Old 22nd July 2008, 12:05   #1  |  Link
nx6
Playing with MKV files...
nx6's Avatar
Brightness/Letterboxing on Zoomplayer
This should be an easy one for home theater buffs.
I'm watching a 16:9 show on ZoomPlayer, and I'm getting slight letterboxing on my widescreen display (as I should, it's a 16:10 LCD panel after all).
My problem is the letterboxing isn't the darkest thing on the screen.
I can see areas of the show are actually shades of black darker than the letterbox frame ZoomPlayer adds in fullscreen mode. I know this isn't a contrast trick of the eyes, because when these dark areas are up against the edges of the picture I can see the letterbox frame stand out slightly from it. I've tried setting the aspect ratio for the video to 4:3 so I could rule out blacklight leak on the display, and the bars are still visible even though they are now a couple inches into the screen on the sides instead of top and bottom.
Is this a sign my brightness is too high, or is it normal? I can lower the brightness on my video card settings slightly to get rid of it, but since I was able to see image area that was darker than the bar before, haven't I now lowered my shadow detail as well?
Intel Core i7 920, 6 GB RAM | GeForce GTX670 | Win8.1 | LAV 0.64 / MadVR 0.87.10 | Zoom Player v10 / MPC-HC 1.7.8
nx6 is offline   Reply With Quote
blacklevel, letterbox, zoomplayer
