Old 30th May 2022, 21:08   #1521  |  Link
kedautinh12
Originally Posted by takla View Post
Just use ffmpegs built-in nlmeans_opencl like this
ffmpeg -y -init_hw_device opencl=ocl -filter_hw_device ocl -i INPUT.avs -c:v prores_ks -filter_complex "format=yuv420p, hwupload, nlmeans_opencl, hwdownload, format=yuv420p" OUTPUT.mkv
Here are the available parameters
Use them like this
nlmeans_opencl=s=1.0:p=7:r=15
Note1: r=15 might be too slow. Use lower values.
Note2: p=7 might be too lossy. Use higher values.
Note3: Anything but 8bit is not supported
Note4: If you have a nvidia GPU or a good CPU, use BM3D
Note5: Or use MVtools
Both are much better then nlmeans.
Some people say KNLMeansCL still better than BM3D in here
Old 30th May 2022, 21:29   #1522  |  Link
takla
I did exactly one test with nlmeans_opencl which was not only MUCH slower then BM3D or MDegrain but also had MUCH worse quality. I tried multiple different parameters to no avail. That is already bad enough for me to never consider it as an option ever again.
takla is offline   Reply With Quote
Old 31st May 2022, 04:51   #1523  |  Link
TDS
Formally known as .......
TDS's Avatar
Well, I have to say I did a BM3D (CUDA) encode the other day, and it was NOT good, so that's off my usage list, from now on.
Having said that, BM3D (CPU) is OK
Yet to do a proper KNLMeansCL comparison.
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is offline   Reply With Quote
Old 17th June 2023, 22:18   #1524  |  Link
Lan4
When this filter is running, my video card starts to squeak. The sound is like a grasshopper. The filter is working fine. Can this be fixed without repairing the video card?
Lan4 is offline   Reply With Quote
Old 17th June 2023, 23:34   #1525  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
That sqeaking just tells about the load.
If the video card is designed in a way that current draw can lead to magnetostriction
(inductivities can exhibit that), any serious load will trigger similar behaviour, not just KNLMeansCL.
Old 18th June 2023, 03:23   #1526  |  Link
Lan4
I compared the work of KNLMeansCL and FFT3DGPU in GPU-Z. Is the "GPU Load" value important? The load is 100% when KNLMeansCL is running. In other values, the difference is small.
Old 18th June 2023, 04:27   #1527  |  Link
kedautinh12
For me, KNLMeansCL better than FFT3DGPU, FFT3DGPU ported base old ver of FFT3DFilter so it's even worst than FFT3DFilter
Old 25th June 2023, 04:12   #1528  |  Link
Lan4
Perhaps I have a strange question. How to reduce load and speed of KNLMeansCL? I don't need the maximum speed of the filter, KNLMeansCL is already fast enough. I want to try to reduce the temperature of the video card, the noise of the fans and remove the squeak.
Old 25th June 2023, 04:33   #1529  |  Link
poisondeathray
Look at various GPU over/underclocking utilities. They can change the core / memory speeds, voltage.
Old 25th June 2023, 10:48   #1530  |  Link
FFT3DGPU uses less precision than CPU version FFT3DFilter,
it was always of lesser quality.
Old 25th June 2023, 14:58   #1531  |  Link
Lan4
I already thought about reducing the power of the video card. But is it possible to reduce the power of the filter itself?
Old 4th July 2023, 01:27   #1532  |  Link
OAKside
Cat
OAKside's Avatar
KNLMeansCL does make my graphics card (6600 XT) produce a specific noise, not heard at other times (games, HW encoding, etc). The sound is like a constant white noise (low decibel, barely heard, similar to coil whine). I assumed it was due to the particular or heavy processing that is going on, like Emulgator has explained. It is my least favorite part about KNLMeansCL (haha, I just don't like my GPU yelling at me or screaming in agony). I assume there is no possible potential of damage (temps are fine). Anyway, this may be unrelated to your squeak, which may be due to load, temps, and fan speed (or even certain speed, which resonates, basically a problematic fan).
OAKside is offline   Reply With Quote
Old 4th July 2023, 02:18   #1533  |  Link
My GPU used to click [but not just with KNLMeansCL, which I dont think I've ever used],
I removed it, gave it a clean, plugged it back in and hey presto, no clicking now, for a couple of years.
Old 4th July 2023, 02:57   #1534  |  Link
TDS
TDS's Avatar
Try:-
MSI Afterburner
You could change the fan "curve", and maybe get passed the "squeak zone".
Old 10th July 2023, 23:28   #1535  |  Link
Katie Boundary
Katie Boundary's Avatar
Come to think of it, a throttling parameter could be pretty generally useful. Set it to 30 and it won't use more than 30% of your available GPU power so you can play Cyberpunk 2077 while you render.
I ask unusual questions but always give proper thanks to those who give correct and useful answers.
Katie Boundary is offline   Reply With Quote
Old 11th July 2023, 10:16   #1536  |  Link
ChaosKing
Another way would be to set a lower Process Priority in Task Manager
ChaosKing is online now   Reply With Quote
Old 1st August 2023, 16:38   #1537  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
Sounds like coil whine. Nothing you need to be afraid of. But it can be annoying depending on how sensitive your hearing is to high frequencies.
LeXXuz is offline   Reply With Quote
Old 31st January 2024, 20:55   #1538  |  Link
Katie Boundary
I have a new laptop and I'm reinstalling everything. I have several versions of KNLmeansCL and none of them work in Win7. I don't know why.
These are the versions that I have:
KNLMeansCL-v0.6.11.zip
KNLMeansCL-v1.1.1.zip
KNLMeansCL_1.1.1_test_for_avs3.5.2.7z
KNLMeansCL_1.1.1e_v20201112-pfmod.7z
Please direct me to one that works in Win7. Thanks.
Old 31st January 2024, 22:30   #1539  |  Link
ChaosKing
Knlmeanscl depends on MSVCP140.dll, VCRUNTIME140.dll, VCRUNTIME140_1.dll
You probably missing 2015-2022 runtimes https://learn.microsoft.com/en-US/cp...?view=msvc-170
Old 1st February 2024, 07:01   #1540  |  Link
Katie Boundary
It's not that. I already have the MSVC++ 2005, 2010, 2012, 2013, and 2015-2022 runtimes in both 32 and 64-bit.
