Old 15th October 2020, 17:59   #30081  |  Link
LowDead
Elit Amans
Originally Posted by Emulgator View Post
LowDead, can you cut a part of the source and upload that somewhere ?
How much of the source file is needed?
//LD
LowDead is offline   Reply With Quote
Old 15th October 2020, 18:08   #30082  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
DGSplit, or hSplit offending part, short of 2 GB, upload to wetransfer (they accept 2GB for free, 1 week)
Old 15th October 2020, 19:03   #30083  |  Link
LowDead
Elit Amans
That will be the whole file then ^^
//LD
Old 15th October 2020, 23:25   #30084  |  Link
Emulgator
Emulgator's Avatar
Good, bring it, rate control won't be off then.
Old 16th October 2020, 04:38   #30085  |  Link
zamengo
There is a way to change subtitle from eng to another language?
Let me explain:
I make a disc from mkv import with .srt on same folder, but this sub is Portuguese.
BD Rebuilder automatically set this to "eng" sub.
I Found a hidden option but I don't know how this works:
FORCED_SUB_LANG=s s = 3 letter preferred language codes -- default is "eng", can be multiples (e.g. "ger;deu")
I need to use: FORCED_SUB_LANG="por" or this not the options I want?
zamengo is offline   Reply With Quote
Old 16th October 2020, 12:35   #30086  |  Link
Sharc
Originally Posted by LowDead View Post
Here it comes
LINK REMOVED BY MODERATOR
//LD
I did 3 tests:
a) encoding with NVEncC using commandline, --vbr-quality 24 => no problems
b) importing your file into BD-RB and encoding with NVEnc, Alternate Movie only output to .mkv container, CQM=24 => no problems, bitrate was 4005kbps only.
c) same as b) but outputting to AVCHD structure which involves tsmuxer => no problem
The only thing which I noticed was that BD-RB converted the 24 fps source to 23.976 fps, with audio adjusted accordingly.
I watched on PC and on TV, all ok.
All were 1-pass encodes, I could not test your size-correcting 2nd pass for this file.
I am also wondering why you see the pixelation on your TV only, but not on your PC.
Old 16th October 2020, 14:36   #30087  |  Link
jdobbs
@LowDead
I removed your post with the link in it. It is against forum rules to share a link to a file that may be copyrighted.
Website: www.jdobbs.net
Old 16th October 2020, 14:38   #30088  |  Link
jdobbs
Let me explain:
Then add this line to your REBUILDER.INI file:
FORCED_SUB_LANG=por
Also go to the SETTINGS dialog and make sure you have that subtitle language (Portuguese) selected to keep.
Old 16th October 2020, 16:56   #30089  |  Link
FilipeAmadeuO
Originally Posted by FilipeAmadeuO View Post
@jdobbs
Any chance to add a replace subtitle/audio function ?
Most of the original UHD nowadays don’t have Portuguese language so I buy other version and like to add Portuguese.
I can do it with BDRebuilder but I need to do it in multiple steps and it takes a very long time.
Hi jdobbs
Sorry for re-asking
There is no LOTR 4K with portuguese subtitles so i am preparing myself
FilipeAmadeuO is offline   Reply With Quote
Old 16th October 2020, 19:09   #30090  |  Link
LowDead
Elit Amans
@LowDead
No, problem. Sorry about that. Didn't think longer than my nose as it was requested to be uploaded for investigation purposes.
Sharc did get to download it before it was removed and did some test which came out ok. So why is BD-RB with NVEnc encoder allergic with my setup? *pulls the last of my hair*
//LD
Old 16th October 2020, 20:34   #30091  |  Link
MrVideo
MrVideo's Avatar
I'm curious as to why BDRB would do that.
Old 16th October 2020, 22:21   #30092  |  Link
zamengo
FORCED_SUB_LANG=por
Don't work, the english flag still ou sub:
Old 17th October 2020, 03:10   #30093  |  Link
Alleycat
Hi all, I've noticed a problem since the new TsMuxer was enabled by default in the latest build of BDRB. Using full backup mode, it's previously it's been possible to play a single m2ts file in a media player on a PC and select the preferred audio track from the right click menu. However when doing a rebuild with the new TsMuxer enabled, one or more of the audio tracks are either missing from the context menu or play intermittently. If I do another build using the hidden option "ENABLE_NEW_TSMUXER=0" all audio tracks are again available and play perfectly. Even more bizarrely, with TsMuxer 2.6.16 all audio tracks do work if selected from the BD Menu in J.River or PowerDVD, but the very same players will have some audio tracks missing when playing the .m2ts file directly. Hope this makes sense. Basically it looks like TsMuxer 2.6.16 is somehow breaking compatibility with LAV splitter etc
Alleycat is offline   Reply With Quote
Old 17th October 2020, 11:55   #30094  |  Link
Sharc
//LD
You could try a pure 1-pass CQM encode using a fix quality value rather than the CQM/CRF prediction algo. Of course you can't fix the target filesize then, but it would give an indication whether your pixelation comes from the prediction/correction mode.
Old 17th October 2020, 13:49   #30095  |  Link
cartman0208
I can confirm that ... first I thought my PC config was broken, because on the Bluray Player were no issues.
But it seems, I'm not alone...
When playing the m2ts files in VLC player, the audio is distorted and choppy or completely missing
cartman0208 is offline   Reply With Quote
Old 17th October 2020, 15:25   #30096  |  Link
jdobbs
Does it have a forced Portuguese subtitle? It only works to select from the list of subs that actually contain forced subs within them.
If you want a set of subtitle to be turned on by default (as opposed to selecting from forced subs) you can right click on a sub in the streams list and set it to default on.
Old 17th October 2020, 16:18   #30097  |  Link
jdobbs
Try replacing the version of TSMUXER (tsmuxer4k.exe) with a newer one from this link. Make sure you use the 32 bit version ( w32-nightly...), as the 64 bit version will cause errors when used with AVISYNTH. The one listed is a couple weeks newer than the one included in BD-RB.
I will say, though, that what you are describing sounds more like a player issue. Does the stream play correctly when using a hardware BD player? The fact that PowerDVD sees them correctly makes me think they are alright. But I'll look and see if I can find anything odd.
Old 17th October 2020, 23:23   #30098  |  Link
LowDead
Elit Amans
THAAAAAANKS!!!! This worked. So why does the prediction/correction cause this? But wait, I also got the error when doing VBR. One thing I noticed was that my test extras clip had a bitrate of ~7000kbit instead of ~4000 kbit.
btw, I had to blank main movie and force encode on the rest of the files to even get onto a disc..
Have a few more tests to do..
Settings:
[Options]
VERSION=0.61.0.17
BD5_SIZE=4610
BD9_SIZE=8250
BD25_SIZE=24400
*BD50_SIZE=50190
CUSTOM_TARGET_SIZE=49350
AUDIO_TO_KEEP=all
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=1
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=0
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=3
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=1
IVTC_PULLDOWN=1
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
AUTO_BIAS=3
B_PYRAMID=1
DGDECIM_SW_DECODE=0
ENCODER_MENU=1
FRIM_SW_DECODE=0
FRIM_SW_ENCODE=0
HC_PROFILE=BEST
IMPORT_HEVC_INTACT=1
KEEP_MBTREE=1
PASS_TWO_STATS_UPDATE=1
SHOW_ENCODER=1
DTSX_ENABLE=1
ENABLE_TEST=1
ENABLE_BLANKING=1
DEFAULT_LANG=eng
TARGET_SIZE=24400
MIN_M2TS_SIZE=0
MIN_PLAYLIST_MINS=0
MENU_AUDIO=C:\vidsoft\BD_Rebuilder\tools\blankclip\blank.ac3
IMPORT_THRESHOLD=15
QUICK_PLAY_THRESHOLD=10
MENU_AUTO_BACKGROUND=1
MENU_AUTO_DVDAUDIO=1
MENU_PLAY_SEQUENTIAL=0
MENU_START_WITH_MENU=1
IMPORT_LIMIT_LANG=0
IMPORT_KEEP_PLAYALL=0
IMPORT_PREPARE_MKV=1
NVENC_CAPABLE=1
ENCODE_QUALITY=0
AUTO_QUALITY=0
ONEPASS_ENCODING=1
FIXED_CRF=20
FORCE_ENCODE=1
ENCODER=1
MODE=0
[Paths]
DGIndexNV=C:\vidsoft\DGDecNV\DGIndexNV.exe
DGDecNV=C:\vidsoft\DGDecNV\DGDecodeNV.dll
WORKING_PATH=E:\WORK\FIXEDCRF\
SOURCE_PATH=L:\UHDBD\FLASH_GORDON_-_4K_UHD
[10-17-20] BD Rebuilder v0.61.17
[21:10:53] Source:  FLASH_GORDON_-_4K_UHD
  - Input BD size: 5,86 GB
  - Approximate total content: [02:40:38.926]
  - Target BD size: 23,83 GB
  - Windows Version: 6.2 [9200]
  - Quality: Very Good (Very Fast), CQM
  - Decoding/Frame serving: NVENCC
[21:10:57] PHASE ONE, Encoding
 - [21:10:57] Processing: VID_00002 (1 of 13)
 - [21:10:57] Extracting A/V streams [VID_00002]
 - [21:11:10] Reencoding video [VID_00002]
   - Source Video: HEVC, 3840x2160
   - Rate/Length: 24,000fps, 481 frames
 - [21:11:10] Encoding using constant quality mode.
 - [21:11:16] Video Encode complete
 - [21:11:16] Processing audio tracks
 - [21:11:16] Multiplexing M2TS
 - [21:11:20] Processing: VID_00003 (2 of 13)
 - [21:11:20] Extracting A/V streams [VID_00003]
 - [21:11:24] Reencoding video [VID_00003]
   - Rate/Length: 24,000fps, 289 frames
 - [21:11:24] Encoding using constant quality mode.
 - [21:11:28] Video Encode complete
 - [21:11:28] Processing audio tracks
 - [21:11:28] Multiplexing M2TS
 - [21:11:32] Processing: VID_00004 (3 of 13)
 - [21:11:32] Extracting A/V streams [VID_00004]
 - [21:11:35] Reencoding video [VID_00004]
   - Rate/Length: 24,000fps, 157 frames
   - Bitrate: 20 239 Kbs
 - [21:11:35] Reencoding: VID_00004, Pass 1 of 2
 - [21:11:39] Reencoding: VID_00004, Pass 2 of 2
 - [21:11:39] Video Encode complete
 - [21:11:39] Processing audio tracks
 - [21:11:39] Multiplexing M2TS
 - [21:11:42] Processing: VID_00005 (4 of 13)
 - [21:11:42] Extracting A/V streams [VID_00005]
 - [21:11:46] Reencoding video [VID_00005]
   - Rate/Length: 24,000fps, 121 frames
   - Bitrate: 21 171 Kbs
 - [21:11:46] Reencoding: VID_00005, Pass 1 of 2
 - [21:11:48] Reencoding: VID_00005, Pass 2 of 2
 - [21:11:48] Video Encode complete
 - [21:11:48] Processing audio tracks
 - [21:11:48] Multiplexing M2TS
 - [21:12:01] Processing: VID_00006 (5 of 13)
 - [21:12:01] Extracting A/V streams [VID_00006]
 - [21:12:05] Reencoding video [VID_00006]
   - Rate/Length: 24,000fps, 120 frames
   - Bitrate: 2 771 Kbs
 - [21:12:05] Reencoding: VID_00006, Pass 1 of 2
 - [21:12:08] Reencoding: VID_00006, Pass 2 of 2
 - [21:12:08] Video Encode complete
 - [21:12:08] Processing audio tracks
 - [21:12:08] Multiplexing M2TS
 - [21:12:11] Processing: VID_00007 (6 of 13)
 - [21:12:11] Extracting A/V streams [VID_00007]
 - [21:12:15] Reencoding video [VID_00007]
   - Rate/Length: 24,000fps, 192 frames
   - Bitrate: 18 057 Kbs
 - [21:12:15] Reencoding: VID_00007, Pass 1 of 2
 - [21:12:18] Reencoding: VID_00007, Pass 2 of 2
 - [21:12:18] Video Encode complete
 - [21:12:18] Processing audio tracks
 - [21:12:18] Multiplexing M2TS
 - [21:12:22] Processing: VID_00008 (7 of 13)
 - [21:12:22] Extracting A/V streams [VID_00008]
 - [21:12:26] Reencoding video [VID_00008]
   - Bitrate: 5 260 Kbs
 - [21:12:26] Reencoding: VID_00008, Pass 1 of 2
 - [21:12:30] Reencoding: VID_00008, Pass 2 of 2
 - [21:12:30] Video Encode complete
 - [21:12:30] Processing audio tracks
 - [21:12:30] Multiplexing M2TS
 - [21:12:33] Processing: VID_00009 (8 of 13)
 - [21:12:33] Extracting A/V streams [VID_00009]
 - [21:12:37] Reencoding video [VID_00009]
   - Rate/Length: 24,000fps, 261 frames
 - [21:12:37] Encoding using constant quality mode.
 - [21:12:41] Video Encode complete
 - [21:12:41] Processing audio tracks
 - [21:12:41] Multiplexing M2TS
 - [21:12:45] Processing: VID_00010 (9 of 13)
 - [21:12:45] Extracting A/V streams [VID_00010]
 - [21:12:48] Reencoding video [VID_00010]
   - Rate/Length: 23,976fps, 240 frames
 - [21:12:48] Encoding using constant quality mode.
 - [21:12:52] Video Encode complete
 - [21:12:52] Processing audio tracks
 - [21:12:52] Multiplexing M2TS
 - [21:12:56] Processing: VID_00011 (10 of 13)
 - [21:12:56] Extracting A/V streams [VID_00011]
 - [21:12:59] Reencoding video [VID_00011]
   - Rate/Length: 24,000fps, 168 frames
   - Bitrate: 16 531 Kbs
 - [21:12:59] Reencoding: VID_00011, Pass 1 of 2
 - [21:13:02] Reencoding: VID_00011, Pass 2 of 2
 - [21:13:02] Video Encode complete
 - [21:13:02] Processing audio tracks
 - [21:13:02] Multiplexing M2TS
 - [21:13:06] Blanking: VID_01000 (11 of 13)
 - [21:13:06] Processing: VID_02000 (12 of 13)
 - [21:13:06] Extracting A/V streams [VID_02000]
 - [21:14:06] Reencoding video [VID_02000]
   - Rate/Length: 24,000fps, 40 089 frames
 - [21:14:06] Encoding using constant quality mode.
 - [21:15:28] Video Encode complete
 - [21:15:28] Processing audio tracks
 - [21:15:28] Multiplexing M2TS
 - [21:15:47] Processing: VID_02001 (13 of 13)
 - [21:15:47] Extracting A/V streams [VID_02001]
 - [21:17:11] Reencoding video [VID_02001]
   - Rate/Length: 24,000fps, 20 814 frames
 - [21:17:11] Encoding using constant quality mode.
 - [21:18:31] Video Encode complete
 - [21:18:31] Processing audio tracks
 - [21:18:31] Multiplexing M2TS
[21:19:04]PHASE ONE complete
[21:19:04]PHASE TWO - Rebuild Started
 - [21:19:04] Rebuilding BD file Structure
[23:15:47] - Encode and Rebuild complete
[23:15:47] JOB: FLASH_GORDON_-_4K_UHD finished.
[Status]
LABEL=FLASH_GORDON_-_4K_UHD
VERSION=v0.61.17
SOURCE_SIZE=6296154371
SOURCE_VIDEO_SIZE=4179603456
TARGET_SIZE=25585254400
REDUCTION=5.61505504817919
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=all
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=-1
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
UHD_V3_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=13
REBUILD_COMPLETE=1
[00002]
AUDIO=1
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=1207806427
NSTART=27000000
NEND=27901875
NSIZE=107231232
FLINK=0
MLINK=0
[00003]
AUDIO=
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=9694190
NSTART=27000000
NEND=27541875
NSIZE=2267136
FLINK=0
MLINK=0
[00004]
AUDIO=
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=17801431
RATE=20239
NSTART=27000000
NEND=27294375
NSIZE=3741696
FLINK=0
MLINK=0
[00005]
AUDIO=
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=14351542
RATE=21171
NSTART=27000000
NEND=27226875
NSIZE=3741696
FLINK=0
MLINK=0
[00006]
AUDIO=
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=1862941
RATE=2771
NSTART=27000000
NEND=27225000
NSIZE=540672
FLINK=0
MLINK=0
[00007]
AUDIO=
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=19422880
RATE=18057
NSTART=27000000
NEND=27360000
NSIZE=2506752
FLINK=0
MLINK=0
[00008]
AUDIO=
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=5657819
RATE=5260
NSTART=27000000
NEND=27360000
NSIZE=2463744
FLINK=0
MLINK=0
[00009]
AUDIO=
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=9970182
NSTART=27000000
NEND=27489375
NSIZE=3213312
FLINK=0
MLINK=0
[00010]
AUDIO=
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=26495154
NSTART=27000000
NEND=27450450
NSIZE=4227072
FLINK=0
MLINK=0
[00011]
AUDIO=
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=15559003
RATE=16531
NSTART=27000000
NEND=27315000
NSIZE=2611200
FLINK=0
MLINK=0
[02000]
AUDIO=1
PGS=111
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=9156559569
NSTART=27000000
NEND=102166875
NSIZE=1557891072
FLINK=0
MLINK=0
[02001]
AUDIO=1
PGS=111
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=12983522348
NSTART=27000000
NEND=66026250
NSIZE=1216567296
FLINK=0
MLINK=0
"C:\vidsoft\BD_Rebuilder\tools\nvenc\nvencc.exe" --avhw  -i "L:\UHDBD\FLASH_GORDON_-_4K_UHD\BDMV\STREAM\02001.m2ts" --codec h264 --preset performance --bluray --qp-min 0 --multipass 2pass-full --vbr 0 --vbr-quality 20 --aq-temporal --keyfile "E:\WORK\FIXEDCRF\WORKFILES\VID_02001.CHP" --sar 1:1 --aud --pic-struct --vbv-bufsize 30000 --max-bitrate 35000 --gop-len 24 -o "E:\WORK\FIXEDCRF\WORKFILES\VID_02001.AVS.264"
//LD
Old 18th October 2020, 00:18   #30099  |  Link
Alleycat
Thanks for replying. I tried your link above but it only has TsMuxer not TsMuxer4k?
Old 18th October 2020, 00:26   #30100  |  Link
jdobbs
You have to rename it to "tsmuxer4k.exe" and then copy it to the BD-RB TOOLS folder. I gave it that name to distinguish it from the older version of TSMUXER (v2.6.12) which is still present in the TOOLS folder.
