Old 19th July 2008, 09:26   #1  |  Link
badmonkey
AC3 via Cyberlink Audio Decoder, will not work in ZoomPlayer
I am trying to get AC3 to be decoded by the Cyberlink Audio Decoder (cos I want Dolby Headphone) in ZoomPlayer.
I've tried both PowerDVD 7 and 8, and neither works.
If I use Cyberlink Audio Decoder as the sole filter for AC3, I get the error:
Pin Connection Warning (Not an Error):
[AVI Splitter].Stream 01  --->  [CyberLink Audio Decoder].Audio In
Code: There is no common media type between these pins. (80040207)
The above is exactly the configuration that I used to use on my old XP system, and it worked perfectly!
(New system is Vista x64).
If I try to use Gabest AVI<->AC3/DTS inline before Cyberlink, I get:
[AVI<->AC3/DTS].XForm Out  --->  [CyberLink Audio Decoder].Audio In
It does work just fine with DTS.
So, ummn, help?
badmonkey is offline   Reply With Quote
Old 19th July 2008, 15:53   #2  |  Link
backtohell
Me too having Same problem (using Vista X86 SP1)
tried variety of settings in zoom player as well as KMplayer but could not get the AC3 through Cyberlink Audio Decoder
Right now i am using Arcsoft Audio Decoder HD (i also use Open source AC3 Filter sometimes)
Both Gabest Audio Decoder/Dscaler Audio Decoder works for me in decoding AC3 audio
But no AC3 through Cyberlink Audio Decoder (have tried both 7 and 8 + also HP Quickplay decoders)
I guess it is something to do with the connecting Pins between the filters(i am a complete noob-don't know what i am saying)
backtohell is offline   Reply With Quote
Old 19th July 2008, 15:57   #3  |  Link
badmonkey
Yeah but it always worked fine on XP. Didn't need to use AVI<->AC3/DTS either, just the decoder on its own would be A-OK.
Only difference is slightly newer version of ZoomPlayer and Vista x64.
Couldn't care less about PowerDVD, just want Dolby HP...
Old 22nd July 2008, 23:42   #4  |  Link
tommy_vercetti
Hahahahahahahahaha, see my thread, the PowerDVD codecs are not available to any other applications in Windows Vista, I switched back to XP x64, I don't like using the AC3 filter, you can try that and your problem will be resolved
tommy_vercetti is offline   Reply With Quote
Old 23rd July 2008, 08:15   #5  |  Link
badmonkey
You can't use AC3Filter in conjunction with Cyberlink Audio Decoder, the best you can do is via FFDShow Audio, passing through 5.1 LPCM, which works but requires channel swapping mickey mouse BS which makes changing from head phones to speakers a real pain.
Your statement is not entirely correct in any case, the Cyberlink codecs appear to work fine with 3rd party apps in Vista
1) Cyberlink Audio Decoder works 100% okay with DTS, as I stated above
2) Cyberlink Audio Effects filter works fine with everything, but it's either crap with 2-channel input or you have the same problem involving FFDShow.
- It's only the combination of AC3 and Audio Decoder that fails for me.
Old 24th July 2008, 18:07   #6  |  Link
backtohell
Even Arcsoft Audio Decoder is working with 3rd Party Applications on AC3 Decoding on vista
but I guess there is no chance for AC3 decoding through Cyberlink Audio Decoder in Vista outside the PowerDVD
Old 26th July 2008, 06:54   #7  |  Link
tommy_vercetti
Seems you got the point, try Aud-X and see
Old 26th July 2008, 07:06   #8  |  Link
badmonkey
Set-up Aud-X in 5.1 mode -
[Aud-X Audio Decoder].Aud-X Output  --->  [CyberLink Audio Decoder].Audio In
Code: Unspecified error  (80004005)
On its own video playback is ruined also, very jerky.
Old 26th July 2008, 18:11   #9  |  Link
backtohell
thanks for the suggestion
but i am happy with both Arcsoft , and Dscaler audio decoder
Old 4th August 2008, 09:58   #10  |  Link
gurubhai
i have been using cyberlink audio decoder for ac3 in vista from version 7 , version 8 decoder only works for dts in vista
gurubhai is offline   Reply With Quote
Old 4th August 2008, 10:05   #11  |  Link
badmonkey
Hmmn I downgraded to ver 7 also, but it's made no difference for me.
Old 4th August 2008, 10:33   #12  |  Link
gurubhai
i am using it in kmplayer and it uses kmp avi - ac3/dts transform filter to connect to cyberlimk audio decoder
Old 4th August 2008, 10:42   #13  |  Link
gurubhai
[IMG][/IMG]
check this
Old 6th August 2008, 05:03   #14  |  Link
backtohell
Thanks Gurubhai
I tried your method of using internal AC3 decoder of KMPlayer with LPCM output through Cyberlink Audio Decoder
it works even on my PDVD8 version audio decoder
ac3, cyberlink, zoomplayer
