Old 30th December 2021, 13:25   #31041  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Originally Posted by MrVideo View Post
Before you ask about the chapter marks, it seems that whomever did the chapter marks failed to create them all....
Hmmm... This would suggest that you do not own the source disc!
Old 30th December 2021, 14:00   #31042  |  Link
jdobbs
Originally Posted by Acerjen View Post
Thank you, jdobbs. Great program. I was curious if there was a way to detect and copy the HDR metadata from a UHD source using this program and NVENC? My attempt ended up not being HDR. The colorspace reads BT.709 rather than BT.2020 in Mediainfo. Thanks. Later.
Acerjen
Yes. It can be done fairly easily. I just hadn't added that capability yet. I created the program for some specific jobs I was running (reencoding series episodes to load onto my media server), none of which was HDR, so I didn't worry much about colorspace.
Website: www.jdobbs.net
Old 30th December 2021, 14:23   #31043  |  Link
jdobbs
Originally Posted by DrinkLyeAndDie View Post
For the rest of us (who are playing with a full deck of cards):
I threw together a program that uses an interface that is very similar to BD-RB that I use for reencoding groups of files using NVENCC. I call it NVENCCRE (very original, eh?). I just thought that some of the folks that use one of the NVIDIA cards with built in encoders might find it useful. You just extract the EXE file and put it in the same folder as BDRB (it accesses the tools folder of BD-RB to call NVENCC and MEDIAINFO).
Nothing complicated, I just wrote it to make some things I was doing easier. Hope you find it useful...
Thank you, jdobbs. This is extremely useful!
Thanks. By the way, there are some options you can put in the NVENCCRE.INI file (that is created in the installation folder) that can customize some of the defaults I put on the dropdown menus.
HEVC_Q_VALUES=nn,nn,nn
AVC_Q_VALUES=nn,nn,nn
These change what you want as the CQM values that show on the menu. Legal values are 1-51. The three values decide what values to use for GOOD, HIGH, and HIGHEST settings. The default setting, for example for HEVC_Q_VALUES is:
HEVC_Q_VALUES=32,30,25
Settings for bitrates:
HEVC_BR_VALUES=nnnn,nnnn,nnnn
AVC_BR_VALUES=nnnn,nnnn,nnnn
The numbers represent Kbps and are used in the program to fill in the options for bitrates for GOOD, HIGH, and HIGHEST bitrates. For example, the default for HEVC_BR_VALUES is:
HEVC_BR_VALUES=1000,2000,3000
I also added the ability to change the audio bitrates used for GOOD, HIGH, and HIGHEST settings (ACC and AC3):
AC3_BR_VALUES=nnn/nnn,nnn/nnn,nnn/nnn
AAC_BR_VALUES=nnn/nnn,nnn/nnn,nnn/nnn
The commas separate the values for each of the GOOD, HIGH, and HIGHEST settings. The slashes separate the bitrate (in Kbps) used for STEREO/MULTICHANNEL. Below, as an example, is the default setting for AC3:
AC3_BR_VALUES=128/384,192/448,224/640
Please note that the audio bitrate values used have to be legal for AC3. Here's a list of legal values (all in Kbps):
32,40,48,56,64,80,96,112,128,160,192,224,256,320,384,448,512,576,640
Any mistakes made in any of these entries will result in the default values being used.
Old 30th December 2021, 14:42   #31044  |  Link
jdobbs
@MrVideo
I just want to point out that, by deciding to output and then import, you are creating your own issues. BD-RB will keep and use untouched TrueHD and EAC3 perfectly, but only if it comes directly from a BD. That's because that's pretty much the only place where a core is needed, provided, and kept. Deciding to export and then import is a self inflicted injury. As pointed out, other containers don't typically support audio streams that have a "core" -- and a core is required for TrueHD and EAC3 when it is used in a BD.
When importing, all container types that are not MKV are converted to MKV before importing. There are many very good reasons for this which I don't have time to (or care to) explain. MKV (like many container formats) does not support a "core" audio component in a stream.
Old 30th December 2021, 14:51   #31045  |  Link
MrVideo
MrVideo's Avatar
How could you possibly come to that conclusion? No studio is perfect. There have been several occasions whereby replacement discs have been sent out. Replacing a disc because of chapter marks, IMHO, is just not worth it.
Old 30th December 2021, 15:29   #31046  |  Link
MrVideo
MrVideo's Avatar
@jdobbs
I've sure learned a few things over these past few days. I did not know that you re-wrapped all imported files to MKV, which explains the issue with TrueHD. I have no idea why the spec that MKV uses doesn't allow for TrueHD to be left intact.
I'm not sure why you lump M2TS files into the "must recode" bucket, considering that M2TS obviously handles TrueHD just fine. I do not know how anyone could make a M2TS file with a coreless TrueHD stream. Certainly not with tsMuxer, as it throws away coreless TrueHD streams.
What I did with these couple of discs is probably going to be a one-off thing. It is something for the home theater I'm putting together. And more-then-likely, it will have been a project that I actually did not need to do. I won't know that for sure until I get all of the pieces assembled.
Limitations are now known.
Old 30th December 2021, 16:26   #31047  |  Link
jdobbs
Actually the "fault" belongs to the BD spec. It's the only place (I know of) where a core is needed. That's because support for TrueHD, EAC3, and several other audio codecs are allowed on a BD -- but the spec doesn't require a player to support them. So a "core" has to be included in the audio stream that consists of one of the codecs for which support is required. TrueHD doesn't normally have a core. So it is completely supported by an MKV -- only as a single stream (as it is generally meant to be). All a BD does is wrap another stream (for which support is required) in with it during muxing so a player can use that stream when it doesn't include TrueHD capability.
Old 30th December 2021, 17:36   #31048  |  Link
jdobbs
Acerjen
I went in and looked at it -- and, frankly, it was even easier than I thought. NVENCC does all the work if you pass it the appropriate command line parameters. I just recompiled NVENCCRE.exe and here is a version that supports reencoding with the HDR characteristics.
I didn't add support for HDR10+ until I test it a little. I'm trying to decide whether NVENCC's experimental setting is stable enough to add it.
Old 30th December 2021, 22:51   #31049  |  Link
MrVideo
MrVideo's Avatar
Now I'm little more confused. If I look at a disc with TrueHD, I don't see another audio stream that is AC3 5.1. Sure, there are streams for other languages, or even descriptive/commentary audio. What I do see is the THD track listed as having a core. AIUI, it is the core that is seen if it doesn't know how to deal with the TrueHD part of the stream.
I do not know what the requirements are for UHD releases, as the specs aren't out there for the general public. A UHD Demystified book hasn't been released yet.
Old 30th December 2021, 23:22   #31050  |  Link
gonca
MrVideo
DTS+some more data= DTS-HD
THD interleaved with AC3 core= compliant BD stream (2 streams in one)
PS
Quite easy to replace single track in m2ts and have it work if you read my description
I do it with subtitles on occasion.
gonca is offline   Reply With Quote
Old 30th December 2021, 23:25   #31051  |  Link
jdobbs
If you selected that TrueHD from the BD menu -- and your player didn't support it, you would hear the (core) AC-3 track (and not even know it). That's why they are muxed together (and even share a stream ID). There are probably people out there that think they are listening to TrueHD without knowing that their player doesn't even support it.
Old 30th December 2021, 23:30   #31052  |  Link
MrVideo
MrVideo's Avatar
As pointed out in some postings, I had issue try to do that. I even managed to lock up my BD player.
Old 30th December 2021, 23:36   #31053  |  Link
MrVideo
MrVideo's Avatar
If you selected that TrueHD from the BD menu -- and your player didn't support it, you would hear the (core) AC-3 track (and not even know it). There are probably people out there that think they are listening to TrueHD without knowing that their player doesn't even support it.
That was my understanding.
What is interesting is that in order to get the lossless audio to work, one must use the HDMI connection to your AVR. The coax/optical connection is not allowed to carry the higher bitrate lossless audio. But, those that have an AVR that handles all of the audio formats, just sets the player to output the raw stream to the AVR and let it handle the decoding.
That said, if you get a UHD player, I don't know of any model that doesn't support all of the audio formats. If you have a UHD player, odds are you have a better AVR as well.
Old 30th December 2021, 23:44   #31054  |  Link
gonca
Start with a BD compliant structure
Load the m2ts into tsMuxeR
Uncheck existing sound and add yours
Check M2TS muxing
Start muxing
Make sure new m2ts has same name as old
Replace m2ts in original BD structure
Open structure in BDEdit
Select proper play list
Change audio properties (type language etc)
Save
Click on Apply to clpi
Go to CLPIINF tab
Make sure info looks right
Save
If it asks you if you want it to correct packets ( or anything) select yes and Save
Import this into BDRB
Note
New audio has to be Bd (UHD) compliant
Old 31st December 2021, 04:14   #31055  |  Link
MrVideo
MrVideo's Avatar
Check M2TS muxing
Start muxing
Save
Go to CLPIINF tab
Save
Note
Yep, that is what I have done and it has not always worked. Reason unknown.
Old 31st December 2021, 16:37   #31056  |  Link
jdobbs
I don't think I would agree with that. If the box doesn't explicitly say the player supports a specific codec -- it probably doesn't. But, the odds are probably higher you'll get more codecs with a UHD player than with a non-UHD player.
Old 1st January 2022, 10:17   #31057  |  Link
MrVideo
MrVideo's Avatar
Of the recent BD players that I have, all Samsung, they all handle all of the lossless formats. But as I noted, even if any of them didn't, the AVR does and I've set all of the players to send the raw streams out the HDMI and let the AVR handle it. IMHO, it is best to let the AVR handle the audio.
As always, YMMV.
Old 2nd January 2022, 04:21   #31058  |  Link
Acerjen
Thanks for adding HDR support to this. I have tested three movies and all came out great. Your efforts are much appreciated.
Acerjen
Acerjen is offline   Reply With Quote
Old 2nd January 2022, 07:19   #31059  |  Link
DrinkLyeAndDie
DrinkLyeAndDie's Avatar
Thanks. By the way, there are some options you can put in the NVENCCRE.INI file (that is created in the installation folder) that can customize some of the defaults I put on the dropdown menus...
Nice. Good to know.
Possibly considered superfluous by some but any chance of adding a beep at job completion option to NVENCCRe? It would be useful for long jobs involving many files that take a bit of time.
DrinkLyeAndDie is offline   Reply With Quote
Old 2nd January 2022, 14:02   #31060  |  Link
jdobbs
Nice. Good to know.
Sure. No problem.
[Edit] I added the beep. You can get the new EXE from this link. It works just like BD-RB. To enable the beep on completion just add the following to you NVENCCRE.INI file:
COMPLETION_BEEP=1
It will play the contents of Ding.wav in the MISC folder under BD-RB's folder. If that doesn't exist it will play the default "Beep" for your system. The sound will only play if a job is completed (all files), and it will not play if you abort a job.
