30th November 2012, 01:02 | #1 | Link |
Available HEVC/H.265 test encoders
My curiousity has gotten too high, and I want to make some HEVC / H.265 test clips. I'm well aware that there's not any production-caliber implementation yet, but I'd like to try the best of what I could get my hands on.
Anyone done any testing that can make any suggestions? There's always compiling the reference encoder, of course. |
30th November 2012, 14:29 | #2 | Link | |
もこたんインしたお!
I would probably say that the only working'ish implementation at this time is HM, the reference encoder/decoder package. The "x265" project (not really having that much in common with x264) doesn't look like something usable, and prunedtree's encoder was in its very beginnings (not to mention that he has been without internet for some time now because of moving from one continent to another).
Looking at the JCT-VC mailing list, the version of code available in the HM-9.0-dev branch is currently recommended (unlike its name, it is actually what is going to be version 9.1). Also from the mailing list, the currently known bugs in this version of HM are: Quote:
If anyone has done any extra testing, I'd be happy to hear about it as well.
[I'm human, no debug]
3rd December 2012, 23:03 | #4 | Link | |
Last summer I ran a test similar to the following:
This persuaded me that HEVC really had legs and was worth investing more time and money. -John
John @ Parabola Research Limited - HEVC conformance and technology http://www.parabolaresearch.com/ |
4th December 2012, 13:40 | #5 | Link | |
もこたんインしたお!
HM 9.1 has been released.
After first trying to set settings manually, and being greeted by weird errors ("-f Number of frames to be encoded (default=all)", yet it has to be set) and/or division by zero errors due to my settings (minCuSize ending up as zero and so forth), I just ended up trying with the pre-made encoder_intra_main.cfg configuration file as the base, and actually got it to encode. Code:
TAppEncoder.exe -c /cygwin/projects/jctvc-hm/cfg/encoder_intra_main.cfg -i zeroma.yuv -fr 24 -wdt 320 -hgt 180 -f 2155 --CroppingMode 1 (it does warning out with "Unhandled argument ignored: `1'" at the end, but otherwise seems to work -- although CroppingMode 1 seems to have been parsed just fine) Edit: Seems like smarter's libavcodec WIP decoder only supported stuff up until HM 8.2, so that was completely a no-go. That said, a French team of students he has been in contact with seem to have made it at least somewhat HM 9.0 compatible, with work being made to make it more capable overall. This version seems to actually be able to decode some of the intra frames in my stream correctly. This is quite nice, even at such an early stage
4th December 2012, 19:51 | #6 | Link |
Yea!
Is there anywhere to get a binary for Windows (32 or 64-bit) for the Visual Studio impaired? I spent two years as a maintainence engineer on banking software, and the experience was so scarring I've not been able to write a line of code since 1995 ... |
4th December 2012, 20:46 | #7 | Link | |
もこたんインしたお!
This way you can basically watch out for possible miscompilations, as well as have the debug symbols useful enough in case anything crashing happens Not like HM is supposed to be fast, anyways (5h+ on my C2D Penryn for 2155 frames' worth of 320x180).
4th December 2012, 21:11 | #9 | Link |
Vanguard announced a realtime 1080p HEVC encoder at IBC that sounds quite promising.
Given the improved tools, I think HEVC should be able to provide better quality at the same encoding time as H.264. A fully-tuned encode might be slower in HEVC, however, as there are more different ways to do things. Also, the decoder is somewhat slower, and that'd be part of the refinement loop in a high-quality encoder. So, I'd think that quality @ time will be substantially better in HEVC. But a placebo mode would likely be slower than in H.264. Of course, implementations and tuning make a HUGE different here. I'm sure there will be some HEVC encoders that'll be worse than some H.264 encoders for particular scenarios. |
5th December 2012, 11:52 | #10 | Link | |
5th December 2012, 12:27 | #11 | Link | |
もこたんインしたお!
In other words, it's not really bad -- and if I recall correctly the configuration for HM should not depend on the shared debug CRT (I did check with dependency walker but I might have missed something). Of course, if someone actually asked for a release build, I was naturally ready to build one as well. I guess I'll compile one and up to fushizen when I get to a workstation with Windows (or home). Edit: Added release builds into my previous post as they were indeed requested
9th December 2012, 11:32 | #12 | Link |
I think HEVC looks promising, here my little test on foreman_cif.yuv clip
- HM9.1 (build commit a0da0c21f34b05bda60e406f991a76b599876a68 ): TAppEncoder.exe -c encoder_randomaccess_main.cfg -q 26 -fr 30 -wdt 352 -hgt 288 -f 300 -i foreman_cif.yuv -b hevc.bin hevc.bin : 369 ko - X264 (2216) X264 --tune psnr --crf 26.7 --preset placebo X264.mkv : 370 ko psnr with MSU Video Quality Measurement Tool : HEVC : AVG: 37.57242 X264 : AVG: 36.87016 Not bad for HEVC but not 50% better and X264 encode need ~10 sec and HM9.1 746 sec |
12th December 2012, 14:19 | #14 | Link |
0.8db PSNR is actually a huge difference (ignoring the fact that it might not be a suitable metric for comparing two different formats). Note that HM isn't a top-notch sophisticated encoder like x264 (not to mention placebo setting). Lots of people would actually expect x264 to win here, given that - despite the h.264 format itself being inferior.
12th December 2012, 16:25 | #16 | Link |
Testeur de codecs
Well it's better to compare with x264 ... simply because x264 is best H264 implementation in the area actually for PSNR. Sound promising for HEVC ... ;-)
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 |
12th December 2012, 19:28 | #17 | Link |
And I'd expect HEVC's advantages to improve as frame size goes up. Those big transforms are doing to do a lot more for 1080p and beyond than for 352x288, which is what H.264 Baseline and Main were originally tuned for.
It would be great if someone has the time to try one of those 2160p test sequences . That'd be a LOOONG encode. |
13th December 2012, 10:37 | #18 | Link | |
The Next Generation Internet Video Codec project.[/url]. |
13th December 2012, 20:33 | #19 | Link | |
Testeur de codecs
14th December 2012, 11:53 | #20 | Link | |
hevc. h.265 |
