanks, jdobbs and Happy New Year !
This setting is what I am missing (v0.61.25 here).
Under Output Options I see only 5 lines to tick: BD-5, BD-9, BD-25, BD-50 and Custom.
Encoding Options has no x265 and no UHD entry.
Do I have to specify a hidden option to expose that setting ?
Old 3rd January 2022, 18:13   #31069  |  Link
jdobbs
Same to you!
Old 3rd January 2022, 18:29   #31070  |  Link
musiclover
M
Write UHD_CONVERT_ENABLE=1 in your ini file
musiclover is offline   Reply With Quote
Old 3rd January 2022, 18:50   #31071  |  Link
Emulgator
Emulgator's Avatar
YES ! This was missing, undocumented in Hiddenopts.txt.
Many thanks, musiclover.
There it was: 24th February 2021, 17:13 #30405
Old 3rd January 2022, 19:10   #31072  |  Link
jdobbs
Whoops. Forgot about that.
There are a lot of options that aren't documented -- mainly to prevent confusion and self-inflicted issues. The majority of BD-RB users aren't necessarily BD savvy.
There's also one called UHD_ALL_MODE=1 that allows H.265 encoding of streams that are less than 1080p. While it usually works on many (most?) players -- it violates the UHD-BD spec.
Old 3rd January 2022, 22:16   #31073  |  Link
MrVideo
MrVideo's Avatar
It is a single file.
Old 3rd January 2022, 22:25   #31074  |  Link
MrVideo
MrVideo's Avatar
They are more along the color of gold.
Yep, where they belong and the only ones.
I've used the color settings in the past and they have worked. More investigation is in order.
Old 3rd January 2022, 22:28   #31075  |  Link
SeeMoreDigital
A single file of what? Some kind of movie poster!
Old 4th January 2022, 01:26   #31076  |  Link
MrVideo
MrVideo's Avatar
A single video file, of course.
Old 4th January 2022, 01:48   #31077  |  Link
jdobbs
Where do you have the BD-RB Folder installed? Virtualization, perhaps (in the "Program Files" folder)?
Old 4th January 2022, 05:08   #31078  |  Link
MrVideo
MrVideo's Avatar
Actually I don't. A while back you suggested that I place it directly under C:, which I have for the past couple of releases.
But, before I continue with my findings, a problem that has been happening pretty consistantly while searching this out is that after I save changes to the configuration I get the "file not found" error. It happens right after creating the pseudo-BD. Right before it goes on to do the menu. Between those two steps a dialog box very briefly shows up. No idea what it says as it is on the screen for too short of a time. If I do nothing and restart BDRB and rerun the job, there is no error. This one has been elusive for ages.
Now, on to what I found. Mental error. It came down to my not dealing with the three button states correctly: active, inactive and selected. With only one menu item, it becomes active by default. Thereby it was given the brighter color. For some reason I kept thinking inactive. The inactive color is useless in a single menu.
I suspect that you saw the red work because you had at least two menu items. I failed to mention that I only had one.
Old 4th January 2022, 10:02   #31079  |  Link
SeeMoreDigital
If all you're muxing is a single video file, why do you need a menu (which is another video file)?
Old 4th January 2022, 10:12   #31080  |  Link
MrVideo
MrVideo's Avatar
As the old saying goes: Because I Can!
